Question about Miele S758 Bagged Canister Vacuum
The yellow bearing cups in the Electro Plus power head (which is attached to an S758) have partly disintegrated) cannot find a location or purpose for the thin bare wire coming out of the bearing assembly. Thanks, George.
Power head attachment does not pick up, rotating head does not turn
replace belt or brush unit because the bearings are shot,or pull the brush out and clean it thoroughly
May 29, 2015 | Vacuums
Solaris electro plus need replacement roller brush for electric carpet cleaning head
The part number for the roller is 4929740 if you are in Australia or NZ we can get the part for you (VacuumSpot)
Feb 16, 2013 | Miele S514 Solaris Electro Plus Vacuum
Manual for s758
if you mean the simple owner manual it is here
https://miele.ca/en/Service/Manuals?parentFolder=%5C%5CVacuums&childFolder=Previous%20models&language=en-CA
Jan 27, 2013 | Miele S758 Bagged Canister Vacuum
The vacuum fan disintegrated. Unable to determine how to remove the fan from the motor shart.
Follow the steps below gradually:
Remove your vacuum's power head by first switching the carpet height adjuster to its highest setting. Turn the belt lifter, making sure that the two red arrows pictured on the lifter are pointed at each other. Disconnect the head, and take it off.
Remove the bag and handle by first unsnapping the handle by pushing a button on the back of the handle located near the base of the handle. To take off the bag, place your hand on the plastic located at the bottom of the bag, and pull it off.
Remove the metal body by simply unscrewing the four medium-size screws that are now visible because of the power head removal. Once the screws are removed, you can easily lift the metal body right off.
Remove the front fan cover plate using a screwdriver to remove the screws located on the front of the plate. Once they are removed, the fan plate should pull off. If it doesn't, gently pry it off by wedging the screwdriver between the plate and the base.
To remove the fan, clamp a pair of vice grips on the pulley to keep it from moving. Attach a 9 mm end wrench to the motor shaft; this will ensure that the shaft won't spin. Turn the vice grip, which will un-thread the pulley, and pull off the fan.
Integrate the fan, and put the vacuum back together. Plug it in, and test it to make sure it's working properly.
Good luck.
Mar 30, 2010 | Vacuums
Lubrication for powerhead motor
the power head motor dose need service first thing you should do is take the top cover off by removing the screws on the bottom of power head then remove brushtroll clean brushroll and the end bearings make sure they spin freely squirt some lube (wd40n or tri flow) on the end cap bearings . Then clean motor by blowing it out with compressed air lube bearings with either wd40 or tri flow that should free up the motor and brushroll
May 26, 2009 | Vacuums
IRobot not picking up dirt
try to replace the filter, that should work.
Feb 23, 2009 | iRobot Roomba 530 Robotic Vacuum
Eletrolux power head
Usually you will find a brush assembly which includes the bearings. You could also be hearing the belt jumping across the brush gear if the belt is bad. If you order the parts online, you may want to get a brush and belt, since a belt won't be that much more money anyway. Aftermarket Aerus (formerly Electrolux) parts can be suspect sometimes, so I would suggest finding a dealer. You can go to their website to find the closest store. aerusonline.com Good Luck!!
Oct 20, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Power down while vacuuming
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559408
Generic problem for all Vacuums
Posted by leo_bateman on Apr 30, 2008
Power down while vacuuming Comment by leo_bateman, posted on Apr 30, 2008
With Miele S758 vacuum cleaner. Occurs continually.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I would advise checking your owner’s manual, it sounds like it could be a motor going bad and It might still be under a factory warranty depending on when you purchased the item, check the owner’s manual for the trouble shooting part to see what is going on and I will also give you some phone #’s listed below to assist you with your problem. Part of which might be the belt if it is a flat belt – it does require changing every 4 to 6 months and if it is a geared belt then you should replace every year or so for the best cleaning. Or you may have a bad connection or computer board that is going bad. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Power Head for Electrlux Oxygen Ultra
I work for Aerus Electrolux. My office # 570-326-1731 Call me and I will help you order the part. Liz
Feb 26, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Miele S758 stops working for no reason
The problem on mine was as described by others. Miele s758 stops for no apparent reason. The first time it happened I had the hose assembly replaced under warranty. Two years later, same problem. I have found that contacts at BOTH ends of the hose were intermittent. I dismantled both ends, extracted both sets of contacts, immersed both sets of slip-rings in methylated spirits and cleaned all the black gunk away. The three PCB mounted contacts were similarly cleaned, retensioned and lubricated with Electrolube. After re-assembly the problem has disappeared. I imagine a repeat procedure will be required in a couple of years.
CAUTION: The procedure is a bit tricky, so unless you know what you are doing, it would be preferable to have it done by someone who does. It is worth fixing as the replacement assembly is $AUD400.
GeeJayL
Sep 02, 2007 | Miele S758 Bagged Canister Vacuum
Miele S758 Bagged Canister Vacuum Logo
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
