Question about HP (NN109AA) 2 Speakers
My speakers wont work. It shows no sound or audio on my computer. My daughter was playing with it and got into the control panel and deleted a bunch of things and now my speakers wont work.
  • 302 Answers
She may have set the sound to mute or very low that's why you can't hear anything.
Just go to Control Panel, Sounds and Audio Device Properties and tinker with every possible option that she may have changed.
Posted on Mar 11, 2011
My usb speaker wont play through pc
Is your usb port working? Try another usb port. Are you sure the speakers work? If so, try the speakers on another computer and see if they work.
Look at your Audio and Sound Properties in the control panel to make sure the volume is turned up and not on mute. Click Start/Control Panel or Start/Settings/Control Panel and look for Audio or Sound. You can also get to the Audio and Sound Properties by clicking the megaphone at the bottom right near the time.
May 31, 2012 | ASUS Computers & Internet
I recently bought a new computer and am running windows 7 x64 professional on it. i downloaded and installed the drivers of the speakers, but still 6 buttons on the speakers dont entirely work. the...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 25, 2011 | Logitech Z-10 Computer Speakers
My speaker wont work when i play anytin on internet wit sound i dnt hear a sound from my speakers
1: check the speaker wire. it should connect to a green port at the back of the computer.
2. In control panel open realtek audio device manager. it will tell you where its connected
3. try to configure the speaker from audio device manager on the system tray volume icon
still doesnt work then uninstall the driver for sound card from device manger
restart the computer
Apr 01, 2011 | Computers & Internet
My speakers are turned on and they are plugged into the computer but they wont play anything
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 11, 2010 | HP USB Powered Speakers . Computer...
I accidently deleted something that made my speakers and headphones stop working in control panel
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 22, 2010 | Altec Lansing ADA 215 Computer Speakers
Logitech speakers not working no sound
Turn off the speakers. Restart the computer with the speakers off. Once fully booted turn on the speakers. I had this problem where with the speakers on when the computer was started the sound card was not even recognized. Loading drivers had no affect. Good luck.
Nov 16, 2010 | Logitech Z-10 Computer Speakers
It just says there as been a problem detected with it and it wont play.
if you mean the sound wont work
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 09, 2010 | Computers & Internet
The speakers wont work no sound
This article contains tips for resolving sound related issues in Windows XP.
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 10, 2010 | Logitech V20 Computer Speakers
Sound
did u install sound card drivers
if u install correctly go to control panel and sound
check there whether audio device is showing or not. if not u didnt install ur audio otherwise u installed correctly but the problem is in ur speaker.
Feb 23, 2008 | Logitech Z-3e Computer Speakers
No sound from speakers
Do other speakers work with your computer? What about headphones? If control panel says there is no sound device, it is referring to the sound card inside your computer that you plug the speakers into. Make sure it is correctly installed. If you have any of the original CDs that came with the computer, see if you can reinstall the sound card drivers.
Sep 21, 2007 | Logitech X-530 Computer Speakers
HP (NN109AA) 2 Speakers Logo
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
