Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Smart mix what is the trick to connecting the smart mix?
  • rachealdawn Jul 31, 2008
    figured it out. Yay for me.
  • 1,673 Answers
Glad you did.
Posted on Aug 10, 2008
The solution in my smart mix will not mix with water and the button just keeps going round and clicks and will not stop on either water or solution.
The smart mix knob is connected to a piston that slides up and down into the automix assembly. This piston has come off of the smartmix knob and left the unit on water only setting. Sometimes the smart mix knob breaks on the bottom side letting loose the piston.
This can be a difficult repair. You have to unscrew the flow indicator window and remove the fan and screen(pay attention to how they come out, most people want to put the pointed end of the white screen down. It goes up.) Place a piece of 2X4, a book, something underneath the machine, between the rear wheels. This will lift the wheels into the air, and keep everything in place when you remove the hood. Take the 6 screws out that hold the hood and lens. As you remove the hood try to do it slowly and pay special attention to any hoses that might try to pull off with it. If you don't get those hoses back into the right place, the machine will not work. The piston will probably be stuck into the automix assembly when you get the hood off. It is a three inch black cylinder with an O ring on it. If you hold the hood upside down and place the cornered side of the piston into the corner of the housing between the knob and the solution chamber, you should be able to hook the winding on the knob with the piston and then turn the knob to screw the piston down into the windings. It won't lock into place, but hold it there well enough to put the machine back together correctly.
If you feel like you're forcing something when putting the hood back on, you probably are, so stop and check to make sure all the hoses are where they are supposed to be.
Good Luck
Nov 25, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Replacing Smart Mix knob
The knob itself will only go in one way, What I was talking about is when you put the top cover back on, the knob should be in the water only position. This way the piston (on the bottom of the knob) will go into the slot correctly.
Sep 07, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7920 ProHeat Problems--No solution spray
Is the smart mix valve turning and stopping where is is supposed to, if it turns all of the way around, then it is broken inside the top cover. Try replacing the smart mix bottle insert and cap asm part #2101795 . Make sure that the rubber gasket is on the valeve asm. at thebottom of the smart mix bottle. If not, it has to be on the valve.
May 19, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Removing the top of the 7901-1 Bissell Proheat
Unscrew the cap for the flow indicator, remove the 6 screws, the top will come off. When you put the top back on, make sure the piston is hooked on the smart mix knob(underneath the top cover) set the smart mix valve in the wtaer only setting, then put the top back on. Turn the smart mix valve to make sure it is turning like it should, then re-install the 6 screws and the flow indicator parts. (don't over tighten the screws)
May 16, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
I purchased a Pro Heat self propelled Bissell rug cleaner model 7950 from Target wherehouse on 4-26-06. I used it once and all was fine. The next time that I went to use it the smart mix for the cleaning...
I assume that it is spraying water? Is the smart mix knob turning freely from one point to the end? If not then there is a problem with the smart mix asm. With liquid in the soap bottle, push the valve in to see if liquid comes out ok, couild be that the valve is bad. Is the seal on the valve at the bottom of the bottle, it has to be on that and not just sitting in the hole. You might try running a mix of water and vinegar thru it, maybe it is clogged up.
Apr 14, 2008 | Vacuums
I have a bissell 1698 powersteamer. i have already cleaned heater and completely cleaned all parts , checked the mix piston, checked belt. it will not shoot water or mix. the motor runs, it will ****...
Pump is probably bad. When you put the lid back down, did you put the piston on the bottom of the smart mix knob? Also the smart mix knob should be in the water only selection when the top is pushed all of the way down. Also sometimes the flow indictor cap can give you a problem with it leaking air.
Apr 13, 2008 | Vacuums
Will not spray water or cleaner
When you put the top back on, the smart mix vale should be on the clear water setting. Make sure that the piston is on the smart mix know under the top.
Jan 02, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Pro-Heat Pro-Tech Carpet Cleaner
Put the piston on the bottom part of the knob, You want the the knob to be at the water only setting when it goes into the slot. After the top is pushed all of the way on, turn the auto-mix knob to see if it is turning easily. If it doesn't stop, and wants to keep turning, then you probably need a new knob.
Nov 23, 2007 | Vacuums
Bissell proheat pro tech model 7901-3 smart mix dial and valve assembly
Turn the knob to the water only, put the piston on the bottom of the knob then turn it slightly so it doesn't fall off, Start to put the cover on, when it is straight, turn the knob to the water only selection and push the top all the way down. The piston should have gone into the hole and the knob should turn easily.
Nov 14, 2007 | Vacuums
Bissell water not working
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix know. Pump is bad.
Oct 21, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
52 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
