How do I use the stove. We bought a house with a anthrasite stove, but we do not have an idea how to start it
    Brigadier General:
  • 4,736 Answers
Not sure which model you have, Reading Stove Co makes the anthracite model. Here's a link to their website http://www.readingstove.com/ Click on the Coal Stove Safety Tips tab and look for your model under Owners Manuals.
I hope all of this will be helpful to you.
Posted on Mar 11, 2011
I bought a house with stove in it. seems to be in good condition. Has no damper and no adjustable drafts. is this right?
Usually not a good idea to have no adjustments to the flu or the combustion air supply. Those two directly effect control over the fire and without them, it is just a bonfire in an enclosed space. I know of no manufacturer that makes a stove without combustion air control (front damper) of some type. You cannot safely operate the stove with too low or too high of flu temperature and you achieve that happy medium by controlling the fires air supply and flu draft.
Mar 07, 2015 | Home
I bought a house with a wood burning stove but I don't know how to operate it
First make sure everything is clean,from the chimney to the stove.insure all metal flues are tight from stove to chimney. Open damper on top of stove(some are in metal pipes). Open your draft vents, usually on clean out door at bottom. Depending on chimney draft you may need to open clean out door to get it started. Load your kindling and get it started. Add bigger wood as it catches. Turn down venting and drafting as the fire roars. Just don't shut draft before vents. You'll get used to balancing draft and vent as you go. I hope this helps
Nov 19, 2014 | Home
Stove top and oven doesn't work.
If it is an electric stove it may have tripped one side of the 230 line. Check the house cuircuit breaker panel and find the stove circuit breaker. It will be tied together by a bar or clip. Shut off both breakers completly and reset them back completely. If it is a power problem this should reset the stove.
Dec 01, 2012 | Kitchen Ranges
I bought a house with a Warnock Hershey eclipse pellet stove. Am having some problems. Where can I find a manual?
Warnock Hersey is not actually a manufacturer's brand, but a certification. You can find more info here: http://www.wood-stove.org/firebelly-stoves.html .
or you could try this link:
http://www.pelletking.com/pellet-stove-manuals/Whitfield-Advantage-IIT-Pellet-Stove-Manual.pdf
I hope this helps you out & if it does please don't forget to rate me, kind regards, Paul
Sep 14, 2012 | Cars & Trucks
Removing a stove pipe through the roof
I would begin by going up on the roof to see what the situation is because you are going to have to remove the stove pipe and repair the roof to assure no leaks. Usually the only thing holding the pipe is roof cement through a rubber boot. Use a razor blade knife to cut through the tar, then remove the boot by pulling the roofing nails that hold it in place. After that, patch the roof and reshingle. If this is more than you care to do yourself you will have to hire it done. good luck
Jan 22, 2009 | Plumbing
Just bought a house, no manuals
After a pot spillover, the cleanup process triggered my stove top to "control lock"
I removed the pot and once the stove top cooled I pressed and held the "control lock" button.
It began to blink, I released it and then the light went off and the stove top operated normally.
You might not have to wait for the stove top to cool. I don't know.
Aug 24, 2008 | GE Profile JP930 Electric Cooktop
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
There is nothing fancy about how the gas controls work on this unit. Do all burners give you the same problem? If so, it could be a kinked service hose or a service valve that has been partly shut. If it is limited to a single burner or two, the valve may be gummed up and should be replaced.
Nov 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Heating & Cooling Logo
168 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
