Question about Sanyo DP32648 32 in. LCD TV
The picture on the tv is shaking and pausing/freezing for seconds at a time.. and discolored but no signs of permanant discolor like a cloud on the tv screen.. what could cause this?
  • 23 Answers
This seems like an internal problem, and can only be solved by an experienced television troubleshooter, I suggest taking it to a professional.
Posted on Mar 11, 2011
I have pink color horizontal lines on my LG LCD monitor screen,How do i solve it?
You can fix you have to follow this instruction
1-Reset the TV by unplugging its power cord for 30 seconds and plugging it back in. This is an essential troubleshooting tool as a simple reset often will resolve the great majority of technical issues experienced by any kind of TV. Power the TV on after plugging it back in and check the picture for any improvement.
2-Unscrew the coaxial cable that attaches your wall cable outlet to either the coaxial cable input on the plasma TV or to any digital cable converters you may use at home. Check the copper needle in the middle of the cable for any bending or damage and screw the cable back on the coaxial input. Again, check the picture for any improvements.
3-Secure the audio/video connection cables that attach the source device you are trying to watch to the plasma TV. This is a particularly important step if you use component cables. Component cables separate a video signal into different colors, so a damaged or loose component cable can lead to noticeable discoloration on the screen. Once the cables are secure, both in the source device and the plasma TV, check the picture again to see if this may have resolved the issue.
4-Scan your channel lineup and check the other TVs in your home to determine the scope of the problem. If you see the discoloration only on one or a few channels, and the same channels are discolored on the other TVs in your home, you may be part of a cable service outage and you will need to report the issue to your cable provider. If all the channels on the one TV have the same discoloration, and the other TVs in the home look normal, the plasma TV likely will need to be serviced for a problem with its picture components.
hope that it helped
Feb 18, 2014 | LG 22" FLATRON LCD Monitor
Our sun rite tv screen shows smudges how to clean
Most of these sets the outer part has a coating like on a old camera lens--any harsh or chemical cleaner discolors it--it is permanent damage and just the glass cannot be replaced as it is part of the front screen unit called a display panel.
Apr 17, 2012 | SunBriteTV 3200HD-Pro 32 in. LCD...
Discoloration when i hook my laptop to the tv
If you are using a VGA to VGA cable, it may be bad. These cables carry Red, Green, Blue, Vertical, and Horizontal information. If one of the colors are missing, the picture will be discolored.
Mar 15, 2010 | Televison & Video
Screen discoloration
the problem of your TV is discoloration cause by a defective thermistor or sometimes by speakers beside your TV because of magnetic field or magnets
Oct 30, 2009 | Sansui DTV2760 27" TV
Aft self-cleaning, top of oven door and knob panel discolored
This is a problem with a bad door gasket, or a mis-adjusted latch. That needs to be addressed, then you can replace the discolored parts. The discoloration is permanent.
Oct 24, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Sony KV-32FV27 Picture Discoloration
It appears that the greenish discolored area could be cause by the Yoke or it could also be some magnetization on the screen as well.
If it's the yoke that moved slightly out of position, it can be adjusted, but i would suggest to let a repair tech do it due a high voltage around the area.
Try unplugging the TV for some time and plug it back in and hopefully the demagnetizer circuitry might be able to clear the greenish spot.
Let me know if you need further assistance.
Jul 01, 2008 | Sony KV-32FV27 32" TV
Pictures has discoloration
From the picture it looks like the digital board or gama board. not a do it your self project. call a tech and expect $$$$.
If you get real lucky it may be a bad or lose connector.
Jun 28, 2008 | Vizio L32 32 in. LCD HDTV
The main video processor, or the input board, or something with screen backplane is failing. This has to be determined from proper diagnostics.
You will have to send the set in for service to fix this. If the set is out of warranty, this can be expensive to service.
Jerry G.
Jun 28, 2008 | Vizio VX32L Television
Television pictures
Is this green all over or just in one corner? If all over then depending on the set, which I don't know what kind or size. It means something if its a big screen or direct view.
Sep 21, 2007 | Hitachi 36CX39B 36" TV
Sanyo DP32648 32 in. LCD TV Logo
372 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
