Question about Kitchen Appliances - Others
MY ELECTRIC FAN OVEN TEMPERATURE KNOB DOES NOT WORK THE OVEN JUST KEEPS HEATING TO THE HIGHEST TEMP AND BURNS EVERYTHI
  • 23 Answers
The problem lies in the detection system and sensors.
Posted on Mar 11, 2011
  • SQUAREL Mar 12, 2011
    not much help can you give more detale on this
My oven keeps cutting out (fan stops and heating) but it isn't at the temperature selected on the control knob. Sometimes it goes up to temp, sometimes it stops a LOT lower.
Oven comes on and off intermittently or heats very little:
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
The reason for my free advice is GOD is good!
Apr 30, 2015 | Belling Ovens
My Maytag MGR5750ADW oven will take forever to preheat. It does get hot, but the preheat light takes a very long time to go out. Food takes much longer to cook as the oven does not seem to get up to temp.
Hello there and welcome to fixya
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Aug 10, 2011 | Maytag Ovens
Everything works fine except it does not heat up at all. Convection fan, Oven lights, Control panel all work an act as expected. I tested the Temp probe at 2K ohm an got 1.066. any help would be great. Is...
Hello there:
Here are two instances of when food "bakes poorly:" or not at all When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Nov 20, 2010 | Frigidaire PLEB30S9DC Electric Single Oven
Oven works but wont get up to temp
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.-----
thanks for using fixya,please do rate the solution positively.
Feb 17, 2010 | Magic Chef Ovens
Burnt some food yest in grill and is not working today. wouldnt turn on straight away so i left it till this morning but still not heating up. oven is working perfectly fine. could the heating element for...
if the temp light or indicator light for the grill is on then i'm tempted to say that it is the element but checking for resistance is the only sure way to know..
Dec 22, 2009 | Zanussi ZBF360 Electric Single Oven
My oven's bake/broil element won't heat
It could be the stat (temp probe) or the cut outs. if these are faulty then it will not allow the elements to heat up
Sep 21, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oven doesn't heat up to the right temp--lower oven Viking Pro
Adjust the knob to the actual temperature. There are usually screws inside toe back of the knob for this purpose.
Mar 23, 2009 | Viking DEDO205 Stainless Steel Electric...
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Oven temperature fisher paykel
benypeny what that flash was from what I have seen over the years is your heating element on the back wall burning out. Remove the cover and you will see the element is no longer in 1 piece.
Feb 03, 2008 | Ovens
Kitchen Appliances - Others Logo
46 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
