Question about Panasonic AG-1330 VHS VCR
How do I pop the tape out??
How do I pop the tape out in order to reglue the piece?
  • smoedklein Aug 04, 2008
    I will give it a try. Thank you.
  • 56 Answers
Manualy by your hand.You have to turn the gear connected to the motor and rotate it till tape is out
Posted on Aug 01, 2008
J C PENNEY 6915 SEWING MACHINE TENSION ASSEMBLY POPS OUT. CAN'T GET IT TO STAY IN PLACE.
Other than taking it into a sewing machine repair shop, I would buy some "packing tape", clear kind, and cut a piece of tape and put it over the plate so that it can't pop out.
Jun 22, 2016 | Sewing Machines
Interior rear view mirror fell off my 98 BMW 540i
There is a small set screw that holds the mirror to the small metal button. Most vehicles use a small Phillips screw but some use a Hex Key Wrench (Allen Wrench) type screw. Slide the mirror off the button. Make sure not to remove the glue before you put the button back on. Trace around the glue with a grease pencil on the outside of the windshield before you remove it. So you know exactly where to replace the button. You can buy a Rear View Mirror Adhesive Kit for around five dollars.
Jan 10, 2012 | 1998 BMW 5 Series
What type of adhesive should I use for the door on a Farberware T4800 convection oven?
You need a tube of permatex blue or black RTV silicone.
I reglued my door about three years ago and it is still holding. Trick is to clean all parts PERFECTLY first using steel wool, a flat 4-sided file, etc.. Then clean real good with acetone (outdoors cause its explosive and toxic). After acetone dries do it again and wipe it dry with a piece of cotton jersey. Then reattach the hinge or handle sides using the silicone and tape it with blue masking tape. Let cure for 48 hours. You will have a joint as good or better than the factory joint.
Oct 15, 2011 | Farberware T490C 1500 Watts Toaster Oven...
Rearview mirror fell off. how do i remove the metal plate from the mirror to reglue
It may be held on by small set screw. (Allen wrench type) Or it just pops on and off, with effort.
To pop it off, hold the mirror as it would normally sit, and with that position in mind, you want to slide the metal plate down and out of the mirror clip, and you may have to pry on it a bit to get it started.
After you have reattached the plate to the windshield, you will have to apply almost the same force to clip the mirror back on.
Tips: Mark the location of the metal plate with a piece of tape on the outside of the windshield.
Make sure you clean the old glue off both the plate and windshield. Do not scratch metal plate.
Make sure you glue the plate on correctly. Do a trial fit on the mirror just prior to glueing.
Aug 28, 2011 | 1998 Buick Century
Audio cassette tape broken. How do I repair?
Radio Shack used to sell a splicing block and tape for fixing broken tapes. They may still, and you can order online from other sources.
You need to pull the tape out from the cassette a little way. Overlap the tape sections a little and get them aligned, which is what the splicing block is for. Cut across both pieces and take away the scraps. This makes sure the pieces match up. Lastly you place special splicing tape over the join and trim the edges. You need the special tape, since it's designed so the adhesive won't ooze out and get on the tape recorder heads.
If the tape has come loose fro the hub inside the cassette, you need to open the housing and use the splicing tape to fasten the recording tape (actually the plastic leader tape) back in place. Depending on how the cassette was made, there may be screws holding it together, or it may have been glued. Some commercially-made music tapes and bargain-grade cassettes weren't made to be opened. If you do open the tape, don't lose the little metal piece with the felt square that goes across the opening behind the tape. This is the pressure pad that keeps the tape pressed against the head in the recorder. Without it, the tape won't work properly.
Apr 12, 2010 | Electronics - Others
How to take apart driver side door for motor replacement
use something plastic, usually door pieces just pop off, there may be small plastic circles or squares covering the screws that are holding your door panel on. doors are a pain, be careful, go slow, and take your time or you are going to end up replacing plastic pieces. The plastic behind the panel can be cut and re taped , or unpeeled and reglued, just helps with moisture not getting into components and frying things like your motor and switches.
Mar 11, 2010 | 2000 Dodge Caravan
Sony's broken button issue
You need to use you fingernail and pop off the entire button assembly. When you have done this you will be looking inside your camera.
Set the new button assembly into the slots. It will not want to go on by just pushing down. The plasitc assembly is very slick so put a small piece of scotch tape the yellow stuff. I put the tape around the plastic assembly. Make sure you are only putting tape on the chrome plastic assembly. The reason for the tape is to get a good hold of the plastic asembly.
Once you have the tape on the assembly/chrome piece you need to really push down and twist clockwise. You will hear a click and then another click. Make sure you hear two clicks. I had to push and twist pretty hard to make it lock into place.
Jun 07, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Video tape stuck
Unplug the VCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Jan 05, 2008 | Panasonic AG-1330 VHS VCR
Panasonic AG-1330 VHS VCR Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
