Question about Cameras
Significant heating problem in a 1987 525e bmw. fluid levels are fine in the radiator, cleaned the thermo sensors on the radiator. flushed and filled rad. and bled out air. still overheating. what could it be?
  • 734 Answers
When you fill up the coolent, make sure there is no air when you put on the cap. Let excess liquid flow out when you turn the cap to lock it.
Posted on Mar 11, 2011
2001 caddy Deville 4.6 only runs hot while driving with ac on .rad. water pump and thermo. Has been replaced and fans work.help
check fluid level --radiator may need to be clean externally--may need a flush --recheck fans for proper speed
Jul 06, 2016 | AC Cars & Trucks
My car is running hot do u think i need to change the motor?
buy a radiator flush kit, some prestone flush additive, and even maybe a new thermostat, and a simple haynes manual for your auto. The manual will tell you where and how to change the thermostat, and how to drain the radiator, and how much radiator fluid you will need. The flush kit will instruct you where to put the flush fitting.
Remove the thermo, flush the motor, install new thermo and gasket. Add radiator fluid, done. This should solve your over heating probs. Don't let it over heat! You can cause major probs then.
You could always take it to a shop and pay the $200 to do it for you. My way would cost you less than $50.
please click yes if this helps. thanks
Jan 22, 2010 | 1999 Mercury Cougar
99 GMC suburban, I added spot leak to radiator because of low fluid level, now I get no heat inside of vehicle?? I changed thermo just in case? Now no heat and the engine temp jumps up and down?? Any help...
must have screwed up your temp sensor,could have plugged your heater valve,if you do replace the sensor get 1 from dealer not autozone, also low coolant level will affect the heater!
Jan 11, 2010 | GMC K1500 Cars & Trucks
Durango 4.7 Overheats
check and clean evap and radiator, check level and ratio of fluid
Sep 12, 2009 | 2004 Dodge Durango
2002 pt cruiser overheating was told i need a new raditor and thermostat for 1 grand sounds fishy
Flush rad & change coolant & thermostat. Check operation of rad fan, & make sure it is coming on when engine reaches normal operating temperature. Be sure to bleed air out good when refilling rad/cooling system. Start engine & turn heater on when refilling & let rad fan come on & off at least 2 or 3 times before putting cap back on rad, and refill rad as needed as you do this. then fill return bottle to proper level & see what happens.
Jun 27, 2009 | 2002 Chrysler PT Cruiser
I unplugged the sensor from the removed the Air Filter assembly, and then removed the assembly to get to the radiator drain. I then drained and flushed the radiator. After the final flush, I filled the...
Likely you set that code by removing the sensor...you can usually clear it by disconnecting the battery or if you keep driving it I believe eventually it will go out when the computer cycles through and finds it is now OK.
Jun 25, 2009 | 1999 Buick LeSabre
Flush the radiator
wins radiator flush
Jun 01, 2009 | 2002 Nissan Altima
2003 ford focus station wagon
have your waterpump checked also thermostat flush radiator and renew the cap make sure your thermo fans are functioning
Jun 02, 2008 | 2003 Ford Focus
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
