Question about IBM ThinkPad T42 Notebook
Ok im lock out the problen started when i left a gap byetween pass code ibel so what can i do to unl
    Sergeant:
    Champion:
  • 212 Answers
Change the cell of mother board lop top
Posted on Mar 11, 2011
V-chip block passcode
Hello
You must have its original remote control handset to unlock your Mitsubishi tv.
After you set the lock, you must use your pass code
to view a locked program, view the locked TV, view
a locked channel, cancel the lock, or enter the Lock
menus.
If you forget your pass code, you can view the locked
TV without entering your pass code. When you are
prompted for your pass code, press the number 9 and
QV keys on the TV remote control at the same time. This
process temporarily unlocks the TV.
When entering the Lock menu, this process deletes
your old pass code and prompts you to enter a new
pass code.
• You can either enter a new pass code to open the
Lock menu and make changes or press EXIT to close
the menu.
• If any of the locks are turned on and you exit the
menus when prompted for a new code, the old
code and all lock settings are retained.
• If all locks are turned off and you exit the menus
when prompted for a new code, then the previous
code is erased.
OK.
Mar 17, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
SGH-a437 phone locked
is the Sim locked or is the phone locked??
Sep 21, 2009 | Cell Phones
Abs light blinks 16 times brake lights dont work
16 is a pass code. For some reasom your diagnostic connector is in test mode.
If light flashes, diagnostic circuit is grounded. CORRECT condition.
If anything other than Code 16, and starting with the first code recorded, GO to the pinpoint test for that code.
If Code 16, and if previous action has been taken, concern most likely has been corrected and ABS system is OK. Otherwise, GO to PC6 .
Diagnostic Data Link Connector located at the left-hand side of the engine compartment and marked ANTI-LOCK TEST.
Jun 26, 2009 | 1996 Ford F350 Crew Cab
Trunk not releasing on 2003 E320.
The mechanism might be siezed. Try lubricating the lock or heating it up to release it.
Jun 17, 2009 | 2003 Mercedes-Benz E-Class
Updated software, now unit tells me im missing software.
You need the unlock codes from your account at Garmin....
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl
(( important double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
Regards
Richard.
May 18, 2009 | Garmin GPS
1997 buick skylark theft system .
Hi....
Is common to see this problem with the theft system on chevys.
On your case I can figure out that the Computer is lossing the Pass code.
But this is due to a Bad pass lock sensor . The pass lock sensor is integrated in the Ignition lock cylinder.
The car will start After about 15 minutes. with the key In On position.
Because is about the time that the computer take to learn the Pass lock code. Exactly 11 min.
I recomend get the ignition lock cylinder checked for any inconssistence on the hardware.
The key some times bent. Or the small wires around the Lock cylinder damaged.
If everything is OK.. You will need to replace the Ignition lock cylinder , Before any control module...
Ok.. I hope this help on your problem.
Thank you for use fixya...
Jan 12, 2009 | 1997 Buick Skylark
Heavy vibration and noise
YOU MAY HAVE CUT THE COVER CHUTE
INCREASING THE GAP BETWEEN THE
BLADE AND CHUTE BOTTOM ALLOWING
LARGER CHUNKS TO PASS THRU. INSPECT
AND IF NEEDED ORDER NEW ONE FROM
OMEGA AT 717 561 1105. ABOUT $15.
Dec 28, 2008 | Omega 1000 Juice Extractor
88 toyota corolla meets skyline front how to fit tips etc
you mean 1988..??.. ok.. yes a good fiberglass man could help and fix this..and then repaint to EXACT match so you can pass whatever you need to pass...
May 13, 2017 | 1988 Toyota Corolla 4 Door
IBM ThinkPad T42 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
