Question about Canon CanoScan N640P Flatbed Scanner
I can not run the canon scanner n640 p ex in windows 7 while it is good working in win xp. so please help me how can i installed??
    Guru:
  • 254 Answers
Hello there
you need windows 7 driver of your cannon here the link : http://www.usa.canon.com/cusa/support choose your operating system and download the windows 7 driver of your cannon scanner
thanks
leave a comments
Posted on Mar 11, 2011
Canoscan n640 not work in windows 7
Canon stopped supporting this scanner after XP. The available software and drivers are here: http://www.canon-europe.com/Support/Consumer_Products/products/scanners/Others/N640P_ex.aspx?type=download&page=1 .
Depending on the version of Win7 on your computer, you can try one of the following workarounds. To check your version, click Start > Control Panel > System and Security > System. If it says x64, you have a 64-bit version of Windows 7. Otherwise, it is the 32-bit version.
1) If you have the 32-bit Win7, you can try the compatibility mode. Download the driver or full software from the Canon site and right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties. This may not work.
2) The option that will work for all versions of Win7 is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or upgrade to them), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the Canon site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. Also a printer cannot be installed on both the real and virtual computers at the same time. You will be prompted to uninstall one set of drivers if you try.
I hope this helps.
(the above suggestions assume you do not want to replace the scanner which would be faster.)
Jun 07, 2011 | Audio Players & Recorders
Do I have to uninstall "MP Navigator Ex 1.0"
Unless specified, the installer will automatically remove the older version and replace it with the new.
Mar 02, 2011 | Canon MP Navigator EX for Windows
I need driver for windows 7
The driver for XP should work. You can find it here: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_d646u#DriversAndSoftware
Mar 01, 2011 | Canon CanoScan D646U Flatbed Scanner
Installer of canon canoscan n640 p ex
Click the link above.
Install the program and run the file. It will automatically search the appropriate driver for your scanner.
Should you have any questions regarding the link above, feel free to ask us.
Good day and God Speed.
Jun 24, 2010 | Canon CanoScan N640P Flatbed Scanner
Need drivers
there is no driver yet for windows 7.but download scan gear and scan gear toolbox from here:http://software.canon-europe.com/products/0000473.asp  open properties,compatibility and run it in compatibility mode for xp sp2
Feb 28, 2010 | Canon CanoScan N650U Flatbed Scanner
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
CanoScan640P ex
If upgrading an existing PC to Windows XP from an earlier versionof Windows, Canon recommends a "clean install" to ensure reliableoperation of drivers. If a clean install is not possible, it isessential that drivers for your existing Canon Hardware are UNINSTALLEDprior to upgrading to Windows XP. After the installation of Windows XP,the drivers for your Canon Hardware can then be re-installed. Canon has released a software utility to uninstall USB and SCSI Scanner drivers for this purpose. Click here to download this utility.It is recommended to consult our Driver Downloads page and use the latest driver for your product. Canon supports several scanner models with Windows XP. Windows XPsupport is offered for Windows XP Home Edition, and Windows XPProfessional.The following older models are not compatible with Windows XPdue to hardware design: IX-3010, IX-4015, IX-4025, CS 300S, FB310,FB61
Source
Sep 20, 2008 | Canon CanoScan N640P Flatbed Scanner
Canon CanoScan N640P Flatbed Scanner Logo
413 people viewed this question
old marine
old marine
