Question about Ryobi Backpack Blower 25.4cc
MY MACHINE IDLES BUT WILL NOT REV UP. I HAVE FITTED A NEW CARB REBUILD KIT
    Guru:
  • 479 Answers
Check the fuel filter on the fuel line in the tank and ensure it isn't blocked.The fuel line can be pulled out of the tank with a piece of bent wire.Check there are no kinks in fuel line.
Make sure that the air filter isn't blocked.
Check the throttle cable is operating the throttle plate in the carburettor ok.
Posted on Mar 11, 2011
Sportsman 90 idles wont rev
Replace spark plug (gap correctly),Drain all fuel, replace fuel filter, replenish tank with fresh fuel, do a thorough readjustment of the carb settings (last resort - remove and rebuild carb)
Feb 17, 2015 | Polaris 2008 Sportsman 90
Emgine idles but will not rev up
Suggest cleaning/checking the carb. Could be blocked jet and or if CV carb could be a incorrectly fitted rubber or one with a perferation in it.
Feb 09, 2014 | 2010 Kymco Agility RS
Carb on srm400be want rev up
Check the spark arrester on the muffler outlet if fitted to see if it is carboned up, if not check the exhaust port has not blocked with carbon
Dec 05, 2012 | Garden
My jag smells like as if it was flooding when i try to start it, when it does start it idles fine but as soon as I rev it up it bogs out, please help me as i really can`t afford to take it to a mechanic,...
Well first off what year and kind of Jag is it?That will make a difference on what might be the problem.If it is a carbureted model, it sounds like you either have a simple fuel line leak going to the carb so when your car sits fuel drips out and gives you the gas smell and then sucks air when you rev it up.If there is no line leak,sounds like your float in the carb is sticking open and simply flooding the carbs with gas,hence the smell and the bogging out at rpm.You would need a carb rebuild kit with float to fix that problem.That way you have gaskets and floats to fix your carb.
Aug 17, 2011 | Jaguar XJ6 Cars & Trucks
Difficult to start,runs for 15mins overheats ,stops wont start.does not seem to rev up enough.New chain fitted.Any ideas ?
Make sure the air vents are clear.try adjusting the high speed jet.or you will need to rebuild or replace carb.
Dec 02, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Engine bogs down when speed is increased.
Ok I have r Royobi Tiller (30CC Gas) And last year it ran fine after rebuilding the Carb. This year it was "hard starts" Idles fine, (Tiny whisps of blue smoke in exhaust with correct ratio) Even seems to run better with the choke "on" but still...at idle only. as soon as I touch the throttle...its bogs down in tune with how much gas I give it. Little throttle? Little bog down, Little more throttle? Almost stalls, a normal throttle rev? it stalls dead! Then starts right back up again in 1 pull and idles fine again!? WTF? So after cleaning a clean carb again, (twice) and seeing no change I thought I'd go look at the original diaphragm and compare it with the rebuild kit diaphragm (which is the one in the carb.) And guess what? The replacement has a larger rivet by a factor of "2". So basically it was flooding the carb, I bent the needle tang down, better but no cigar. But I could rev it half way now. A second disassemble to bend it yet a bit further and Vrooom vroom vrooom ****! So check your needle valve even though you think its 100%. (Especially if you rebuilt the carb with a kit!)
Mar 27, 2010 | Honda 25cc 4-cycle Mini Tiller
Lawn trimmer runs but won't rev
You need to clean the carburetor. Remove & disassemble. Use a Den Tek Brush,
(http://www.shopping.com/xPO-Lustrasilk-Lustrasilk-Cholesterol-Shea-Butter-Mango-20Oz-Bonus), to clean small portals in carb. Spray carb. with carb. cleaner. make sure the small screen in carb. is free of debris. Reassemble and start. If this doesn't work, buy a carb.kit and replace the needle valve, gasket(s), small screen, & diaphragm.
Jim
Jun 06, 2009 | Craftsman 25cc Gas Line Trimmer
Ryobi Backpack Blower 25.4cc Logo
177 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
