Question about HP LaserJet 5200tn Printer
I am using hp5200n laser jet, 50.4 fuser error is coming, what do to
  • 82 Answers
It would need a specialist to repair it or replace the fuser with a new one in case you can not fix it .. I think that hot piece failed. This defect you find in your printer manual
Posted on Mar 11, 2011
What is the solution for fuser error 50.4 in laser jet pro 400
Most likely you will need to replace the fuser. Try plugging the printer in to a different outlet than it is right now. If you get the same error then you can be pretty sure the fuser is bad.
Feb 20, 2015 | Laser Office Equipment & Supplies
50.1fuser erro hp5550dn
50.1 Fuser error:Low/No Fuser tempatrature, replace Fuser assembly.
For service engineers: Reason: thermo switch open, remove fuser assembly, dis-assemble up sleeve, check switch continuity, if no continuity, remove switch & just hit gently on aluminum capsule till continuity comes,make sure it should not damage or dent,once continuity comes, clean main thermister & sub thermister, fix it back, power on the printer, chek errors,adjust fuser temperature in low, give prints up to 50 blank copies, chk.. if problem repeated replace Fuser assembly, but success rate is 70% for above exercise. Note: Only professionals can perform this activity..
Thermo switch:
Oct 02, 2013 | HP LaserJet 5550 Printer
Fuser error
Directly form HP's website:
50.2 Fuser Error Turn off then on
Error message 50.2 Fuser Error Turn off then on Description 50.2 Slow fuser error. The device has experienced an internal hardware error. Action
  1. Turn off the device, wait at least 25 minutes, and then turn on the device.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.
  3. If the problem continues, contact HP Customer Support Center for technical assistance
Feb 08, 2012 | HP Laser Jet Pro CP1525N
An error jut appeared on my laser-jet 4200 saying 50.1 Fuser Error and asked that the printer be switched off and then on but the error is still there and i cannot print. What could be wrong and how can...
A laser printer works by putting the dry toner ink onto the paper, and then using heat, via the "fuser drum", to melt the ink into the paper, permanently bonding the ink to the paper.
So, a "fuser error" means that the fuser unit is not heating up to its "operating" range of temperatures.
Take the printer to a qualified technician, for trouble-shooting, and repair.
It might be cheaper to REPLACE the printer, rather than paying the technician to REPAIR the printer.
May 09, 2011 | Computers & Internet
Hp laser jet 2420 printer 50. error
This is an error with your fuser...you need another fuser...any 50.x error is related to that and they are something that needs replacing regularly(100-150k pages) the heat resister goes out or the film tears..ect....Try www.getthatpart.com for a good deal on a used one...Used are normally just as good as new for a lot less and these guys guarantee their units, they have someone you can call on the phone, so I recommend them. Hope this helps you.
Oct 25, 2010 | HP LaserJet 2420dn Printer
Is the procedure to correct a 50.2 fuser error the same on the Laser Jet 5100dtn as discribed on the 4100?
50.2 is a fuser warmup error. Books to turn printer off for 20 minutes, if error is still there after powerup ... reseat the fuser. Then replace power supply and then DC Controller.
It's basically the same on all laser printers.
Sep 14, 2010 | HP LaserJet 5100dtn Printer
Our HP Color Laser Jet Printer keeps saying 50.2
Hi ellenf971:
Here is your problem.
50.X FUSER ERROR
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
printer off and remove the fuser. Measure
the resistance between the fuser
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Break in the fuser heater. Measure the
resistance between the fuser connectors
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
you will have to get an HP certified technician to replace the fuser assembly.
Hope this helps
Jul 17, 2009 | HP Office Equipment & Supplies
Fuser Error 50.1 Fuser is hot. What is a fuser?
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Aug 17, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 5200tn Printer Logo
153 people viewed this question
Seeker5211
Seeker5211
