Question about Canon PIXMA MP530 All-In-One InkJet Printer
Cant get the scanner to work - press 'scan' button and black 'start' button, but computer scren does not show the scanning function. FYI - Printer is connecred and works.
    Guru:
  • 254 Answers
Hello
Try this: restart you PC if the problem is still exist, uninstall your driver and install it again. might be the driver is corrupted.
thanks
Posted on Mar 11, 2011
  • cri123456 Mar 16, 2011
    Very Good Advised. Thanks
CODE 162,0,0 ON CANON D1350
This happens across the range of Canon Printers. The fix is to push the right button! Yeh I have a differing model, but the answer is the same. Go to the printer and select remote scan. Then invoke computer program. Some one has to be boss either the printer or the computer for scanning.
I can make the scanner printer the boss and issue a TIFF scan to the computer. Just push scan on the printer and select computer (it does a push data)
I can make the computer the boss by selecting the steps below:
Please choose what option you require. Ignore the model number.
The error codes 162,0,0, or 255,0,0, usually indicate that you have not selected a scan type at the machine. Please follow the steps below to perform a scan from the image I-SENSYS MF8230Cn:
Verify that MF Toolbox is closed on the computer and press the [SCAN] button on the printer.
Highlight [Remote Scanner] and press [OK]. The screen will show, "Remote Scanner. Waiting online...".
On the computer, open the MF Toolbox and select [PDF].
Click the green [START] button on the [PDF] window. The machine will start processing the scan.
If you receive any errors or need further assistance with the I-SENSYS MF8230Cn, we recommend that you contact us at 1-800-OK-CANON (1-800-652-2666).
Sep 29, 2014 | Canon imageCLASS D1350
The scanner function on my Canon D480 has not worked since the installation.
Go to the scanner company website and see if there are drivers available for download. Sounds as if you may not have the proper drivers installed.
Jan 07, 2013 | Canon imageCLASS D480 Black and White...
How do I scan documents from Lexmark X7350 to my computer?
Make sure the Lexmark OCR scan software is installed on your computer. The software is available in the install disc that came with your printer. Scanning a document:
1 Make sure the printer is connected to a computer, and both the printer and the computer are on.
2 Load an original document faceup into the ADF or facedown on the scanner glass.
3 Press Scan Mode.
4 Press or repeatedly until the destination to which you want to scan appears.
5 Press Start Color or Start Black.
6 To scan multiple pages from the scanner glass, place successive pages face down on the scanner glass and
press Start Color or Start Black.
May 03, 2011 | Lexmark X7350 All-In-One InkJet Printer
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    CANON MX 320 SCANNER PROBLEM
    You need to control the scanner thru your PC with canon software that came with your scanner otherwise you cant scan anything..first open the printer/scanner software ,select scanner,then place your document and command "scan" on your PC..thats it..
    Jan 05, 2010 | Canon PIXMA MX310 All-In-One Printer
    I just installed a (new out of the box) HP LaserJet 3380 All-In-One printer/fax/scanner. I have NOT set up the fax function (no telephone line available). The unit is connected to my computer with a USB...
    WHen you open the scan application and get to the point just before you scan... open at the top menu "File" and request to "Save As" and give it the "Name.BMP" see if that helps..
    You named the folder but you did not mention naming the file you want to save????
    Aug 04, 2009 | Office Equipment & Supplies
    My Dell copier model# A920 will not copy manually
    If you want to scan you will need to connect the device to a computer. For copying, place a document to be copied on the flatbed scanner and press the color or black button (as appropriate).
    Jun 02, 2009 | Dell A920 InkJet Printer
    How to Scan a Picture onto the Computer
    turn the printer on, place the picture on the glass, on the printer under mode press the big silver button until the scan light comes on  then press select, you should hear the picture scanning, then on the computer, go under my pictures and you should see that picture.
    Apr 16, 2009 | Lexmark P4350 All-In-One InkJet Printer
    Printer shows offline/Scanner has no destination list
    You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
    You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
    Joe
    Dec 18, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
    Canon PIXMA  MP530 All-In-One InkJet Printer Logo
    304 people viewed this question
    old marine
    old marine
