Question about HP DeskJet F380 All-In-One Printer
My printer is not recognised by the computers at all. A salesman of canon said its because the logic board of f 380 is spolit. replace it and it will be solved. is it right?
  • 125 Answers
IF YOU GET SELF TEST PAGE ON PRINTER THEN THERE NOT SIGLE PROBLEM WITH YOUR PRINTER LOGIC BOARD.
Try this out.
if you have you printer driver cd with you install the drivers or if you dont have get it from http://www.hp.com
after installing drivers connect the priter and power it on,
if it is not detected,
click on add printer
select local port
select usb port click next
if printer is not listed-> click on brows give path of cd or driver folder
if drivers are correct, your printer will be listed
install it.
set it defualt and give test page print.
Posted on Mar 11, 2011
Canon MP830 geting error 6500
The error indicates a service error code with your printer, typically caused due to internal error in one of the ASIC chips on the logic board of your printer, and may only be repaired by replacing the logic board at an authorized Canon service center, and should be done for free if your printer is still under warranty.
Jul 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
ERROR 6500 ON MY CANON PIXMA IX4000
The orange and green lights should be flashing 20 times. If this is so then i am afraid the main logic board has failed. The only remedy is to replace the logic board. Srri
Jun 02, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
I have a Canon MX300 which has been bought 2nd-hand. There are new Canon original inks installed. When I switch on there is brief activity then power and error lights flash alternately. The display panel...
Is verry bad,the printer have logic board defect....you need to replace the logic board.I look in the service manual and 9000 error means to replace the logic board.If i have been useful please give me a vote :).Thanks
Apr 04, 2011 | Canon MX300 Office All-In-One Printer
6300 error code
Alarm LED lit
RAM error [6300] The RAM error occurred in the RAM check at hard-power-on.
Its a hardware error. In most case the logic board assembly is failed or an internal error of one of the ASIC chips on the logic board and can be repaired by replacing the logic board at the Canon Service Center.
Feb 18, 2011 | Canon PIXMA MP830 All-In-One InkJet...
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP830 error 6500
Error 6500 is a logic board error code (= 'other hardware error').
Before committing to replacing a logic board, ensure that the error has not been generated and held by spurious external signals. Reseat the ink cartridges. Remove any memory card(s). Check any flaps / covers are properly closed (eg. CD printing cover). Turn off the printer and disconnect the power lead and USB lead to the computer. Leave the printer disconnected from power and data signals for several minutes, allowing time for any static electrical signals present on the logic board to discharge.
Reconnect printer and test.
Feb 25, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Error code 6500
Error 6500 is a hardware error.In most case the logic board assembly is failed or an internal error of one of the ASIC chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
Please rate your response.
Thanks, SF
Feb 18, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp460 not recognising replaced ink cartridge and cannot get rid of alarm code
hi guys,
BTW, did you refill the cartridge?. First, try to press START button (Black or Colour). Perform this procedure for each cartridge. If the problem still persist there some possibilities: cartridge error, carriage part or logic board is faulty. Then you need to replace faulty part.
Regards
Source:
Canon Inkjet Forum
Dec 07, 2008 | Canon PIXMA MP460 All-In-One InkJet...
CD/DVD Print tray does not work - apparently bad logic board
No, Canon only sell through supported dealers. If it does work and sometimes stops working, it could be cd tray is dirty or the disc are too shinny calls the sensor to reflect back to the tray. some cheaper disc do not work as they are not matte white.
Oct 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
My canon mp830
Error code 5200 means the print head temperature is too high. The only was to resolve this error is either replace the print head or replace the logic board. The print head is available, part number QY6-0061 but you will struggle to find a logic board. The only other thing you can try is resetting the EEPROM on the logic board, this sometimes clears the error. A service manual will show you how to do this: http://www.tradebit.com/filedetail.php/4546483-canon-pixma-mp830-printer-service-manual
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
234 people viewed this question
Seeker5211
Seeker5211
