Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Same problem, smartmix won't engage
Please,please tell me how you solved your problem
    President:
  • 1,673 Answers
If you have had the top off, the piston goes on the bottom of the smart mix valve and should be in the water position when you reinstall the top.
Posted on Aug 10, 2008
It won't spray water out of the floor cleaner but it will out of the upholstery cleaner.
If your machine is spraying through the hose but not to the floor, check to ensure the spray tips at the base near the brush roller are clear. Using a pin or safety pin, **** the spray tips or use a cloth to clean.
You can also try these troubleshooting tips:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
If these suggestions do not solve the problem, please have a technician at a local BISSELL Authorized Service Center inspect your machine. BISSELL supports your machine with a one-year warranty for any defective or malfunctioning part.
To locate your nearest BISSELL Authorized Service Center, please go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
You can also locate a Service Center by phone, 24 hours a day, by calling 1-800-237-7691 and choosing option #1.
Apr 20, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
Wont discharge shampoo!
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
Nov 23, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
WATER WILL NOT COME OUT
Nov 22, 2010 | Bissell 7901-R Clearview Proheat Plus...
My bissell wont release water or cleaner
Nov 05, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
My bissell isnt putting down any solution or water
Oct 28, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My machine is not putting out water or sucking anything up
Please try these suggestions to get your machine working properly:
Sep 26, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
It wont spray the water on the floor.what do i do
Try these suggestions to get your machine working properly:
Aug 05, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I have Bissell 7920. The water is not being
Jul 14, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Does not spray the water and cleaning solution
If these suggestions do not solve the problem, have a technician at a local BISSELL Authorized Service Center inspect your machine.
To locate your nearest BISSELL Authorized Service Center, go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
Jun 17, 2010 | Bissell 1699 ProHeat Clear View Upright...
Sprayer not working
If these suggestions do not solve the problem, contact a technician at a local BISSELL Authorized Service Center inspect your machine.
Jun 15, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
121 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
