Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore Dishwasher No Power Model 665-16769000
I have a Kenmore Dishwasher 665-16769000. We have replaced the circuit board 3 months ago and last night replace the touch pad. Since it had been sitting for 2 weeks I ran it empty. Today the dishwas will not start - - no lights nothing. Can you tell me what is the problem this time?
  • BStapp1021 Aug 10, 2008
    Just replaced the circuit board again as a service tech explained that the board and the pad have to be replace same time. Dishwasher is still dead!
5 Suggested Answers
mattozan
  • 555 Answers
SOURCE: My Kenmore Dishwasher Model #16769000
Try unplugging and replugging to reset (or, if the plug is too difficult to reach, reset the breaker)
Posted on Jul 07, 2008
  • 117 Answers
SOURCE: dishwasher not filling
Yes you should have 120v to the valve so the problem is elsewhere. Possibly the control isn't sending the proper voltage but you will need a tech to verify as this board is about $130
http://tclaundryrepair.com/
Posted on Feb 20, 2009
  • 20 Answers
SOURCE: how much voltage should go to the fill solenoid?
most times it120v look at the wiring diagrams
  • 864 Answers
SOURCE: dishwasher only a couple of months old. Ran it
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Posted on Aug 25, 2009
SOURCE: Kenmore Elite dishwasher model 665 touchpad buttons falling off
WE HAVE THE SAME PROBLEM. DID YOU FIND A FIX FOR YOURS?
Posted on Mar 27, 2010
Dishwasher does not start
I had this problem and solved it by merely switching the associated circuit breaker off and on again. Something of a "hard reboot." Annoying ... and ... if it happens repeatedly (tonight was the first time), someting I will pursue fixing while hte d/w is still under warrwentey (It was purchased/installed less than three months ago.)
Dec 12, 2012 | Kenmore 18" Built-In Dishwasher -...
Had a Samsung DMT800RHS dishwasher installed by Sears 2 weeks ago. Used it approx. 4 times. Worked well. Today it doesn't turn on. None of the "touch-type" buttons on the console work. Home...
Hi. We have the same problem. Dishwasher was installed about 3 months ago. There is an easy 'temporary' fix.
Completely turn off the dishwasher by flipping the circuit breaker to the off position. Wait a couple of seconds, and flip the circuit breaker back to the on position.
The dishwasher console must be getting into a bad state and not sensing the console panel buttons. The circuitry in the dishwasher is never really "off" as some amount of power has to be "on" to be ready to sense the touch panel. Turning the circuit breaker off and back on likely resets all the functions and makes the unit operable. We have been operating the dishwasher this way for about a month now. Luckily for us, the circuit panel is 3 steps away from the dishwasher...but this is getting old.
Hopefully this solves your problem ... reply back here one way or another...if this turns out to be a common problem & solution,it will give me more faith that Samsung will be convinced of a problem when I call them after the holidays.
Dec 21, 2010 | Samsung Dishwashers
Kenmore Dishwasher Model 665.11643300 Cycle will not run. Normal Wash light blinking Cancel light will also blink (but can be cancelled by holding button down) I tried shutting down the power and...
I will look a bit further in detail about your dishwasher problem. I am assuming you have checked the inlet water tap to the dishwasher is turned on.
Sep 14, 2010 | Dishwashers
On off switch won't stay depressed on AEG dishwasher
Took unit apart and when I put it back it worked again. For how long who knows.
Access to the switch is difficult but by removing the printed circuit board, it seemed to allow the switch to work.
Dec 27, 2009 | AEG 24 in. Favorit 40850 Free-standing...
Freezer side stops defrosting.
has the defrost timer been replaced? if not, that'd be the next step. there are only a few parts in that line: the power, the sensor, the timer, and the heating element. also, if the condesate drain is plugged, water stays pooled under the coils and freezes again.
Aug 27, 2009 | Refrigerators
Kenmore dishwasher no power
Check the following areas for faults.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer or control board
Replace if defective (note: uncommon problem).
4. Selector switch
Jun 14, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Lights blink, wont wash
almost certainly its the board again. If you do decide to replace it again, suggest you install a surge plug on your power cord. Does wonders when you have power fluctuations.
May 09, 2009 | Maytag 24 in. MDB7601A Free-Standing...
Kenmore Elite 17483 Dishwasher Caught Fire!
Had the exact same problem (Control panel burning up, sparking, and smoking during wash cycle) last night with our Kenmore Elite DW model 665.16293400 purchased Nov. 2004. I have reported it to the CPSC and www.kitchenaidfire.com and will be contacting Sears first thing tomorrow. It is outrageous that this problem is apparently so widespread with nothing being done about it! I have no doubt my kitchen would have been in flames if I had not been sitting right here to shut off power to the D/W.
Feb 04, 2009 | Kenmore 24 in. 17483 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
261 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
