Question about Cell Phones
I want to know what are the Dns( &2 - Cell Phones
  • 302 Answers
Short for Domain Name System (or Service or Server), an Internet service that translates domain names into IP addresses. Because domain names are alphabetic, they're easier to remember. The Internet however, is really based on IP addresses. Every time you use a domain name, therefore, a DNS service must translate the name into the corresponding IP address. For example, the domain name www.example.com might translate to 198.105.232.4. The DNS system is, in fact, its own network. If one DNS server doesn't know how to translate a particular domain name, it asks another one, and so on, until the correct IP address is returned.
Source: http://www.webopedia.com/TERM/D/DNS.html
Posted on Mar 11, 2011
F4i honda 2001 light is flashing 7 times on diagnostic code {fi light} then staying on does anybody know what 7 blinks mean
7 = Coolant Temp sensor or wiring.
A long blink = "10"
A short blink = "1"
DNS = Engine does not start
EON = Engine operates normally
BLINKS : PROBLEM, SYMPTOMS
No blinks: ECM malfunction, DNS
No blinks: ECM power / ground circuit malfunction, DNS
No blinks: ECM output line malfunction, DNS
No blinks: MIL circuit malfunction, EON
Stays lit: Data link circuit malfunction, EON
1 blink: MAP sensor circuit malfunction, EON
2 blinks: MAP sensor performance problem, EON
7 blinks: ECT sensor circuit malfunction, Hard start at low temp
8 blinks: TP sensor circuit malfunction, Poor performance on quick throttle operation
9 blinks: IAT sensor circuit malfunction, EON
11 blinks: Vehicle speed sensor circuit malfunction, EON
12 blinks: No. 1 Primary injector malfunction, DNS
13 blinks: No. 2 Primary injector malfunction, DNS
14 blinks: No. 3 Primary injector malfunction, DNS
15 blinks: No. 4 Primary injector malfunction, DNS
16 blinks: No. 1 Secondary injector malfunction, DNS
17 blinks: No. 2 Secondary injector malfunction, DNS
18 blinks: Cam pulse generator, no signal, DNS
19 blinks: Ignition pulse generator, no signal, DNS
21 blinks: No. 1 O2 sensor circuit malfunction (California only) , EON
22 blinks: No. 2 O2 sensor circuit malfunction (California only), EON
23 blinks: No. 1 O2 sensor heater malfunction (California only), EON
24 blinks: No. 2 O2 sensor heater malfunction (California only), EON
33 blinks: E2-PROM in ECM malfunction, EON
48 blinks: No. 3 Secondary injector malfunction, DNS
49 blinks: No. 4 Secondary injector malfunction , DNS
Aug 30, 2014 | 2001 Honda CBR 600 F(4)i
Tip
Server 2003 & client configuration
<p><span>Some days before I have done a job on Windows Server 2003 Enterprise edition & Client XP. It is departmental food court. In the office room of the restaurant have a system which will be Server system and main domain. There was another 8 system in every department of food <span> </span>with printer for billing.I</SPAN><br> <p><span>Windows Server 2003 includes a mission critical Windows Server operating system, such as security, reliability, availability, and scalability.</SPAN><br> <p><span>You have to install DNS server for DC without DNS the client computers wouldn't know which one is DC.You can host DNS on a different server than DC.</SPAN><br> <p><span>Before Starting the DC installation process you need to make sure the <span> </SPAN>following points</SPAN><br> <p><span> </SPAN><br> <p><span>1)You have installed Basic windows server 2003 installation</SPAN><br> <p><span>2)Make sure you have assigned a static ip address to your server</SPAN><br> <p><span><span> </SPAN>Now start DC and DNS Setup process</SPAN><span></SPAN><br> <a><span> </SPAN></A> <span><span>Domain Controller</SPAN></SPAN><span></SPAN> <span>Active Directory is a huge topic in itself. While DCPROMO is easy to run, planning of both the physical and the logical structure is the key to a trouble free active directory. </SPAN> <p><span>Domain controllers do not have to be your most powerful machines, however they must be reliable and always available to answer logon requests. </SPAN><br> <a><span>DNS (Domain Name System)</SPAN></A><span><span> </SPAN></SPAN><span>Role</SPAN> <p><span>Once DNS is setup, it runs itself thanks to the new dynamic component hence DDNS. TCP/IP knowledge plus understanding of how DNS works is essential when troubleshooting connectivity problems.</SPAN><br> <p><span>DNS enables client machines to resolve servers IP addresses. Once the client finds the server, Active Directory uses LDAP to locate services like Kerberos, Global Catalog that clients request.</SPAN><br> <a><span>Print Server Role</SPAN></A><span></SPAN> <p><span>In my experience there is a contrast between the software settings which are easy to configure and the hardware which constantly need for attention e.g. paper jam, 'out of toner'. Check list for print server:</SPAN><br> <p><span></SPAN> <br> <p><span>Printer Priority</SPAN><br> <p><span>Network Printers</SPAN><br> <p><span></SPAN><br> <p><b><span>Client Configuration :- </SPAN></B><span>After</SPAN><span><span> Installation of Windows Xp give the IP Add on TCP/IP of IPV4.If you want to manually configure DNS server addresses, click</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Use the following DNS server addresses</SPAN></b><span><b><span>,</SPAN></B></SPAN><span><span> and then type the preferred DNS server and alternate DNS server IP addresses in the</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Preferred DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>and</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Alternate DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>boxes. After all job try to ping each other. I'm trying this and it also pinging. Files and data also can be shared through it.</SPAN></SPAN>
on Feb 15, 2011 | Computers & Internet
NOT RESPONDING TO INTERNET
Let's try setting a static DNS server and see if that takes care of it:
1. Click on Start, choose Run, type in ncpa.cpl and press Enter to open Network connections window.
2. In the Network Connections window right click on Local Area Connection and then select properties.
3. Click Internet Protocol (TCP/IP) and then the Properties button in Local Area Connection Properties.
4. Choose Use the following DNS server addresses: and type in 4.2.2.1 for your Primary DNS (you can leave the Alternate DNS blank).
5. Choose OK/Close to the windows and test Internet Explorer
Let me know if that helps
Thanks & Regards
Anas K A
Apr 25, 2011 | Computers & Internet
I brought Samsun Wave GT-S8500 it failed to connect internet through 3g & even i tried to connect office accespoint it was connected in browser it was showing the dns failed Please help me what to do
Seems it's a bug from Wave but alternatively you can try to change your DNS.
1.  Temporarily urn off Wi-Fi on your phone
2.  Go to Settings --> Connectivity --> Wi-Fi and tap on your WLAN's name.
3.  Tap IP Address Type box
4.  Set DNS  8.8.8.8 (google's public DNS)
Feb 08, 2011 | Samsung Wave S8500 Smartphone
DNS failure youtube in mobile
dear friend,
i have also the same mobile & i also got the same problem but i fixed it.....dns is generally in hands of the service povider so call the customer care they will fix it other do comment & vote for the proxy dns....
enjoy & cheers
Jan 18, 2011 | Samsung Star GT-S5233 Cell Phone
I want to get my youtube unblocked at work. do you know a site thats works?
This depends on how your IT dept has blocked access (there are many ways of blocking site/content/IP access). Try the below (I am assuming you are using Windows XP as your OS)
(all of these when you are at work, not sure if you are using a desktop or laptop)
1. Open command prompt and check ipconfig /all (note down the IP for your DNS servers; you should have at least 1 if not two. Make sure you note down the first IP)2. Go to network connections (from Control Panel), if you are using LAN (using an ethernet cable) then go to Local Area Connection properties or if you are using Wireless then go to Wireless Network Connection properties3. Under general tab, select Internet Protocol (TCP/IP) & click on properties4. Under general tab, below you'll find an option 'use the below DNS server address' - select this option5. Under preffered DNS server add 4.2.2.26. Under Alternate DNS server add the IP address you noted in step #17. Restart your system and try using Youtube
Hope this helps. Sorry, if the steps were too detailed out.
Oct 07, 2010 | Computers & Internet
I bought an ethernet cable for the ps3 & evry time i would try to sign in 2 playstation network it would come up wit this: ''an error occured during communication with the server.This is a DNS...
The remedy is quite simple actually for any router. Two things need to be known & with them, you need to enter that information below, into the PS3 configuration. 1) Your SSID of the Router The name of the network. 2) WEP must be 'enabled' and the WEP key entered.
If you don't know or remember set the router all up again and take note this time of SSID & WEP key.
Feb 27, 2010 | Video Game Consoles & Games
It says that my computer is connected to network and internet but it my computer cant browse in the internet
Likely a DNS problem.
1. Check to see if your router is set to obtain DNs as dynamic or static (probably dynamic). Verify the listed primary & secondary DNS servers are correct for your ISP.
2. Check router to see if it acts as DHCP server for your network to assign ip numbers to clients. If so, then verify your computer as dynamic, otherwise set static ip in the same subnet.
3. Verify gateway assignments.
May 16, 2009 | Computers & Internet
Cell Phones Logo
216 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
