Question about Panasonic Lumix DMC-TZ1 Digital Camera
Touching the zoom lever the barrel will come out fully and retract immediately with the message at the display "Please turn camera off and then on again" Done that the same occures over again.
    Novelist:
  • 147 Answers
This is probably due to a lens error.
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Posted on Mar 12, 2011
The camera will not turn off and the lens is not fully retracted
from your question I understand there may be problems in the lens unit, in some cases totally open the lens unit fully re assemble it again,clean the sensors at side of the barrels, can override this snags.
the below picture is not the same, but similarly you take the cam sect out and reassemble it.
Mar 20, 2016 | Sony Cyber-shot DSC-H300 Digita Camera -...
My canon ixus 75 is not turning on properly the zoom lense is stuck out and wont retract. When i turn it on it says "lens error reset camera&quot
OK, assuming the batteries are ok, the problem is within the mechanism for the lens being too 'binding' while it operates.
Sometimes, people put their finger on the barrel of the lens when it retracts or extends.
If you reset the camera and it still does this, the camera needs to be serviced by Canon.
http://www.usa.canon.com/cusa/online_repair_tracking/consumer/digital_cameras/powershot_sd_series/powershot_sd500?pageKeyCode=requestRepair
Jun 28, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
My dsc hsx-1 zoom lens wont retract from max.
my cam z sony DSC HX1..the problem z when i zoom in(max) the objct i m zoomin doesnt get focusd....when i shoot it the pic z totally blurrd....no matter how mch i try 2 focus with the manual focus option the outcum z da same....
Nov 27, 2009 | Sony Cyber-shot DSC-HX1 Digital Camera
My fujifilm E550 digital camera has a problem where the cilyndrical piece in front that usually moves in/out is stuck half way (won't go back inside) and the camera will not take pictures. The camera is...
You may need to use some light "force" to manipulate the lens barrel into its proper orientation. Try a combination of turning it on and helping the barrel to rotate one way or the other. Also try a little manipulation when the camera is shut off, to get the lens to retract properly. This is a fairly common issue with the E series cameras. If you are uncomfortable with the amount of force you should use, run it into any competant photo store. They've probably run into the same issue before. Good luck.
Oct 07, 2008 | Cameras
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
May 27, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Zoom will not retract
Dear Grammie,
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
Sincerely,
HeavyDLB
May 22, 2008 | Canon PowerShot A540 Digital Camera
Lens barrell doesn't retract for zooming out, only for shutting off.
Hello, Sounds like you have a drive motor/gear assembly malfunction,this type of failure is costly to repair.
Best Regards, Russell
Oct 29, 2007 | Kodak EasyShare DX6490 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
98 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
