Question about Microsoft Wireless Optical Mouse USB Receiver 1010104281
Screensaver is not working after installing the desktop receiver
    Problem Solver:
  • 16 Answers
Go to this web site and get your Manual
http://office.manualsonline.com/
Posted on Mar 13, 2011
How do i save screensaver images to my power acoustik PTID-7002NR
You need to upload then via USB. You should have a cable that came with your unit
Nov 04, 2009 | Car Audio & Video
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Monitor picture turns on its side when it goes to screensaver
Sounds like your screensaver is using a picture of your desktop in it's code intentionally.
Right click on a blank area of your desktop --> select properties
--> click screensaver --> change it to "none" or another screensaver
Jan 17, 2009 | CTX S762A 17" LCD Monitor
Hi, my screensaver acer aspire one doesn't work. can you help ?
To set up your screensaver, right click on your desktop and choose Properties. Choose the Screen Saver tab. In the drop down menu for Screen saver, make sure something is selected instead of (None). Next click the Preview and it will give you a glimpse of what the screensaver you chose will look like. Move the mouse to get out of it and select apply if you like that one or choose a different one.
Jan 14, 2009 | Acer Aspire One PC Notebook
Screensaver want work
Go to:
Start >> Control Panel >> Display >> Select the tab ...Screensaver
Modify the settings of your screensaver there and also (enable - disable)
Oct 27, 2008 | Gateway Computers & Internet
Report ACER(N~1.SCR has stopped working, how can I repair
it's your screensaver, scr is screensaver (and acer scr is a screensaver from aces) so just change ur screensaver to a windows one and then it will work again :D i don't know why the acer screensavers don't work... if u really want them to work you may want to search their website :D
Sep 23, 2008 | Computers & Internet
Error Tab
Turn off the, or better yet uninstall, the Acer Screensaver. Something you installed, possibly a screensaver program? has corrupted the Acer screensaver causing that error message. That add-on screensaver is notoriously buggy anyway.
James Smith
A+ NET+ Server+ M.C.S.E. CCNA
Sep 09, 2008 | Acer Aspire™ T180 PC Desktop
Cannot locate a download button for screensaver
Do you have a screensaver you are trying to use or are you trying to download it from someplace?
Jun 27, 2008 | Computers & Internet
I can't get my screen saver to apply
easiest would be to right click on the desktop and goto properties and then screensaver tab...by default the apply tab is grayed out. You need to select a screen saver from the dropdown and your apply button will become active
Mar 05, 2008 | Acer Aspire™ T180 PC Desktop
Microsoft Wireless Optical Mouse USB Receiver 1010104281 Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
