Question about Refrigerators
We have an LG GR267EHF Double door refrigerator. We recently relocated to Australia and the side of the fridge incurred two dents in transit. The approx size of the dents is 4cm x 4cm. The egg box tray original supplied with this model is also broken. We would like a quotation for: 1) Repair of the two dents 2) Replacement cost of the egg box
  • 11,800 Answers
1) That depends entirely on who is going to do the repairs and exactly how much work is necessary.
But for simple dents that can be filled with car body putty it's a one hour job so the final price will be around $150. But you can do it yourself, it's not a complicated job, see here
http://www.youtube.com/watch?v=ymnTUoC32Os
2) the only online source that had it mentioned was out of stock. There it was priced at 2,02 pounds + shipping. Your only hope of finding a new one is at a local dealer - expect to pay about $15.
Posted on Mar 11, 2011
How do I repair a dent in the door of my stainless steel refrigerator?
if the dent is not creased; use a suctioncup dent puller availlible at any autoparts store
Feb 04, 2013 | LG LFX25960ST Stainless Steel French Door...
I Have A side by side LG Black fridge> Dents on door can it be repaired
Yes,u should be able to contact LG and purchase new panels for the doors
Mar 31, 2011 | LG LSC27950 Side by Side Refrigerator
I have a double door refrigerator, the top side is not working, only the freezer side wich is working.
It may be your compressor. There has been a lot of complaints about this fridge. If the vents are blocked, it won't cool. The fridge has been the one that always goes out, mainly because the compressor. You will have to get someone out to fix it. Hopefully, your warranty is still good.
Feb 18, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice auger/feeder will not work. Makes ice, dispenses water just fine. when lever is pushed the flap opens and a valve pops out, but no motor action. Checked for wire damage and loose plug from the door to...
First and foremost double check your wire connections at the top of the door to make sure one of the wires did not slip out of the plastic connector (if you removed the doors to move it).
You may have a frozen auger motor. This is located behind the ice bucket and has a steel "u" shaped part that connects to the front of it to drive the bucket. The entire assembly that it mounts to is usually held in with four screws and one wire jack. you can remove the entire assembly and let it sit to dry or even heat it with a hair dryer (carefully to avoid melting any plastic). Be sure it is thoroughly dry before re-installing it.
Jun 11, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How do i get a dent 2 by 4 out of the fridge. there really isnt any scratchs but just a dent. can i some how get it out with out having to replace the hole stainless steel door
there arent any real solutions outside of some auto body repair shops have a suction cup dent puller that might help. most of these doors have a molded foam isulation inside that prevents you from getting to the inside of the door panel to push a dent out. even if you could it would be a rough job . you would have to remove the inner door liner including lots of screws, if the inner door liner isnt molded to the outer door panel. so unless you know someone that works in a body shop, the only real option is to replace the panel, which wont be cheap and i would suggest having a tech install it because if you damage it while installing it, that would be on you and the parts company probably wouldnt replace it for free. Good luck!
Dec 17, 2009 | LG LSC27950 Side by Side Refrigerator
Dents in fridge door
Contact an automotive "paintless dent removal" provider-- they are mobile, so they can come to your home.
Jul 09, 2009 | LG LSC27950 Side by Side Refrigerator
Fridge door dented
no - door is in two parts - inner and outer with foam between
Sep 25, 2008 | Frigidaire FRS23R4A Side by Side...
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
