Question about Pioneer Televison & Video
Hi.. please help i have a pioneer hard drive dvr-520H. i love it and have never had any problems over the years. but just yesterday it froze up on me when i was trying to watch a recorded show. now when i turn it on it takes ages to show what channel i'm on. then when i go to disk nagivator to see my show that i have recorded it shows up as black little screens with circle arrows on it.. does this mean it's time for a new machine or can you help me get it back.
    Brigadier General:
  • 8,909 Answers
That sounds to me like the hard drive has crashed and it can't find the required "hand shake" from the drive, hence taking such a long time to initialise and then showing rubbish. Unfortunately fitting a new hard drive to most of these machines requires matching hardware to firmware and that is achieved with the use of a "Service Remote". So fitting a replacement drive may not fix it without matching the new drive with the special remote.
If you have a Pioneer Dealer in your area, get them to estimate the repair and weigh it against the cost of a replacement.
Hope that helps.
Posted on Mar 11, 2011
Power supply unit failure
It could be the IC101 (MR2920) and the zener D104 both failed, or IC1 (MD5001T) failed as well, here is the link where I've descrived how I fix the issue on my DVR-520H, it is in italian but you can translate it with Google: http://www.plcforum.it/f/topic/181344-riparazione-guasto-alimentatore-pioneer-dvr-520h-dvr-520h-failure/
Feb 08, 2013 | Pioneer DVR-520H DVD Recorder
Looking for a manual free of charge for DVR-520 H. Where to find?
Hello
Get into this site where you can get its user manual for free download. If you fail to do it, either send your email address by fixya of send a mail to me at gopakumarg43@ymail.com. I've the manual in pdf format, and will send it to you by return mail. OK.
www.pioneerelectronics.com/.../Manuals/ci.OPERATING+INSTRUCTIONS+ DVR-520H.Protected - United States
Ok.
May 18, 2011 | Pioneer DVR-520H DVD Recorder
Hi.. please help i have a pioneer hard drive dvr-520H. i love it and have never had any problems over the years. but just yesterday it froze up on me when i was trying to watch a recorded show. now when i...
Those circles are there as a sign that the unit has not finished loading the indicator - it's a wait signal. This happens because the processor no longer recognizes the indicator for the shows you recorded so yes, this is a big defect.
The unit is repairable - you will have to replace the hard drive and reprogram the unit - but this is a long and costly procedure. It will be cheaper just to buy a new one.
Mar 11, 2011 | Pioneer DVR-520H DVD Recorder
My Pioneer DVR-520H DVD Player works fine but sometimes when it is powered off the power just goes completely. When this happens I plug it into a different socket or just pull out the power cable from the...
It seems problem with power supply board in Pioneer DVR-520H, possible causes for that symptoms are few dried up/ leaky capacitors, cold/ dry solder joints on circuit board or chip resistors would be devalued.
Local repair shop will help you to replace bad capacitors, chip resistors in power supply board to solve this issue if you are not familiar with soldering work in circuit board.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 11, 2011 | Televison & Video
CANNOT ACCESS HARD DRIVE AFTER DVD DRIVE REPLACED
Hello Aom1908, check your wiring and drive jumper setting.
  1. If you are using IDE, check loose IDE cable, of the DVD drive and the Hard Drive. motherboard connection included.
  2. Check also the jumper at the back of the drive, one should be master and one should be slave. I prefer the hard drive master and the DVD drive slave.
  3. Check also the power connector for loose connection.
Thats all. keep me posted.
Mar 22, 2010 | Pioneer DVR-520H DVD Recorder
No power
Something inside is loose, so it's time to buy a flat panel tv or spend $50 to get it repaired.
Oct 17, 2008 | Pioneer DVR-520H DVD Recorder
DVD shelf won't open
You know you can place a paperclip in the hole next to the DVD drive to release the door. Never just pull on the tray when it is all the way closed. Once the door is part way open you can gently pull it out the rest of the way. This will not fix anything, it just allows you to open the tray once.
Jul 17, 2008 | Pioneer DVR-520H DVD Recorder
Pioneer DVR-520H DVD Recorder Picture is Yellow
If running component or RGB try replacement lead set. Otherwise is TV issue.
Oct 12, 2007 | Pioneer DVR-520H DVD Recorder
Pioneer DVD Recorder - can get picture but no sound
If you are using RCA cables, you need to hook up three cables (1) yellow video, (2) white - left audio, (3) red - right audio.
May 28, 2007 | Pioneer DVR-520H DVD Recorder
Loses power after timer recording
Hi Saturn et al,
I had similar issues with my Pioneer DVR-520H. It completely went off for quite a while when it should be going to standby after a timer session. At the start it would come good after a few days. Eventually it went off altogether and nothing would bring it back.
With my father-in-law being an electronics person we investigated with the help of the service manual which I found on the net. The finger was duly pointed at the power IC (MR2920) on the power supply board (Pioneer will sell only the complete board). I ordered the IC from the UK (nikko-electronics.co.uk) GBP8.99 which was the only place I could find it online and soldered it in myself (easy, if you can solder).
All fixed and working again.
Hope this helps.
Apr 25, 2007 | Pioneer DVR-520H DVD Recorder
Televison & Video Logo
142 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
