Question about Hobart Handler 210 Wire Feed MIG Welder
Hello, I would like to purchase 3035 spool gun and attach it to my self made welder. Could somebody to tell me which power supply I have to provide for spool gun motor? DC voltage, amperage ? Can I use PWM regulated power supply for spool gun engine ? Thanks to all.
    President:
  • 1,702 Answers
The spool gun is a 12volt motor, i usely hook it to the power feed for the feed motor in the welder. it is also 12 volt . i have heard of some welders that have 110 volt feed motors but have not seen one yet but just to be save i would test the power feed to the feed motor before i made the connection.
Posted on Mar 11, 2011
Testimonial: "thanks a lot. "
  • sga_m Mar 11, 2011
    It very good info, because my welder already has internal 18 volt source. It is no problem to make lower voltage by PWM by one transistor.
    Thanks a lot
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    I hav a silver beauty 90200 mig welder and suddenly no power through whip to the gun.any suggestions that I may try to trouble shoot problem?
    There is an inline fuse with the power feed to the gun, it may be blown. It is usually under the panel that exposes your connections for the gun/ wire spool.
    Jan 17, 2012 | Lincoln Welding Tools
    Is there a connection for gas to mig weld on a Clarke 6440 flux welder
    No. Not with the spool up on the gun. It is one of the few flux core specific welders.
    This is not to say you could not try. the hard part is the plumbing between the gun and the main box. If you can get that figured out it would otherwise be the same components as other MIG welders.
    Jan 08, 2012 | Clarke Power Products Welding Tools
    I have a Migmatic 200 Canox (millar)ser# kb060228 and would like to purchace a spool gun to use with it . There is a 14 pin remote feeder plug on th front. Is there a spool gun available for it, or do I...
    They make a spool gun for it, it has a round 7 pin connector like an RV trailer with braking would use.
    If yours is truly a 14 pin, you can use your schematic and the one for the spool gun made for your machine to rewire it to work for you.
    this is the manual for the gun that made for your welder:
    http://www.millerwelds.com/om/o250884a_mln.pdf
    Jan 07, 2012 | Welding Tools
    I own a Lincoln 305gas powered welder I recently purchased a Lincoln 25M suitcase and wanted to know if the two were compatible before I tried them together and if I can weld aluminum with them hooked up
    Hi:
    Yes your 25M feeder will work perfectly with ANY engine drive welder. Regarding the aluminum welding that's a no, sorry but suitcase feeder and gun are specialty made for mild and SS welding. For the aluminum you will require a spool gun and N adapter for your engine drive. Check you onwer's manual for more details.
    If this was useful to you, please vote. Thanks.
    Mar 27, 2011 | Lincoln Welding Tools
    What mig welder would you I buy to restore a old car.
    I always tell my customers that the best machine for a body shop is a millermatic 212 if you have 220V available if not, go to a Millermatic 211 this is one is a dual voltage unit 110V/220V. if you can afford it buy a spool gun SG100 for all aluminum parts, the machine will cost you 999.00 and the spool gun 215.00. Best investment ever for your shop.
    Oct 28, 2010 | Clarke Power Products Clarke 130EN Mig 110...
    Spool gun not working
    Was it working before?? If so check switch on gun/relay in welder and connections. If not it is not connected properly/bad relay/ gun switch/ or bad spool gun.
    Mar 16, 2009 | Welding Tools
    Need wiring schematic for miller 140 wire feed welder
    No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
    Dec 27, 2008 | Miller matic 140 Mig Welding Package W/As...
    Hobart Handler 210 Wire Feed MIG Welder Logo
    202 people viewed this question
    Top Hobart Welding Tools Experts
    Matt Olenzek
    Matt Olenzek
    Troy
    Troy
    Level 1 Expert
    Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
