Question about Karcher 2500 PSI Pressure Washer
Honda power washer probs...
I am having a problem with the pull starter. It seems to be locked. I get nothing when I pull. Anything I can do??
  • marinephotog Jan 10, 2009
    Honda Power Washer engine seized. Is it salvegable?
  • Anonymous Feb 09, 2009
    what if i can turn it like 12 to 9 and then it stops
    Problem Solver:
  • 18 Answers
Theres a possibility that the engine is seized !! try taking the pullcord casing off and turning by hand. If it don't turn it's broke - for good!!
Posted on Sep 19, 2008
Problems with recoil starter
The recoil starter needs to be repaired. It is a common failure item.
Apr 27, 2014 | Craftsman 3000 PSI 27 GPM Briggs ...
I have a 2003 Honda accord that will not start! Tried to jump battery..all fans and belts were running however car would not turn over...bought a new battery and replaced with old now my car want do a
I have seen issues like this on other Honda's and the problem turned out to be the ignition starter switch. Do this, jumper power directly to the starter solenoid trigger wire and see if the engine cranks.
Jun 30, 2017 | 2003 Honda Accord
1990 HONDA ACCORD WON'T TURN OVER TO START BUT IT WILL ROLL START. I HAVE CHANGED THE ALTERNATOR AND TESTED THE IGNITION SWITCH STARTER RELAY SEEMS FINE CLUTCH SWITCH SEEMS FINE MAIN RELAY IS FINE
About the only thing you didn't mention was the starter itself. You could have it tested. But before that, try to see if you have power on the small wire to starter solenoid on the starter, when key is held in cranking position. Pull the small wire off and check for power with a multimeter or a testlight while someone holds the key in crank. This is the signal wire from ignition switch that closes the elec. contacts inside solenoid so the starter gets full power from the battery to spin. (This wire also is in the circuit with the clutch switch and the starter relay.) If you have power on this wire in crank, it is very likely the starter is bad. If there is no power, check that circuit out. It is losing power somewhere from switch to starter solenoid. Good luck.
Jul 06, 2012 | 1990 Honda Accord
1995 Honda Civic has no electrical power to anything. Battery tested perfect, starter tested perfect, but still no power. Under the hood all fuses have power but nothing inside car has power.... any...
check for damp on floor in car, when you find it pull back the carpet and follow the cable's you should find a few loom connectors, check for green or blueish mould on the copper connectors it will be your problem. replace the loom or cheaper way is to cut out the connectors and replace them with a junk yard special. good luck.
Aug 29, 2010 | 1995 Honda Civic
I tried to start the pressure washer by lulling the cord, there was sharp popping noise, and the engine would not crank to start. It is a Honda K. washer. What went wrong? Pls advise, thanks.
Make sure your oil level is correct and not overfull. If ok, pull the sparkplug out. Then, pull the starter rope to see if the engine spins freely. If it does, pull it 4-5 more times to clear the cylinder of oil or gas. Put the plug back in and try it again.
However, if the rope fails to pull freely, you either have a locked engine or pump. You will have to seperate the pump from the engine to determine which is locked up.
Aug 02, 2010 | Honda Garden
Starter cord wont pull
Try removing your spark plug, you could have fuel on top of the piston or even "vapor lock". If that doesnt work try squeezing the trigger of gun/wand as you pull.
May 31, 2010 | Honda Pressure Washer PSI 3000
Power Washer will not start - pull cord seems to be stuck
hi take out the bolts holding the compleat pull starter remove unit pull the cord if it wont move something is jamming it inside if it is ok then the fault is with the motor //seized or washer remove washer pump if engine turns over /pump seized the fault is 1 of the three you have now found out wich 1 starter, motor or pump it will take too long to go over all 3 get back when you have got this far merlinv12
Aug 22, 2009 | Honda Maxus Pressure Washer MX5222
Motor seems to be locked up!!!!!!!!
It may be your engine, but it may also be the water pressure. Try this: Hold the trigger down while pulling the recoil starter. This acts as an unloader for the pressure washer, and may allow the engine to turn over. There is also an oil level in the pump as well as the engine. Check both levels.
Just a thought, but I've been there. Best regards, W/D
Aug 16, 2009 | Devilbliss DeVILBISS Devap DVH2600...
I have a mah5500b. prob is washer will not start or do anything. it just beeps. tried the diagnostic test. by pressing delicates and heavy soil. led shows 00. when i push other buttons to check functions....
I had a similar problem on my Neptune. All the machine would do is beep. I believed it was a stuck button so I got a new touch pad and that solved the problem. I also substituted a control board prior to buying the touch pad but the problem was the same.
May 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front loader
I would say that you have damaged your door lock. Most appliances have a door lock or a mico switch. this is the first port of call for the power to supply the w/machine.Safety measures??? go back to basics,is the door locking, any power to the going to the electronics. a door. Change faulty components???
Aug 14, 2007 | Maytag Neptune MAH5500B Front Load Washer
Karcher 2500 PSI Pressure Washer Logo
228 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
