19 7/16 . wich is the corrispondent in mm??? - Office Equipment & Supplies
  • 113 Answers
If this is 19 7/16 inches then 19.4375 in equals 493.7125mm (multiply by 25.4)
Posted on Mar 11, 2011
How to connect the raidmax rx-730ss power supply to the gigabyte ga-z97x-gaming 3 (rev.1.0) motherboards 'ATX_12V_2X4' port?
The 2 plugs are seaparte because many mainboards do not have the 8-pin CPU power plug. Use the second 4-pin on the side of the connector.
Aug 02, 2014 | Gigabyte Computers & Internet
What size core holes I need to drill for a 48x220mm marine grade S.S. 316L spigot, to fix with fisv300 or360? The bolt is 16mm thick, but got a 24 mm anchor bolt. Please advise, also wich FISV product to...
i learned long ago from a master , for matching threads an sizes by just eyeing them , hold the 2 together if they mesh they are correct size for the drill size just hole it up to the light with a drill in front.
Jun 26, 2014 | Toys
Diagram of the retracting spring portion of the flywheel of a lawn mower
Rewind recoil spring? jackssmallengines.com but you will need the engine manufacturer and the corrisponding the number you have provided is for the cutting deck wheels etc
Apr 07, 2013 | Yard Machines 158cc Push Lawn Mower #11a...
Canon 2230 copier paper jams on the in feed how do I fix it
Do you mean that you have paper stucked, before drum, in the right lower door ( not big one, but lower in the same height as paper cass )?
when you open that lower right door, there must be an axis with two small rollers of +/- grey colour, use some alcohol or water and clean it verry well.
To prevent more jams, you need to apply pressure on that door.Use some iso tape and fix it on small channal on top, wich will apply pressure on black plastic guide, wich is pressed when the door is closed.Do not over react with tape, about 0,3-0,5 mm would do the job.
If does not help, you can contact me also on emma.servis@gmail.com
Jun 16, 2010 | Canon IMAGERUNNER 2230 Copier
Zoom--mm blinking and can't change mode
Your zoom motor is probably stuck. Remove the two screws on the front side of the tiltable head. Pry off the two tilt caps using a small flat head screwdriver (they are glued on). Remove the 4 screws found under each cap. Now you can separate the two sides of the head and take out the two lenses (remember exactly how the lenses were positioned). Try pushing the flash in or out (it should move with a little force). See if the flash now responds before reassembling.
Mar 21, 2010 | Canon Speedlite 430EX TTL Flash
Rear axel removal 95 crown vic
simple!remove wheels wich ever side remove drums or rotors remove rear pumpkin cover! spin gears til u see an 8 mm pin! remove pin/bolt then slide larger pin out ! k push axl in c clip will fall out remove axl ! to install reverse!
Mar 18, 2010 | 1999 Ford Crown Victoria
Cannot hook up machine to our water supply. Seems to be metric?
have you be to lowe to find the parts you need?It lowes don't have it try auto part stores.Also try to install a water line like you would on a ice maker.
Mar 21, 2009 | Espresso RMI La Cimbali Espresso Machine
23 people viewed this question
k24674
