Question about Wella Blondor Blonde Powder Bleach 28.2oz Multi Bleach
How to mix wallah bleach - Wella Blondor Blonde Powder Bleach 28.2oz Multi Bleach
Can you mix bleach with vinegar to kill mold?
Don't know you can try. It might work.
Good luck
Mai
Feb 07, 2017 | Washing Machines
How to clean
Hello Lisa Rucker - I suggest to first rub some bleach around the door gasket. Let this dry. Next rub some vinegar around the door gasket. Let this dry. (Do NOT mix the bleach and vinegar) Then run a hot empty load of bleach in all three dispensers. Put 1/2 cup of bleach in the detergent dispenser and fill the softener and bleach dispenser to the max fill line with bleach. Once that is done repeat the process with vinegar. Please make sure you run a load of towels or some sort of items that will not matter if you get a little bleach on them once this process is done.
Jan 09, 2013 | Frigidaire ATF6000ES Front Load Washer
How to clean my washing machine Electrolux Front Loader
Hello -
First rub some bleach around the door gasket. Let this dry. Next rub some vinegar around the door gasket. Let this dry. (Do NOT mix the bleach and vinegar) Then run a hot empty load of bleach in all three dispensers. Put 1/2 cup of bleach in the detergent dispenser and fill the softener and bleach dispenser to the max fill line with bleach. Once that is done repeat the process with vinegar. Please make sure you run a load of towels or some sort of items that will not matter if you get a little bleach on them once this process is done.
Sep 21, 2012 | Electrolux EW1000i Front Load Washer
I have purchased a kenmore Front-Loading washer model #796.4044. The instructions state that I can mix some colour safe bleach in with the high efficiency (HE) detergent. Is there such a thing as HE...
This is not a technical answer, but we have the same appliance and have not found any HE Color-Safe bleach. We use the Clorox Color-Safe and just use less-- and mix it with the detergent. I've seen other feedback saying to put it into the bleach tray, but we have not done this-- just put some in with the detergent.
We make sure the entire tray area and inside the rubber rim of the door (under it) and anywhere else there's water is totally dry before closing the tray and door, and we've had no problems at all. We also occasionally run a 'clean' cycle through with regular bleach only.
Hope this helps somewhat at least-- Best of luck!
Jan 20, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Bleach is eating holes in my clothes. With top loaders, the bleach is mixed in with water before clothes are added.. seems that with front loaders the bleach is just being deposited directly onto clothes?
Add your bleach with less potency but make sure you are putting it where it is suppose to go and when you are supose to add it , it makes a difference.
Jan 02, 2011 | Samsung WF337AA Front Load Washer
1999 ford focus estate diesel.Windscreen washer bottle has black mildew in it.how do i get it out as it blocks the washer jets.
Remove the windshield washer reservoir and give it a good cleaning with a mixture of 1 part bleach and 3 parts water. You may be able to clean it without removing the reservoir by flushing it throughly and the cleaning it while still on the vehicle with the bleach mix. After it is throughly cleaned put a bleach mix in the reservoir and disconnect the hoses from the spray nozzles and run the washer until the hoses are clean. Use a needle to clean out the nozzles, and the connect the hoses and run the washer until the nozzles are clear. Remove the bleach mix and then fill the reservoir with a commercial windshield washer fluid. I recommend Rain X.
Mar 07, 2010 | 2000 Ford Focus
How to apply bleach to my washing as there is no space for bleach on the washer
start washer and let it fill up about 1/2 way prior to adding clothes. add bleach and let it fill a little more to mix up, then add clothes
Jun 05, 2009 | Daewoo Washing Machines
Facia panel keeps breaking/bleach ruins clother/water level too low and doesn't clean well
Do not use bleach, if you do you will get a bleaching effect,the new machines use less water, do not volume overload machine. mix the load to prevent uneven out of balance spin and check feet are level. Ragrds Advisor
May 05, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Wella Blondor Blonde Powder Bleach 28.2oz Multi Bleach Logo
57 people viewed this question
Top Wella Health & Beauty Experts
Steve Macqueen
Steve Macqueen
Stan Ford
ray gallant
Are you a Wella Health and Beauty Expert? Answer questions, earn points and help others
