Question about Panasonic Heating & Cooling
Please solve the problem my Panasonic multipoint water heater. Suddenly the light indicator turned off and heater shut off.
2 Suggested Answers
gwyz73
  • 362 Answers
SOURCE: My Panasonic model no. TH-42PZ80U suddenly won't turn on. Power light is blinking 7 times. What does this indicate??
If it's a DLP, then it needs a new bulb.
If LCD or Plasma, then it's probably a bad power board.
Posted on May 19, 2015
My Panasonic Plasma TH37PV7AZ turns on- Searches-Then stays on standby How do I fix this please
does the light indicator blinks?. then after you turn the power on, it suddenly shut down? just let me know first.
Sep 23, 2012 | Panasonic 37" Plasma TV TH-37PV70 + Stand...
I have a Brittony 11 multipoint water heater can I run a Mira mixer shower of it?
Im thast gessing here bt if it says multipoint that means more then 1 water supply so i will say yes it would be fine if u connect ur shower
Bt best solusion here is if u dont wane get a plumber is go to a plumbing hardwere store with a picture of the device and thast ask them. coz i cant say for certen now, went on the internet bt dident find invo on that water heater for u sory. bt in my profession multipoint means more then 1 point .
Jul 16, 2010 | Home
I have a trouble code 11 on my Rinnai model 2532 water heater which indicates no ignition. I checked for gas supply by turning the furnace on which is approx. 1 ft. away, it works. The water heater is...
11 is a ignition failure code. Could be alot of things, I suggest calling a tech who has repaired these before. Pull the front cover off and have a helper turn on a hot water faucet. Look thru the viewing window to see if the unit is firing then going out. If not, clean out the water filter on the inlet side of the plumbing. You will need to turn off the water supply prior to cleaning it. If the unit fires but shuts off seconds after ignition, you may have a dirty or bad sensor. Call a proffessional at this point. Sorry
Oct 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Water not staying hot, i have a Bosh tankless water heater. i noticed that the less water i have comming in the longer the water heater indicator light stays on, resulting in hot water. As i release more...
I installed a tankless heater in my home, I had the same problem, I discovered that the unit was not adequate for the water flow that I needed, I went up to a bigger unit and solved my problems, check to see what the flow rate is recommened for yours
Oct 10, 2009 | Water Heaters
1 unit intermittently shuts off and other won't ignite
if you have the exhaust run together it will not light up,, they have to be seperate,, the computer board sences the unburnt gasses and will not allow it to start,,
Jun 24, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Heating & Cooling Logo
61 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
