How do you empty the waste toner cartridge on a canon iRC3170??
    Sergeant:
    Champion:
  • 212 Answers
Open the dram unit and clean vaste toner cartridge
Posted on Mar 11, 2011
E000013-0000
The Waste toner is full, the copier will not work until you have emptied it or replaced it.
The waste toner is in the front, open front cover and the white bottle in the middle is the waste toner cartridge. Remove the black screw, and empty or replace the cartridge.
If you empty it make sure to clean the see-trough plastic on the top of it so that the sensor sees that it is empty.
Oct 16, 2010 | Canon iRC3100 Printer
Message
the waste toner cartridge/bottle is located on the right rear panel. remove two screws and empty the bottle.
Jul 15, 2010 | Canon imageRUNNER 5020 Copier
CANON CLC3220 COPIER ERROR CODE E0000001-0003
although the waste container is empty still it show 'THE WASTE TONER IS FULL' cleaned the bottle neck of waste container see to it that the 2transparent round hole area is not clouded by toner .this is the sensor path it should be cleaned(remove one screw to remove transparent cap)
Oct 01, 2009 | Canon Office Equipment & Supplies
Remove the waste toner cartridge from a canon imagerunner 6020. I wasn't sure and couldnt get the instructions from the 5570 to work
i think the waste toner bottle is on right side, its on the lower level of right side of the machine there is four screws, unscrew them and empyt the bottle, but u have to clear the waste toner bottle mode after. if this machine the waste toner in the front cover, just open the front cover, left the green handle and pull the waste toner,.the empty it and put it back
Jul 08, 2009 | Canon imageRUNNER 5570 Copier
Waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
May 26, 2009 | Canon imageRUNNER C3170U Color Copier
Toner waste container location
Mar 30, 2009 | Canon iRC3100 Printer
How do we empty the waste basket?
The "waste basket" is to indicate that the waste toner area in the drum cartridge is full. If the copy quality is still ok you may be able to empty the waste by removing the drum cartridge from the machine and removing the opaque piece from the left side and dumping it out. BE CAREFUL this can be very very messy. toner is a very fine powder and will get all over the place if caution is not used.
Jan 07, 2009 | Canon NP 7130 Black and White Copier
Waste Toner for GP200 series
The waste toner is collected inside the drum cartridge. It can be emptied by removing the drum cartridge assy and opening the opaque window and emptying into a large bag. The lines on your copies are probably a symptom of the drum being worn out, so replacement is probably a better option. The drum is good for 60,000 copies.
Jul 17, 2008 | Canon IMAGERUNNER 6570 Copier
107 people viewed this question
jasbo
jasbo
