Question about Canon LIDE20 Flatbed Scanner
Problem with Canon Lide20/30. I want to multi scan photos. The multi scan in the simple mode is not working. The multi crop and size signs in advanced mode are not enabled. Tried uninstalling and installing but no change.
  • 7 more comments
  • ciki Mar 11, 2011
    the support was of no use
    now I even can not use the scanner - says error
  • ciki Mar 11, 2011
    no good
    I scan with arcsoft studio - why would canon toolbox make any difference? it was installed on my computer
  • ciki Mar 11, 2011
    i used to multi scan until now so my applications are able to handle multi scan. I probably changed something by mistake
  • ciki Mar 11, 2011
    I multi scanned till now - so no problem with my application. I probably hit some wrong button
    I am getting non relevant answer from you: install canon toolbox? install repair driver that say that I have oudated drivers - on a new computer? will I get a solution that will work?
  • ciki Mar 12, 2011
    i use windows xp and the multi scan problem is in Arcsoft Photo studio 5 ( in the simple mode) plus the advanced mode the multi crop and size selection are not enabled
  • ciki Mar 12, 2011
    did you find something useful?
  • ciki Mar 12, 2011
    I did everything you said ( the scan gear window did not open in the lower right window but middle). The pictures were scanned as a whole and appeared in the photobase 3 (not arcsoft photostudio5 )/ they were not separated, eventhough I chosed multi scan.
    The links did not open on the internet. Can you give me the basic web in which i would follow the other parts of the adress?
  • ciki Mar 12, 2011
    The multi crop and size settings in advanced mode in your instructions, are still not enabled.
  • ciki Mar 12, 2011
    one of the links is your previous mail the other two guides I have already and read them deeply. If the guides would have solved the multi scan problem I wouldn"t have ask help from you.
    By the way, there is a comment in the guide when they mention the multi scan that says that multi scan will not work when some application/// I did not understand that . is this the cause?
    President:
  • 1,961 Answers
Hello!
Can you tell what operating system you are using?
On what particular program application that you are using right now, is the multi scan function seems not useful?
These information is needed to give you the proper advise.
Posted on Mar 11, 2011
  • 1 more comment
  • Danilo Baraquiel
    Danilo Baraquiel Mar 12, 2011
    hold on im looking on it tnx.
  • Danilo Baraquiel
    Let's start trouble shooting:
    1. On your scanner, press the Scan-1 button or the Scan-2 button.
    2. A new Scan window will appear, see if the box next to "Use the
    scanner driver to make advanced setting" .....is blank or has a check
    mark on it. Make sure it has check mark on it..
    This category sets whether or not the scan settings
    are set with the ScanGear CS scanner driver.
    If a check mark is placed in this category, the ScanGear CS window will
    open when you click the Scan or Copy button at the window's lower right
    corner, allowing you to adjust the scan settings in detail.
    The Scanner settings in the Copy window, including the Scan mode, Paper
    size, Image quality and Brightness, are disabled. Set them in the ScanGear
    CS window instead.
    If there is no check mark in this category, the scan is initiated right
    away when the Scan or Copy button in the window's lower right is pressed.
    If Multi-Scan is selected in the ScanGear
    CS window, the number of image files sent to the application program
    corresponds to the number of items on the platen. With the Copy
    function, the number of image files sent to the printer corresponds
    here are some helpful links: copy paste this links on your internet browser.
    1. file:///D:/Downloaded%20files/LiDE2030scanningguide-e/CanoScan/3/2/3/3_2_3_6.html
    2. file:///D:/Downloaded%20files/LiDE2030scanningguide-e/CanoScan/3/2/3/1/06.html
    Let me know if this works.
  • Danilo Baraquiel
  • 2,574 Answers
Please click on the link below and follow the instructions in order to fix your problem:
Multi-Scan or Multi-Crop funcion does not crop or transfer multiple images.
Download and install CanoScan toolbox -->click here
  • Reparatii PC - Service IT
    Some software applications may not be able to handle multiple image scanning.
  • 1,555 Answers
It seems that the driver which you are using is outdated try downloading one from the link provided below and instal.
http://www.opendrivers.com/driver/297493/canon-canoscan-lide-20-scanner-scanning-guide-1.0-mac-os-x-free-download.html
  • Aruna Singh
    Aruna Singh Mar 11, 2011
    In such cases you can always uninstal the recent driver and install the old one. You will be able to use it back again. Meanwhile, I'm looking for another solution.
  • Aruna Singh
    In such a case I would recommend you to remove the power cable and data cable of the scanner. Keep it for 15 minutes like that only. Uninstall the driver from your computer. Restart your computer connect your scanner to your computer without installing drivers but to a different port than you used. Install the driver when asked by the window. Re-start your computer and then try multiscanning again.
My Cannon Pixma MP500 multi-function printer randomly scans only part of the document on the glass. Sometimes it does get it right; that is it correctly scans the whole page, but very often, the scan...
Try to adjust the scanner resolution
Solution: Adjusting Output (Scan) Resolution (Windows) - MP150 / MP170 / MP450 / MP500 / MP800 / MP950
Adjusting Output (Scan) Resolution By changing the resolution, you can set how clear the image is going to be.
The higher the resolution, the clearer (but the larger) the scanned image is.
The resolution can be changed before scanning. (Note)
If the resolution is doubled, the image data will be quadrupled.
If the data is large, problems such as slow processing speed or lack of memory may occur.
To change standard scan settings using MP Navigator, click here
To change more advanced scan settings using the scanner driver, click here
Using MP Navigator
  1. Place the document face-down on the platen glass.
  2. Launch MP Navigator.
    1. On the Windows desktop, double-click the 'MP Navigator 2.0' icon.
    2. Alternatively, in the Windows taskbar, click 'Start', click '(All) Programs', 'Canon Utilities', 'MP Navigator 2.0' folder, then 'MP Navigator 2.0' icon.
  3. Click 'Scan Photo/Document'.
    Display varies according to the printer model.
  4. When the Scan Photo/Document window is displayed, click 'Specify'.
  5. When the Scan Settings window is displayed, select the resolution in Scanning Resolution drop-down.
    Select from the following scanning resolutions:
    [Text(OCR)]: 300/400/600
    Other: 75/100/150/200/300/400/600
  6. If necessary, set other items as well.
  7. Click 'OK'.
  8. In the Scan Photo/Document window, click 'Scan' to start scanning.
Using the scanner driver
  1. Launch MP Navigator.
  2. Click 'Scan with Scanner Driver'.
  3. Change the resolution.
    According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
    To set the resolution in Simple Mode:
    (A) Select the 'Simple Mode' tab.
    (B) In Destination drop-down, select the resolution which suits the purpose.
    To set the resolution in Advanced Mode:
    (A) Select the 'Advanced Mode' tab.
    (B) In Output Resolution drop-down, select one of the preset resolutions, or enter a number from 25 to 19200 to specify your favorite resolution.
  4. In either Simple or Advanced Modes, select other settings as required and then click 'Scan' to start scanning.
Aug 13, 2008 | Canon Office Equipment & Supplies
Problem with Canon Lide20/30. I want to multi scan photos. The multi scan in the simple mode is not working. The multi crop and size signs in advanced mode are not enabled. Tried uninstalling and...
Check the manual for that on this link http://safemanuals.com/user-guide-instructions-owner-manual/CANON/CANOSCAN%20LIDE%2020-_E
Hope it helps.
Mar 11, 2011 | Canon LIDE20 Flatbed Scanner
Canon scanner speed slow
Various ways....Try these! the slow problem wil get off
How to change the resolution (Windows)
The precision of printouts can be improved by changing scanning resolution.
The higher the scanning resolution is, the more precise the scanned images are represented, however, the file size gets larger.
The scanning resolution can be changed before scanning photos.
Note: When the scanning resolution is doubled, the image data size will be quadrupled.
When the data size is large, the throughput speed may slow down or may occupy too much of the computer's resources (memory).
<Procedures>
Memo: The following is explained using MP Navigator 3.0 procedures.
To scan using MP Navigator:
1. Launch MP Navigator and click Photos/Documents (Platen) on the Scan/Import tab.
80006642en_05sj00759_en_00.jpg- The window you see varies according to the printer model.
2. When the Photos/Documents (Platen) window is displayed, click Specify.
3. When the Scan Settings window is displayed, select the resolution in Scanning Resolution.
4. Click OK.
5. In the Photos/Documents (Platen) window, click Scan to start scanning.
6. Changing the resolution is completed.
To scan using the scanner driver:
1. Launch MP Navigator and click Open Scanner Driver on the Scan/Import tab.
80006642en_05sj00765_en_01.jpg- The window you see varies according to the printer model.
2. Change the resolution.
- To set the resolution in Simple Mode:
(1) Select the Simple Mode tab.
(2) Select the output resolution from the Destination pulldown menu.
If necessary, set other items.
- To set the resolution in Advanced Mode:
(1) Select the Advanced Mode tab.
(2) In Output Resolution, select one of the preset resolution, or enter the number from 25 to 19200 to specify your favorite resolution.
3. Click Scan to start scanning.
4. Changing the resolution is completed.
Jun 01, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanned photos on my Canon Pixma MP190 come out about the size of a postage stamp. Then it gives option to edit or crop. Why don't they come out the size they are when scanned
all you have to do when you scan an image for example , you will set it to enlarge image.. do that it will appear big.. or the same as your pictured scan..
Sep 07, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Canon CP760 will not recognize images. I loaded
hi,
you can try picasa-the free photo software by google to do all simple photo editing. after editing directly print the photo from the program(rather than transfering to sd card) as this will reduce chances of non-recognition by printer.
cheers
Jul 17, 2009 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Scanning photos into computer at a large size?!
This sounds like you are trying to scan images at a larger size than they actually are?
I am not an expert-(but I have a Mac)-but from what I'm reading, scan your photos at a 300-600 dpi resolution, then use photo editing software to enlarge them. The higher the resolution, the more disk space and the more photo detail (i.e. cracks, dust, scratches, paper type) will be captured, and the more time it will take to scan. Also, for the white, does your scanner allow you to select the area/define borders during the pre-scan? Mine lets me drag borders to just the image area (but capture the image first, then do the cropping and editing to a copy later).
Rookie2112
Dec 11, 2008 | Canon PIXMA MX310 All-In-One Printer
Scanning with Canon Pixma MP450
I just did it then! With help from solution posted Feb 08 leave the acual scanner alone can be done from the computer. Steps:
1. Go to - start - control panel - printers & hardware - scanners.
2. Once inside the scanners folder just click once on the scanner icon (mine is called WIA Canon) so it is highlighted.
3. Then click on the toolbar 'File' > 'scan', then select the correct program from the list (mine was MP Navigator 2).
4. Use the MP Navigator program to select "scan photo/document", follow the instructions. At the bottom if the window that is open you can change the document type to PHOTO or DOCUMENT!
This is where the problem lies it is scanning the document as a photo which is why it is coming out as multiple documents.
Feb 06, 2008 | Office Equipment & Supplies
Unwanted cropping of some 35mm slides using CanoScan 8400F
Turn off the thumbnails view and you can manually set the cropping box.
Nov 29, 2007 | Canon CanoScan 8400F Film Scanner
Scanning mode, unrequested crop
There many program to reshape or crop /adobe photo shop/corel draw.it make drawing became smaller in size to fit scanner.
Sep 02, 2007 | Canon Pixma MP450 All-In-One InkJet...
Canon LIDE20 Flatbed Scanner Logo
284 people viewed this question
old marine
old marine
