When I wanted to delete a file It gives an error message "Cannot delete nul: The parameter is incorrect"
  • 506 Answers
Right click the file, Security, advanced, owner. Change the ower to the user you are using to delete the file. Apply and OK, to complete the taking owership of the file.
Delete the file.
Posted on Mar 11, 2011
    Sergeant:
    Novelist:
  • 164 Answers
You may try to rename the file and try deleting it again. Or you may open a command prompt(go to run and type in cmd) and type in del \\.\Drive:\directory\filename
Example: del \\.\c:\programfiles\me.exe
"online" light flashes, but labels don't print
Check that you are using the correct escape characters.
in printerparameter check that you are on auto
else check in the driver you are using esc LF Nul or {'} characters.
last if in serial mode check the communication parameters
default 9600,n,8,1 (no partity 1 stop bit, 8 data bits)
Jul 30, 2012 | Toshiba TEC B-572 Printer
Garmin 2460 incorrect parameter
Hello
Go its user manual page [19] to get details about this fault. If you want to download the manual for free, try links
static.garmincdn.com/pumac/nuvi_2200_2300_2400_EN_OM.pdf
www.retrevo.com
http://www.dataentryjobs.us/67948.html
Feb 05, 2012 | Garmin StreetPilot c510 Deluxe GPS...
The parameter incorrect
Symptoms:
- Synching with Outlook.
- Error message: 'The parameter is incorrect'.
Explanation:
Generally, this error message indicates that the configuration process has been cancelled at some point. Typically, this happens due to cancelling the setup process on the Outlook Folders tab. If you are on Exchange folder, this tab can take several minutes to populate.
Fix:
In order to correct the problem you are experiencing, you will need to delete or rename the .ini file and then reconfigure CompanionLink/DoubleLook. This file is typically found in one of two locations:
For CompanionLink:
c:\Program Files\CompanionLink\
c:\Documents and Settings\[Username]\Application Data\CompanionLink\CompanionLink
For DoubleLook:
c:\Program Files\DoubleLook\
c:\Documents and Settings\[Username]\Application Data\CompanionLink\DoubleLook
Please note that Application Data is a hidden folder and that the .ini file extension is hidden by default. Please see http://www.companionlink.com/support/howto/ht0017.html for an explanation of how to display all files.
Hope this helps
Mar 01, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Turbotax 2008
Hello There, I found this in their FAQ Guide. Hope this resolves your problems, I know it is a bit of a read. Good Luck!!
What is happening?
Double-clicking on a backup, portable company file, or a file with an extension other than .qbw, the following error occurs:
An error occurred when QuickBooks tried to create, open, or use the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (-6150,-1006).
Or, if you attempt to double-click the data file without QuickBooks open, the following error occurs:
There was an unexpected error reported while trying to run QuickBooks with company file "path location". Error code 80070057.
Note: More than one error message that includes the error code 80070057 exists. If this is not the exact wording of your error message please refer to one of these other documents:
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, QBW, NT, or TLG file from a Google Search Timeline
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, NT, or TLG file from a Google Search Timeline
Error: 80070057, the parameter is incorrect. There was an unexpected error reported while trying to run QuickBooks with company file [path and name]
Error: 80070057 the parameter is incorrect" and "You do not have sufficient permissions to delete files...
If your Error 80070057 is different than the ones displayed, perform a new Search.
Why is this happening:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
How to fix the problem:
Verify that the file extension displays company name.qbw and not a shortcut.
Copy the company file, change the extension to .qbm, .qbb, or .qbx, and follow the appropriate steps to open a portable file, backup, or accountant's review.
If the error occurs during the conversion or creation of a backup or portable company file, run the Verify utility to check the file for data damage. If it finds damage, run the Rebuild utility.
Repair the QuickBooks installation.
Uninstall, and then reinstall QuickBooks.
Sep 25, 2009 | Microsoft Windows XP Home Edition
Cannot delete my bad files...
Could be a process issue stopping you deleting the files. Try downloading unlocker (http://ccollomb.free.fr/unlocker/) and see if this helps.
If not it might be an 8.3 naming convention issue. Go to DOS prompt to a "dir /x /a". Rename the file to less than 8 characters using the SHORT name only. Then try deleting the file.
Apr 01, 2009 | Microsoft Windows XP Professional
Cannot copy files Parameter Incorrect
most likely the issue is that your trying to copy files over 4gb to fat32 disks, and this causes the parameter incorrect -issue. Try formatting the drive your copying to ntfs, this can handle +4gb files.
Nov 11, 2008 | JVC Everio GZ-MG360 HDD Camcorder
System Error. Code : 87. Parameter is Incorrect.". Please give me solution for this
When I want to connect a software ,which connect to Database through ODBC display the messageV"System Error. Code : 87. Parameter is Incorrect.". Please advice solution
Mar 29, 2008 | Microsoft Windows 98 for PC
Cannot open or copy - parameter is incorrect?
..wel, i solved mine.. im copying music files into a memory card like micro SD.. when im copying music.. it says.. cannot copy file.. the parameter is incorrect... then go into My Computer then Right Click the external hrd drive(micro SD),, then go to properties....then tools.. then click the Check now.. - it will check for some errors and automatically fix the errors.. :D thats it..
Oct 17, 2007 | Vivitar ViviCam 5385 Digital Camera
Computers & Internet Logo
212 people viewed this question
David Payne
David Payne
