Question about Lanzar SD32MTS Car Video Player
I have the lanzar sd32mts.. the option for the bluetooth isnt lighting up for me to select. i have my phone on bluetooth and ive tried search and listen and nothing happens the screen is gray for not on or something. how do i get the bluetooth to work also is there anywires in the back the must be hooked up. i connected them all but the blue wire and the brown wire. everything else works fine just not the bluetooth
Duncan
  • 218 Answers
SOURCE: my vibe 286 4000 watt lanzar amp wont stay on..
Check your speaker load. It probably should be 4 ohms per channel. Also, if you are bridging then you must double your ohms load. It may be that your old amp could tolerate a lower impedence (ohms load) than the new amp. Do this now so you don't fry your amp. Good luck.
Posted on Mar 05, 2007
  • 5 Answers
SOURCE: lanzar not playing dvd's says parking brake
what you need is a toggle switch...
put the switch between the parking brake wire, and actual ground,
the black wire will work, just extend the wire so the toggle switch is
accessible, once you do that turn your indash on,
slap a dvd in it, then once it displays the parking brake message,
hit your toggle switch once, if it doesnt get it,
try it multiple times but with a second between clicks,
that should do it and please keep the eyes on the road. :]
Posted on Jun 23, 2009
  • 78 Answers
SOURCE: speaker box wont work
The quickest way to tell the woofers are good or still hooked up... you need a multimeter set to ohms. test each speaker and make sure you get a reading of 2, 4 or 8 ohms. ifs its a prefab box, probably 4 ohms each but still depends on make. Make sure the speakers have good connection inside and out. Make sure amp wiring is in good condition too.
Posted on Jul 25, 2009
  • 21 Answers
SOURCE: My amps and subs are working, but my subs aren't hitting.
Try bypassing the remote wire staight to power instead of the stereo
Posted on Oct 27, 2009
  • 3 Answers
SOURCE: car amp turned off in the middle of play
if ur running this amp at 1 ohm or less that could be ur problem just turn every thing off and try again if still didint work u might have blown ur amp im looking at one of these amps to and just wondering what kind of ohm s ur running
Posted on Dec 14, 2009
Tip
How can I send pictures via Bluetooth?
<p>Sending images is easier than ever to do with Bluetooth. The Bluetooth function is a wave viable communication link allows electronic devices to share and transfer media such as photos, music and even videos without any physical connection. In most cases, users choose their cell phone to send pictures to the computer as a way to upload. However, most of the work is done by phone. By setting up user, you can use the Bluetooth function on their mobile phone or computer to easily send photos for free. <br /> <p>1. Press the phone "Menu" or "OK" button and navigate to the Pictures folder on the phone. <br /> <p><br /> <p>2. Search photos stored on the phone and find the photo you want to send images from the phone directory. <br /> <p><br /> <p>3. Press the right phone, the pictures "menu" Options. "Select the action" Send Options "pop-up menu. <br /> <p><br /> <p>4. Select the "Bluetooth" option to send the submenu. You will be prompted to power the phone's Bluetooth component. <br /> <p><br /> <p>5. Press the phone "Menu" or "OK" to "Yes" option and confirm that the Bluetooth component. Bluetooth phone menu opens automatically. <br /> <p><br /> <p>6. Select Search to search for compatible Bluetooth-enabled electronic devices by selecting "Browse Device" option in the Bluetooth menu. (The phone must be connected to the receiving device for photos sent successfully.) Component Bluetooth phone will start searching for devices within easy reach. <br /> <p><br /> <p>7. Select receiving electronic device is the name of the list of Bluetooth devices from your phone lookup. A request to accept photos sent will be sent to the receiver. If the request is accepted, the image is automatically sent from your phone to the receiver. <br />
on Jun 26, 2011 | Computers & Internet
How do i bluetooth songs to a freind with my android huawei u8230 mobile phone
Just select the song, click on 'options', then select 'send', then select 'via bluetooth'.
If the songs you want to send are more than one, select the first song, click on 'options' select 'mark', then go to the next song, select 'options', then 'mark'. Do this for as many songs you want to send. When you are done with marking, select 'options' > 'send' > 'via bluetooth'.
When you click the send via bluetooh, it would ask to search for devices. First make sure your friend's bluetooth is turned on, then search for his/her device, when it detects it, select 'connect' on your phone, then on your friends phone, select 'accept'.
Hope that was helpful?
Have a lovely day.
Jun 05, 2011 | Cell Phones
I have a lanzar sd32mts. and the option for the bluetooth is not lighting up for me to select, i do have the bluetooth "on" on my phone ive tried listen and search but nothing. any ideas why
have you read the instructions that came with your device? normally you have to try to sync them both together at the same time within about 100 to 300 seconds. first you have to set your phone on discovery mode under the blue tooth options then next you have to hold down the blue tooth sync button on your other device for a few seconds till it lights up, then they are paired. But also sometimes to complete the pairing process you have to enter a default code. normally something like 0000, or 1234.
Mar 11, 2011 | Car Audio & Video
My samsung sgh-t139 cannot connect be found on bluetooth
To Turn Bluetooth On or Off
This option allows you to turn Bluetooth On or Off.
1. From Idle mode, press Menu ? Settings ? Bluetooth.
2. Make a selection and press the Select soft key or the OK button on your keypad.
My Devices
This option allows you to search for new Bluetooth devices. Highlight the Search new device option and press the Select soft key or the OK Button on your keypad. The phone searches for available devices.
Sometimes cell phones and bluetooth devices become problematic when trying to pair them together. If you've followed the directions correctly but are still not able to get them to pair, take them to your cellular company's store and let them pair the devices. They can show you step - by - step how to correctly do it.
Jan 26, 2011 | Samsung Cell Phones
How can i pass a song via bluetooth to another phone using my sony ericsson xperia x8?
1.select a song
2.go to option
3.there you can see the send option
4.select the sending option(bluetooth)
5.the bluetooth will search for available bluetooth connection
6.select the bluetooth connectivity which you have to send
Dec 27, 2010 | Sony Ericsson XPERIA X8 Cell Phone
I plug in my ipod touch and it will not play through my speakers, it plays through the ipod speakers instead, how can i solve this problem
when you plug the ipod touch in do you select the radio to source to aux to reconize the ipod
do you get any of the ipod to display on the radio screen
let me know
caraudioquestion@gmail.com
Oct 29, 2010 | Lanzar SD32MTS Car Video Player
Ive just braught car car with a 3200 ls already in the car, ive erased all old phone that have ben used on it but i dont know how to link my nokia n95 to it, can anyone help me ?
2 ways of doing this. Go in to the bluetooth menu of your phone and search for the device, it will come up parrot 3200ls select this and it will give you a pin on the screen enter pin in the phone when asked and hay presto! you will have to send over the contacts tho, you do this by going into contacts then options, mark, mark all, send, via bluetooth, select the parrot, and it will send them all over. The other way is if it doesnt give you a code on the screen when pairing, go in to settings, pair with phone, then other phone, pin will come up. search from phone and then select.
Nov 29, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Im trying to set up my blue tooth to work on my ps3 but no signal is found what am i doing wrong?
You need to pair your PS3 with your bluetooth headset.
  1. Turn on your PS3's bluetooth and search for bluetooth devices.
  2. While the PS3 is searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the PS3 finds it.
  3. Pair the devices and allow the BT headset to connect automatically.
  4. To connect, press and hold call/end button on BT headset like the one in step 2.
Oct 25, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
Bluetooth pairing
Try the following:
a) Options->Bluetooth->Enable Bluetooth
b) switched on the Moto headset (blue light blinking)
c) options->bluetooth->add device
d) searching for devices....---> here it should find the headset and pair....
If it does not work do the following
After doing the above, do the following:
e). Start the headset. Start with the headset powered off, and hold the Call button for 10 seconds or so, until the light stays on. (Initially, the light will flash a few times before getting steady.) If the light is flashing, or if the light starts flashing anytime during steps f) through g), the headset is not in pairing mode, and this step (step e) must be repeated, again starting with headset powered off.
Select the Headset:
f.) Go back to phone, and select "[Look for Devices]." The phone starts searching for Bluetooth devices.
g). Once phone is finished searching, you get a list of one or more devices under the heading "Scan Results." Select the headset.
h). The next screen will read "Bond With ..headset." Select "Yes."
i). The next screen will be "Enter Bluetooth Passkey." Enter 0000 and select "OK." A screen will confirm pairing and connection. When the pairing is complete, the light on the headset will flash.
Sep 13, 2008 | Cell Phones
Lanzar SD32MTS Car Video Player Logo
Top Lanzar Car Audio & Video Experts
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Jose Velazquez
Jose Velazquez
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
