Question about Systemax Pursuit 4155 Notebook PC - Intel Core 2 Duo T5200 1.6GHz, Genuine Windows XP Professi (023363) PC Notebook
RAM chip is bad
I took my computer to Pennsylvania College of technology. They ran a diagnostic test on it today. They just called me back and identified the problem through the diagnostic test as the RAM chip number DDR2PC5400. My computer still is under warranty.
    Genius:
  • 2,028 Answers
Refer to your warranty for contact info, and if memory is covered. If so, tell them you had a professional diagnostic done, and see if they'll send you another memory chip. If not, then you will need to get the chip specs, and replace the chip yourself.
Posted on Jul 31, 2008
Two components that must utilize the same front bus speed
Let's dissect the question
I feel it may help you understand better. Looks like a test. The purpose of a test is to see what you know.........
Bus,
http://en.wikipedia.org/wiki/Bus_%28computing%29
Front Side Bus (FSB)
http://en.wikipedia.org/wiki/Front-side_bus
Now you know what a BUS is, and a Front Side Bus.
Now let's apply that to a Motherboard Diagram, and see if that makes it clearer.......
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
You see how the CPU (Processor), is connected to the Northbridge chip, (Of the motherboard chipset)
Data (Information) transfers back, and forth through the FSB, to the Northbridge chip.
Think of the FSB as an 'Information Highway'.
Now,.............what other component besides the CPU, has to operate at the same frequency rate ('Speed'), as the Front Side Bus?
Correct
The Northbridge chip
As you can see the Northbridge chip handles the Faster capabilities of a computer;
CPU (Processor), Ram Memory, and HIGH-speed graphics; plus Jennifer Aniston.
NO! You gonna' believe that? Just messing with you about the Jennifer Aniston thing!
(She is HIGH speed though! Whoa!)
HIGH-speed graphics being the AGP technology, and the PCI Express technology.
A graphics card inserted into a PCI slot, OR using Integrated (OnBoard) graphics; is NOT high-speed graphics
The Southbridge chip handles the Slower capabilities of a computer;
Anything connected to the;
A) PCI bus. (Like a PCI graphics card)
B) Integrated graphics. (Should be stated as OnBoard Graphics.
Easier to understand. ON the motherBOARD)
C) IDE (PATA) bus,
http://en.wikipedia.org/wiki/Parallel_ATA
D) SATA bus,
http://en.wikipedia.org/wiki/Serial_ATA
E) USB bus
F) Ethernet
G) Audio (Sound)
Ram Memory TYPICALLY operates at half, of the Processor's FSB.
I say again -> TYPICALLY
Overclockers would like ram memory to operate at the same frequency rate ('Speed'), as the processor's FSB.
Problem is folks, the expansion slots are also dependent on the CPU's (Processor's) FSB
Mess with the CPU's FSB too much, and ram memory won't operate, and neither will the expansion slots.
Bear in mind Bud, that this is rapidly becoming old technology.
However, you have to know this technology, to be able to understand the Intel Core i technology.
This technology does NOT use a Front Side Bus,
http://www.hardwaresecrets.com/article/535
http://en.wikipedia.org/wiki/Intel_QuickPath_Interconnect
Regards,
joecoolvette
Apr 17, 2013 | Computers & Internet
Dell Optiplex 330,won't boot memory parity error, tried new bios battery, new ram stick, still won't boot,actually had two at same time the other I ran a advanced diagnostic test said hard driv
I found this
Customer's Optiplex 330 did the same thing today; no beep codes (due to lack of on board speaker). Solid/orange light on front of case indicates board or cpu. I isolated every component not soldered down (RAM, HDD, Optical, etc). Considering all the fans and lights on the MoBo were functioning, and no physical damage to the CPU was apparent, and the BSOD presented the "memory parity error; system halted" (meaning it's memory, graphics memory, or cpu and we've eliminated possibly CPU and RAM) my conclusion is that the problem resides in Graphics memory failure. Considering the error message is very vague and generally insists "motherboard", the gpu in an optiplex 330 is integrated ON the board, lumping it all together.
and general memory parity fail information
memory parity error fix Google Search
Nov 22, 2017 | IBM ThinkCentre Computers & Internet
Windows shuts down unexpectedly
This problem has been solved. There was intermittent contact inside the power switch on the front of the case causing the motherboard to issue a shut-down request to the operating system. Switch replaced and system is now stable.
Oct 06, 2012 | ASUS M3N WS Motherboard
RAM
I have no idea what test they ran or why you took the machine to them.
Was it having a problem?
Assuming that the RAM tested bad, you can easily replace it yourself. If you are not willing to do that then I suppose you'll have to have them do it or have someone else do it.
There is no way we can really answer your question, as we know nothing about the original problem or what tests were run.
Jul 29, 2009 | Dell Computers & Internet
Computer crashed it will not let me start up the computer
reseat ram, hd sounds good, probably ram is loose and needs to be reseated.
Jul 06, 2009 | HP Compaq nx6110 Notebook
Worked fine yesterday, today zilch !!
One computer I fixed had its internal power regulation confused. With the AC adapter plugged in, holding the power switch down for twelve seconds, then pressing it again, switched it back on. This sort of problem can come from a variety of causes, though. There is an internal power distribution chip which could have received a static electric shock or power surge and gotten cooked. The RAM could have gone bad. The socket where the adapter plugs into the computer could have been cracked loose. Check the power switch and then RAM first, and write more if that doesn't fix it.
Jan 05, 2009 | Toshiba Satellite M105-S3041Notebook
Ok, this is my problem. My friends comp took a dump. A friend told her that it was definatelythe hard drive. I thought ok, lets find out how to replace it. But than was told by someone that it may be the a...
There is a way of testing harddrives and RAM using the manufacturers diagnostic tools, you would have to go to the harddrive manufacturers website and download the utility then burn it to a CD.
You can also download a whole bunch of diagnostic tools and burn it to a CD using whats known as "The Ultimate Boot CD". There is plenty of help and instructions on the UBCD web site:
http://www.ultimatebootcd.com/
You will need a computer that has a CD burner installed and the ability to make a bootable CD, you will also have to change the setup of your friends computer so that it boots from the CD first and not the harddrive, by carrying out the diagnostic tests hopefully you can identify the faulty part easier and avoid buying something you don't need.
Oct 19, 2008 | Computers & Internet
Dell latitude d60
WE NEED A ALL DRIVERS FOR DELL LATITUDE D600 MODEL LAPTOP - WINDOWS XP OS
Apr 26, 2008 | Dell Latitude D600 Notebook
Systemax Pursuit 4155 Notebook PC - Intel Core 2 Duo T5200 1.6GHz, Genuine Windows XP Professi (023363) PC Notebook Logo
66 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
