Question about Dell Inspiron Mini 1012 Netbook PC
I want to restore it to factory settings but i have formatted my hard disk. There is a partition drive labelled O.E.M
    Scholar:
  • 45 Answers
Hi, welcome to FixYa.
Are you sure you have formatted all partitions in your hard drive? If that so, it will become very difficult to restore the "factory settings" because the factory settings restore is kept in the on of the partition that you have formatted.
There are several softwares that claim are able to recover formatted partition, but I'ven't tried any. You can search for them.
I hope this can help you out.
Posted on Mar 11, 2011
Reformat partition hard drive
To return your HD to the factory settings do a full system recovery using the recovery disks (CD or DVDs) you made when you first had the computer. This will return the whole computer to its as-shipped state: you will lose all your data and any software that you have installed. This will retain/re-install the original partition structure on your hard disk. To do this process you may also use the recovery partition on the hard disk.
To completely reformat the hard disk, in which case you will lose everything on it
press the start button at the bottom left of screen,
R-click on computer, and select manage. The computer management window will open. From the left pane click on disk management under 'storage'. A new pane will open, with information on the different disks in your computer. Select the disk on which the partition to be formatted is located. R-click on the partition to be formatted, and choose format, and ten work through the format wizard. (see http://windows.microsoft.com/en-us/windows/create-format-hard-disk-partition#create-format-hard-disk-partition=windows-7)
When you R-click on the partition other options will appear will appear as well as format, choose the appropriate option to create a new partition, merge, etc, By successively working your working your way through the partitions you may format/merge some while retaining others.
18.July.2014
Jul 11, 2014 | HEWLETT-PACKARD Computers & Internet
Tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 | Computers & Internet
Tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
OS Hard drive missing
Using Recovery Partition
The Recovery Partition quickly restores your Notebook PC's software to its original working state. Before using the Recovery Partition, copy your data files (such as Outlook PST files) to USB storage devices or to a network drive and make note of any customized configuration settings (such as network settings).
About the Recovery Partition
The Recovery Partition is a reserved space on your hard disk drive used to restore the operating system, drivers, and utilities installed on your Notebook PC at the factory.
Sep 12, 2013 | ASUS Computers & Internet
Im trying resore my acer back to factory settings
Did you press 5 times
If you do NOT have a copy of this disc, skip to step 3 for further instructions. Once you restart your computer, a screen will appear with the words. Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings. Follow the on-screen prompts to finish the installation. Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again. Restart your computer to complete the restore. 3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk. Unplug all external devices and restart your computer. When the loading screen comes on with the Windows logo, press Alt+F10 together five times. This will bring up the system restore menu. Follow the on-screen prompts to restore your computer back to the factory settings Hope this helps.
Jan 20, 2013 | Computers & Internet
Mi notebook acer aspire 3000LCi the only do is a an upper and i dont have a recovery disk
When you restore your system back to the new factory settings, it will wipe your hard drive clean and do a fresh install of the operating system with the original factory setting.
To start this process, unplug all extra devices from your computer
(printers, external hard drives, etc.) as these can interfere with the system restore.
Starting with Windows XP, most systems with issued a system recovery disk in case of any problems with the factory installation.
Check the documentation and disks that came with your computer to determine if you have one of these system disks.
If you do have a copy of this disk, place it in your CD/DVD drive and restart your computer.
hope this helps
Oct 17, 2012 | Acer Aspire 5610-4648 Notebook
Yes I have forgot my password on my toshiba Satellite L3550 and I cant do any thing on my laptop. I dont have a boot disk either, is there anything I can do to beable to use my computer again
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
Restore Partition C: of HDD without changing current partition size
CAUTION:
Restoring the C: drive to its factory default state formats your drive. Your information on the drive will be overwritten, and lost. Be sure to back up all important files first. If you have created other partitions (for example, a D: drive) those partitions and any information on them will not be affected and will remain intact.
To restore only the C: drive:
  1. Press 2 to restore only the "C:" drive (the letter C is traditionally used to designate the first volume on the hard disk drive) on your computer. A confirmation message will appear, indicating that all information on the drive will be lost during the recovery process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating that the HDD has been restored.
Restore Image to C: Partition with user specified size
CAUTION:
Resizing and restoring your C: drive to its factory default state formats all partitions on the HDD (for example, if you created a D: drive, it will be deleted during the recovery process) your information will be overwritten, and lost. Be sure to back up all important files first.
To resize and restore your C: drive:
  1. Press 3 at the Toshiba HDD Recovery Utility screen. A confirmation message will appear, indicating that all partitions will be reformatted and all information will be lost during the recovery process. Be sure to back up all important files before proceeding.
  2. Click "Yes" to begin the recovery and to specify the size of the C: drive.
    • Press the Left/Right Arrow keys to increase/decrease the C: drive size by 1 GB increments.
    • Press the Up/Down Arrow keys to increase/decrease the C: drive size by 5 GB increments.
      NOTE:
      The size of the C: drive will be displayed on the progress bar as you make your selections.
  3. Click "Enter" to begin the recovery. A message will appear once the operation is finished, indicating that the HDD has been restored.
  4. Press any key to restart the computer.
Aug 12, 2011 | Toshiba Satellite L355D-S7815 Notebook
Can you please give me step by step insturctions on how to totally wipe my hardrive on my dell latitude 600? Then I will refoat it back to its orignal settings. thank You
Unless you're donating the drive, there's no need to do anything before re-installing the OS. When Windows asks where you want to install the OS to, you'll see an option for formatting the drive first.
If you are donating it and are worried about someone recovering the data (after formatting and re-installing, it's not something the average tech can do) I'd recommend booting the laptop off CD/USB drive with this image (http://www.ultimatebootcd.com/) and running one of the Hard Disk Wiping utilities. Mind you, some of the very thorough ones (military-grade) can take DAYS.
Jun 29, 2011 | Computers & Internet
How to factory rest
  • Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
  • Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
  • Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
  • Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
  • Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
  • Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
The hard disk drive restore utility is saved on a separate partition on the Toshiba laptop's hard drive. If that partition has been formatted you won't be able to use the restore utility. If you don't have the operating system recovery disc and the partition has been formatted, you will need to contact Toshiba's customer support to have them send you a new disc.
All of your existing data will be permanently removed from the hard drive when the factory restore process has finished running.
Jan 17, 2011 | Toshiba Sattelite A105-S2051 Notebook
How do i master reset my acer 5220. my accer 5220 wont start up, it started playing up about a week ago and i think it had a bug but now wont load past the windows screen. i have tried loading in all the...
If the system can not boot, you can restore it from the WinPE environment. The system starts from the hidden partition on the hard drive. To begin the restoration, press Alt + F10 (PC Tower) or F10 (laptop) to boot the PC and when the Acer logo appears. This will start the system from the hidden partition the hard drive and you access its main page. The restoration will be on partition C:. The partition D: (ACERDATA) will not be formatted, and therefore documents will not be deleted but it is always prudent to think about making a backup of your most important documents in case!
Note: You will be asked to enter the password before the System Restore starts. If you enter the wrong password three times, the computer will restart into the operating system.
You must enter the password to access the main page of the hidden partition. The main page of the hidden partition provides three options to restore the system:
1 - Restore the system to factory default settings: Select this option and then enter the password. The utility will restore the system from the image of the factory default settings on the hidden partition on the hard drive. When prompted, confirm the system restore. A message will warn you that you will lose all data on the disc. The utility then restores the system to its original state.
2 - Restore the system from backup user: Select this option and then enter the password. The utility restores the system from the image of the user on the second partition on the hard disk. When prompted, confirm the system restore. A message will warn you that you will lose all data on the partition. The utility then restores the system to safeguard user the most recent.
3 - Restore the system from the CD / DVD: When this option is selected, insert the first disc of the backup in the optical drive. Confirm System Restore when prompted. A message will warn you that you will lose all data on the partition. The utility will restore the system from the backup image on CD / DVD. Insert the other disks when prompted.
Note: If you are trying to restore the system to its factory default settings stored on CDs / DVDs, Acer eRecovery Management prompts you to insert disc 2 to start.
Good Luck
Nov 01, 2009 | Acer Extensa 4620 Notebook
Dell Inspiron Mini 1012 Netbook PC Logo
199 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
