Question about HP Color LaserJet 2600n Printer
Hello i have HP n2600 almost all toners are at 90% but i am facing the problem that got a line in middle of page in every print and also the color are so fade..please help me
  • HP Master
  • 1,915 Answers
1. Make sure that your firmware is up to date.
2. Was the printer used in a dirty environment? If so it is possible that the scanner optics are dirty. To clean these requires a complete disassembly of the printer to remove the scanner module and then clean the inside. These units have zero tolerance for working in a dirty environment.
3. Even though the cartidges are 90 percent, it is possible to have a defective one. One bad cartridge can affect the rest. Try old cartridges if you have them to trouble shoot. Repalce one at a time and test print to see if the error has gone away. I would start with the yellow cartridge first.
Posted on Mar 11, 2011
  • 135 Answers
Try to run some test like..Ink Test, Drum test. It is in the menu button of the printer. From running a test you will see the exact problem youre encountering.
When printing from the HP color laserjet 4600DN, its leaving tracking lines in the middle of the page. Any suggestions on how to fix this?
Hello, track lines could be caused by a number of components within the printer.
Is it any specific color? Yes - Change the toner of the color causing the lines.
open the front main door, Inspect the ETB for damage. Inspect the fuser for damage. If any component shows damage it will need to be replaced.
Feb 04, 2011 | HP LaserJet 4600dn Color Printer
Hp 2500l prints a dark line horizontal down each page. Can we clean drum at home?
A dark line on the hp 2500 series can come from the drum You can't clean it at home), it can come from a toner cartridge, from the fuser unit and from the optics.
Step one - check if the line in all colors, run copy quality check through Menu and diagnostics, if the line is only on one color your problem is the toner cartridge.
Step two - if the line is on all colors, take the drum unit out and look at the drum, if you see the line on the drum you need to replace the drum unit.
Step three - stop a print in during the printing process by turning the printer off, take out the drum and look at the printed paper under the drum, if the printed page is clear of line your problem is in the fuser.
Good luck.
Dec 14, 2010 | HP Color LaserJet 2500L Laser Printer, up...
Hello, my problem is, when i print a copy I receive a blank line, it seems like the ink is finish or the middle of the ink is finish or don't have ink. don't know what to do I tried to clean the toners and...
If you are seeing a white line down the page in one or more areas, but it is printing fine in others it is most likely your toner or your drum. Try taking the toner cartridge out and shaking from side to side to evenly distribute the toner and break up any lumps that might have formed while it sat around. If that doesn't work take out your drum unit and look at the drum roller (don't touch it!) if you see lines or color differences on it then it might need to be replaced.
Aug 18, 2010 | HP LaserJet CP1515n Printer
Cp2025 horizontal color lines almost 3" apart.
you have to replace toner cartridges (unfortunately).
Same problems can be occured whit CP 1025 too
the problem is - cartridge image drum failed
Jul 14, 2010 | HP Laserjet Cp2025n Printer
Black dots on printed page from Brother 9440 color laser printer
The problem lies with the black toner cartridge. This is a common problem in these machines due to poor design by Brother. Best solution is to replace the offending color toner cartridge.
Jan 18, 2010 | Brother MFC-9440CN Laser Printer
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
WHEN PRINTING THE COLOR IS VERY WEAK
You have to disassemble the printer and clean the prisms inside the black box within the printer. The prism for the red and yellow colors are near the bottom and face up, so they easily collect dust buildup, thereby causing weak or striped printing of these colors.
Mar 03, 2009 | HP LaserJet 2605DTN Color Printer
HP 2600N PRINTS A BLACK LINE VERTICALLY ACROSS THE PAGE (FROM TOP TO BOTTOM) RIGHT IN THE MIDDLE EVERYTIME YOU PRINT SOMETHING . WHAT COULD THIS BE? I HAVE CLEANED EVERY DRUM, THE FILM ETC AND IT KEEPS...
You either have a defective black toner, a bad fuser or transfer belt. From my experence it is usually a bad toner cartridge. After you print a couple of pages, pull the black toner and see if there is anything on the drum. If there is try shaking the toner, sometimes toner does like dirt and clogs up. If you still have problem you will have to try another toner. I know that is not cheep, but I don't know any other way.
Mar 02, 2009 | HP Color LaserJet 2600n Printer
Magenta lines on paper
You need to change the Magenta Toner. Rebuilt toners often have this kind of problems.
Feb 27, 2009 | HP LaserJet 4600dn Color Printer
HP Color LaserJet 2600n Printer Logo
57 people viewed this question
Seeker5211
Seeker5211
