Question about Car Audio & Video
I need some assitance on how to remove the radio unto from a VW Sharan. Where are the release screws for the front panel or for the radio?
  • Car Audio & ... Master
  • 4,874 Answers
See if you can find anything useful on this free removal site
V W is listed
CLICK HERE
Posted on Mar 11, 2011
2004 Sharan. How do I remove an armrest from the front driver's seat?
i have a ford galaxy which is a VW sharan with a ford badge and mine will come off for repair by removing a cover and under the cover is a torx headed bolt
Jul 13, 2015 | Volkswagen Cars & Trucks
How do I get the drivers R/H door panel of to get access to the window operating switches on my 2001 V/W SHARAN
take a good look around the door handle. most of the times there are screws around that area (because it's the place where you pull the door, this is the obvious place to put some solid screws in). Maybe a cover lip? take a close look, pry the lip of and start your dissasembly. the rest of the panel is mostly fastened with plastic lips which pop out when you carefully pull the panel
Feb 21, 2015 | 2001 Volkswagen Sharan
Vw sharan radio proble
HI Youssef
i believe that when you put the volume up to the max, you blow up the main fuse, because the new radio with volume up to the max consume more amps than the fuse is set to for the original radio.
now you have to look into the fuse boxes and replace the fuse, this will sort out the radio and the door lock problems as i hope.
Good luck
Aug 17, 2014 | Volkswagen Sharan Cars & Trucks
Vw sharan
That is when clutch slip happens-when the clutch is released. If the clutch disc is worn badly, it won't hold tight against the engine flywheel-it will slip, causing that shudder you feel. Have a mechanic verify this, but it sounds like you need a new clutch.
May 20, 2014 | 2001 Volkswagen Sharan
How to unlock vw sharan stereo
hi! the vin for my sharan is WVWZZZ7MZ1V003511
please can i get my radio code? thnx
May 03, 2012 | Volkswagen Golf Cars & Trucks
VW SHARAN 02. i need to remove the headlights so i can straighten the cap covering the bulb and also the light tilter is not working ( the switch does not seem to tilt the beams when i turn the dial, this...
  1. In order to remove the headlights, you need to remove the front bumper cover.
  2. Place the front of the car on jack stands.
  3. You will need to remove the screws on each side in the fender wells on the back side that screw into the bumper. these are torx screw head type.
  4. On the underside of the car there are larger torx type screws that attach the bumper cover to the body. They need to be removed.
  5. You will need to remove the grill that has the VW symbol on it. Under the grill there is more torx type screws to remove. Inorder to remove the grill you need to get the hood release rod off as well.
  6. With the bumper cover removed, there are four torx type screws holding the headlight in place. Once removed you can unplug them and the head light is off.
Jan 25, 2010 | 2002 Volkswagen Jetta TDI
Is the transmission sealed on a 1999 VW Sharan?
you need a haynes manual.because some new cars dont have dip stick to check tranny fluid.you have to locate a check fill plug on automatic transmission differential.its located on the right side.front of drive axle.for volkswagon you got buy the tool to squirt fluid in tranny.still get a manual it will show you place to put tranny oil.
Jul 12, 2009 | Volkswagen CC Cars & Trucks
Whow to remove center trim panel on dash board for 99 vw beetle
on the dash top the center section is removed by holding tightly from the sides and slide it toward the windshield until it unlatches. if you mean the one around the radio , it is most of the dash face and has 2 screws at top of instrument cluster and 2 more hiding at the bottom under the the a/c controls way back just above the very front of center counsel.
Feb 28, 2009 | 2001 Volkswagen Beetle
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
