I have an amana washing machine model #: lw6501w2. it goes through the wash cycle fine and then when it starts to spin the motor is turning fine but seems like the tub really is hard to turn as a result the motor pulley spins and grinds the belt down a little each time until it is has ground down the belt to where it is not tight enough and the spin cycle does not work. i have replaced the belt several times. replaced the pump, the tension spring and tension pulley. seems to be something on the tub side of the belt that is causing it to strain and be so hard starting the spin cycle cause once it gets going it is fine. have tried it with extremely small loads thinking maybe it was to heavy but the same thing is true. would appreciate any help as i am unfamiliar with the tub side of the belt so i am lost when it comes to what is involved there. thanks john
    President:
  • 1,554 Answers
The problem is the shifting mechanism for the spin mode in the transmission assembly. The shifting mechanism is getting stuck and fails to shift the transmission from agitate mode to the spin mode. Remove the drive belt then turn the drive pulley in both directions it should turn freely both ways; otherwise, the transmission assembly is indeed faulty and replacing is the only viable solution.
Posted on Mar 11, 2011
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
Will not agitate
your transmission is locked up.
May 20, 2010 | Amana DLW330RA Top Load Washer
The amana washing machine model lw6501w2 fills with water and starts agitating and spinning at the same time during the wash cycle. This causes the water to spill over the top and run out the bottom.It...
Sorry that does not sound right,,. there should be interlocks that stop agitating and spinning from happening at the same time. go to the dealer you bought it from and tell them and there may be a recall for your problem and they may replace your machine at no cost or low cost to you no matter how long you have had the machine,at least in theory..
Oct 19, 2009 | Amana Washing Machines
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
My amanda washing machine
My amana washing machine will not unlock
Mar 21, 2008 | Washing Machines
Model LW6501W2
Sounds like the outlet pump has siezed up due to having been stood for so long. You may need to take the pump apart, clean the shaft & reassemble. Or, you could try a spray with WD 40 on the pump. TURN POWER OFF FIRST
Oct 26, 2007 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
