Question about Canon PIXMA MP830 All-In-One InkJet Printer
We have put in all new ink cartridges but the black ink cartridge for documents still will not print. We have tried cleaning and deep cleaning twice to check the nozzels but that does not seem to solve the problem. We have checked the ink levels troubleshooter and it says that the ink levels are adequate - any tips on what we can do next?
  • Canon Master
  • 1,381 Answers
Hi lukebrander
Try reinstalling the sofware / driver .
Delete first the Driver in Device Manager and the software in Control Panel / Programs .
Discconnect the device .
Reboot .
Reinstall software / driver. Reconnect your device and wait for confirmation of successfull operation .
Don't have the install disc ? Download the Sofware / driver from here :http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp830#DriversAndSoftware
Select the correct OS before proceeding .
Regards ,
fanaudi
Posted on Mar 11, 2011
  • 1,218 Answers
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
I replaced the black 100xl ink cartridge in my printer, it is almost full, and was working fine before, now it will not print and only gives me blank sheets. the colored cartridges work fine just not the...
Try to do the Deep Clean Printhead function on your printer. On the printer touchscreen, touch Ink Levels > More Options > Deep Clean Printhead. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please contact the Lexmark Technical Support Center or point your browser to http://bit.ly/lFKDzs for online technical assistance.
Sep 12, 2011 | Lexmark Prospect Pro205 Wireless...
Black is not printing
Try this to unclog printhead.
take out cartridge, locate the hole where ink goes trough, put a can of compressed air and blow it.
put some paper under the printhead to catch ink.
Jan 14, 2008 | HP Business Inkjet 1200dtn Printer
I have a Canon pixma mp990 Recently it has stopped printing with the larger black ink cartridge that is meant for printing text (PGI-220BK) All the other cartridges print fine I was using a non-canon...
It looks to me that your non Canon cartridge has blocked the print head. I see this all the time. Remember the compatables are not pigment based but just watered down ink so you can get it to flow through a syringe into the cartridge. This however is the classic outcome of trying to save a few pennies on an expensive bit of kit!
Jul 30, 2011 | Canon Office Equipment & Supplies
I have just changed my black ink cartridge however still patchy
Typically you do not have to change the color cartridge when you replace the black cartridge.
As far as the spotty printing, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which printer do you have?
Please rate this solution. Thanks.
Oct 07, 2009 | Office Equipment & Supplies
Changed ink cartrigde and printer no longer printing.
microsoft logo is in colour and so its printing while everything else on test page is black so its not printing. the problem is common.you need to do automatic deep cleaning for the ink flow to start once you install new cartridges.go to printer maintanance option and click the option deep cleaning .it will pull out the ink in printer head and it will start working.sometimes also requires cleaning twice. thanks and do not forget to accept the solution.
Apr 03, 2009 | Canon BubbleJet i560 InkJet Printer
Printer will not print black ink.
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head..slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out.
5. Have severasl paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. May color and black and white print is back!
Hope this helps.
cw
Feb 16, 2009 | Canon PIXMA iP90v InkJet Printer
Canon MP830 printing with interlacing shades of black
your printer cartridge or head unit ink channel (some of color or black ink channel) constipated, you may try:
1) if your ink cartridge is not new, take out the cartridge put the bottom surface touch cleaner liquid(special for ink printer) or water for 1 hr (you can see ink spread water), then set back and test. refill enough ink maybe necessary.
2) still trouble, you need clean print head ink channel to do same thing above, if your print head is separated from the cartridge.
Feb 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
3e Black cartridge won't print
I'm not an expert but I go through a lot of ink.. I have found that even with new ink some of the tanks of ink aren't any good especially with compatible which i buy a lot of because it's a lot cheaper (ebay). With that ink I have gone through 10 cartridges in a row before finding one that worked correctly again (I mean out of 100+ cartridges hitting a run of 10 that where bad but the rest good.)
Also, a tech for epson once told me to hit deep clean 7 times in a row before a head check to clean their nozzles.. That has helped with my printer and at Fry's electronics, they have a cleaning solvent in kit, haven't tried it, but i have run alcohol through mine but I'm told that is very ******* the print head (dissolves the glue).
Hope that helped..
Apr 03, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
37 people viewed this question
old marine
old marine
