Question about HP LaserJet 3050 All-In-One Printer
Always showing the manual feed option when we printing. We would like to set it as automatic printing. How can we do that in default. Please help. We checked all the menus. example: in system set up paper type is any type and paper size is A4. Please help
  • HP Master
  • 1,915 Answers
If you are in Canada or US then you need to set the default paper size to Letter not A4. Most if not all software you use likely sends the print job in letter format. Because the printer is set in A4 it stops and waits for that size.
Posted on Mar 11, 2011
How do I change HP Laserjet 1100 to NOT manual feed under Printer Properties?
I suspect the printer is defaulting to manual feed because it thinks there is a page in the manual paper feed. Make sure no bits of paper debris are jamming the sensor.
Dec 03, 2014 | HP LaserJet 1100 Printer
My office has the bizhub c360, and when I put paper into the bypass tray, it prints from the main tray instead of the bypass tray. The settings on the printer are for bypass tray, the settings for my...
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
Printer has always worked great, gets lots of office usage, but now suddenly won't feed; the machine will turn on, when the print queue is activated, but just "clicks", won't feed and the error...
Try The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 27, 2010 | HP LaserJet 1020 Printer
Forces manual feed of paper whenever printing WordPerfect doc
Is a WordPerfect problem.
In WordPerfect go to file/page setup/select letter (or whatever)/edit/source - set to auto select.
Problem solved!
Jan 22, 2010 | Brother MFC-7820N All-In-One Laser Printer
Hp 4250 manuall feed heavy paper message
You'll have to set up the paper settings within the copier to reflect heavy paper for the bypass tray. You'll need to make this a default setting. Then when you print out with heavy paper via the print drivers it should pick up automatically at the printer.
Aug 28, 2009 | HP LaserJet 4250n Printer
HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Jun 25, 2009 | HP LaserJet 4700 Printer
HP LaserJet 1022 won't print unless i manually push button. it shows its set to automatic print, but doesn't work
Ceck your driver settings on the computer. It sounds like te driver is defaulting to MANUAL FEED instead of auto-select.
In some cases, deleting the printer from the computer, unplugging the printer's cable, restarting the computer and then reconnecting the printer may solve these types of problems. Follow the on-screen prompts to reinstall the printer's driver using the original disk.
Jun 04, 2009 | Office Equipment & Supplies
Dell 1700 only printing to envelope feeder
make sure that the manual feed tray is not set as default make sure you main tray is
Apr 30, 2009 | Dell 1700 Laser Printer
Paper source
I would suggest checking printer properties in the computer and ensure the paper size and source is Letter and set to Automatic Choose. Another choice may be to deleted the printer driver and re-install it. You can also go into the menu options until you get to Set factory defaults, press Select, then try the print job again.
I really suspect a program is controlling this from the computer.
To get a list of the existing printer settings, Select Menu and use the Right Arrow button until you get to Printer Menu Settings. The printed report should tell you what your actuall settings are. Maybe the default is set to Custom, instead of Letter.
The Set Factory Defaults option should fix most problems.
Good Luck John Moser
Jul 01, 2008 | Lexmark Optra S 1625 Laser Printer
Info print 1140
when you go to the menu of the printer is the paper TYPE set correctly?
tray 2 should be letter ( if using plain paper)
tray 3 legal, label etc...
and tray 1 should be any
May 18, 2007 | IBM Infoprint 1140 Laser Printer
HP LaserJet 3050 All-In-One Printer Logo
263 people viewed this question
Seeker5211
Seeker5211
