Question about Ricoh Aficio 1515 Black and White Copier
Problem is : follow instrctns in right cover to remove.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
Close right cover
Posted on Mar 11, 2011
Ricoh Aficio 750 (495 cODE
Ricoh 2016 show me
Nov 19, 2013 | Ricoh Aficio Office Equipment & Supplies
How to install transferbelt
  1. Remove or slightly pull out Tray 2 (RM1-1916-000CN).
  2. Remove three (3) screws, two (2) from the right cover assembly and one (1) from the left cover
    assembly.
  3. Open the front door
  4. Remove the right cover (RM1-1858-000CN), carefully twisting the front edges of the side covers
    outward to remove.
    NOTE :
    To make the removal of the right cover assembly easier, release the tab on the inside of the cover.
  5. Remove the left cover.
  6. Squeeze the white link lever on the left side.
  7. Remove the screw on the right white plastic catch, and then remove the plastic catch.
  8. Close the ETB.
  9. Remove the small black cable cover (RC1-5147-000CN) on the left side of the printer by carefully snapping it out of place.
  10. Remove one (1) grounding screw from the ETB harness.
  11. Pull out the white wire holder by pushing it up.
  12. Pull out the ETB connector.
  13. Remove one (1) screw from each hinge cam on both sides.
  14. Using needle-nose pliers, remove the hinge left cam (RC1-4249-000CN) and the right hinge cam (RC1-5311-000CN).
Remove the ETB. Use the following procedure to replace the ETB.
  1. Align each foot of the ETB with the respective holes, securing the right side first, and then the left side.
  2. Complete replacement by following steps 1 through 14 above in reverse order.
NOTE :
When replacing the right cover, align the tabs on the upper edge of the right cover and lower edge of the face-down cover with their respective slots.
Nov 19, 2013 | HP Color LaserJet 2600n Printer
Follow instrctns in right cover to remove
Probably is a paper jam. Make shore that you remove all the peaces of paper.
If you have any more doubt reply to me so i can help you
Mar 31, 2011 | Ricoh Aficio 2015 Copier
I am having a problem with the ricoh aficio mp 1600L printer. It shows message"Follow instrctns in the right cover to remove". We have checked everywhere there is not paper jam. We are very...
ok mate. when you open the right cover, there is a registration roller on the side. the registration roller is black one. it is visible from the side. rotate that roller and the paper should come up. rotate that roller with hand.there is a small piece of paper stuck below that registration roller which is not visible.
Nov 26, 2010 | Ricoh Aficio MP 1600L Black and White...
Keeps showing follow instrctns in right cover to remove. Unable to copy
ther is a paper jam in the machine, open the side cover and remove the paper jam, if the paper is not visible then there is a small piece stuck somewhere.
Nov 17, 2010 | Ricoh Aficio 2015 Copier
Trying to remove an alternator from an 06 altima
Removal and Installation L4-2.5L (QR25DE) Engines To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Engine cover
    • Front/right-side engine undercover
    • Drive belt
    • Alternator harness connector
    • Engine ground wire from top mount
    • Alternator upper and lower mounting bolts
  3. Set the alternator aside and remove the top mount.
  4. Remove the alternator.
To Install:
  1. Slide alternator in place.
  2. Install or connect the following:
    • Alternator top mount
    • Drive belt
    • Engine cover
V6-3.5L (VQ35) To Remove:
  2. Disconnect the negative battery cable.
  3. Drain coolant from the radiator into a suitable container.
  4. Remove or disconnect the following:
    • Radiator
    • Front/right-side engine under cover
    • Drive belt
    • Idler pulley
    • Alternator adjustable top mount
    • Alternator lower mount bolt and nuts
    • Alternator lower front bracket bolt
    • Alternator harness connectors
    • Alternator
To Install:
  1. Install or connect the following:
    • Alternator in place
    • Idler pulley
    • Drive belt
    • Radiator
  2. Replace the engine coolant.
  3. Connect the negative battery cable.
  4. Start the engine and check for leaks.
  5. Recheck coolant level and top off as needed.
Oct 15, 2010 | 2006 Nissan Altima
is it a miss feed problem? open the cover on the right cover of the machine then remove the jammed paper. then close the covers
May 26, 2010 | Ricoh Aficio 2015 Copier
How to exchange the ETB unit (belt) on a HP Colorlaserjet 2600n?
To replace the ETB Belt.. follow this step..but it would be easier if I can show u the diagram.. I will figure a way to upload. but let see if u understand here...
ETB removal and replacement
Use the following procedure to remove the ETB (RM1–1881–000CN).
1. Remove or slightly pull out Tray 2 (RM1–1916–000CN).
assembly.
3. Open the front door.
4. Remove the right cover (RM1–1858–000CN), carefully twisting the front edges of the side covers
outward to remove.
NOTE : To make the removal of the right cover assembly easier, release the tab on the
8. Close the ETB.
9. Remove the small black cable cover (RC1–5147–000CN) on the left side of the printer by
14. Using needle-nose pliers, remove the hinge left cam (RC1–4249–000CN) and the right hinge
cam (RC1–5311–000CN).
15. Remove the ETB.
side.
NOTE : When replacing the right cover, align the tabs on the upper edge of the right cover
May 23, 2010 | HP Color LaserJet 2600n Printer
Changing the fuser unit
1 Unplug the power cable.
2 Remove the paper delivery tray assembly
3 Remove two (2) screws from the right cover assembly
4 Remove the right cover assembly, carefully disengaging the catches
5 Unplug the control panel cable.
6 Insert a screwdriver to loosen the release tab on each side of the upper face cover
7 Remove the upper face cover
8 Remove four (4) screws from the upper cover
9 Lift up and remove the face-down cover
10 Remove the output tray by releasing the tabs.
11 Unplug the harness from the fuser motor
12 Open two (2) clips and remove one (1) clip to remove the fuser connector.
13 Unplug two (2) 3-pin optical encoder wires
14 Unplug the red high-voltage bias wire.
15 Remove the thermistor wire.
16 Remove the cables from the wiring harness.
17 Remove three (3) screws from the fuser chassis.
18 Gently rocking if necessary, roll the fuser forward to remove.
Use the following procedure to replace the fuser.
1 Align the fuser tabs with their respective holes.
2 Complete replacement by following steps 1 through 18 above in reverse order.
NOTE When replacing the right cover, align the tabs on the upper edge of the right cover
Hope this helps
May 16, 2008 | HP Color LaserJet 2600n Printer
HP 2600 fuser unit
6 Insert a screwdriver to loosen the release tab on each side of the upper face cover.
13 Unplug two (2) 3-pin optical encoder wires.
forward to remove.
May 14, 2008 | HP Color LaserJet 2600n Printer
Ricoh Aficio 1515 Black and White Copier Logo
226 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
