Question about Car Audio & Video
Want to reset my code for kenwood dpx-05md..coz i forgot my old password
shagone
  • 34 Answers
SOURCE: UNLOCK SECURITY CODE
for your kdc-mp528 will work whith code KCAR entered from the remote
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press and hold the "Auto" button and "Track up" (next track button on the right) on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
i hope this works for you.
Posted on Jan 08, 2009
SOURCE: kenwood ddx-6019 password
a friend of mine who is into bypassing stuff...found this method from sumwhere and it worked on my system...
u need to reset the system first by pressing the small button right next to <ATT> using a ball point pen or something pointed... once it reboots, keep the <SRC> button pressed till the display goes off, then while keeping the <SRC> button pressed, press the <ATT> button for 3 seconds, while keeping both of these pressed at the same time, press the small <RESET> button next to the <ATT> button using something sharp... this hard resets the system and it reboots to a blank screen, press the <SRC> button once and you have all the options working...
anything else, lemme know... varshik89@hotmail.com
Posted on May 07, 2009
SOURCE: kenwood DPX 9000 MJ CDplayer
Start type the code on the face preset button only 1 to 4 to let it appear this number start from 3110 and press Play/Pause button. do itz until it's get to 3119.... the code is 3112 but it'z quite hard....
maybe ur rite!! solution num 2, put it in the trash!!!!
Posted on Nov 12, 2009
sWatti
  • 188 Answers
SOURCE: RESET PHONE
If you have forgot your phone lock code and you want to unlock it or wnt to reset your phone,
then all you have to do is to type this code at your normal dial screen:
#7465625*2877#
(Note:This code will reset your phone to default settings
and all your data that is stored on your phones memory will
be erased,so store your important data on your memory card before you type this code.
Posted on Dec 14, 2009
Testimonial: "thank u!"
SOURCE: kenwood dpx-501
I just solved the problem with my kenwood dpx mp 2090U - (looks similar with 501). FL Display with single CD, USB, 2 Din.
I should share this......... as I received the clue from someone that share the same case to me . Thanks to Mr,Nasirbaek from Indonesia,
The problem is at the main board . Dry (bad) soldering occurred. There are more then 5 resistors in series configuration. The resistor is quiet big (1.5mm x 3.5 mm, surface mount type R) about 2,7Ohms.The position is start from near usb port cable and ended to near big transistor (1 x 1.5 cm power transistor). After resoldering check with multitester to make sure that all R are connected in series configuration.
Just open 3 screws to access the main board. 1 at the top case. 2 at cd assembly, then Carefully take out the CD and the CD ribbon cable.
good luck.
Posted on Feb 21, 2010
Kenwood dpx-u70 security code?
My radio car dpx-u70 am forget my security cod how to disable this password?
Feb 22, 2013 | Kenwood CD / USB new deck DPX-U77
I bought a kenwood dpx-6020 from a friend and it asks for a 4 digit code when it's turned on, how can i retrieve that code or reset the code.
check in the back of the unit or on the back of the face plate for a reset button. If all else fails go to that brand web site and search for the user guide
Jul 28, 2011 | Kenwood DPX-6020 CD / Cassette Player
My Car Stereo Kenwood DPX 7021 MPI displays CODE, this happed after I changed the car batterry.
I HAVE INSTALLED THIS CAR STEREO IN MY CAR AND IT IS ASKING FOR A CODE. I DO NOT KNOW WHAT TO DO. CAN YOU GIVE ME THE CODE FOR KENWOOD DPX-7021MPi CAR STEREO PLEASE.
PLEASE HELP ME
Feb 12, 2011 | Car Audio & Video
Need password for Kenwood DPX-MP2090. Serial Number Y39-5150-25.
My son set a code for my DPX-MP 2090 car system and forgot the code. I am trying to enter the possible codes but do not know how to enter after putting the code on display. is there a way to go about it?
Nov 22, 2010 | Kenwood Car Audio & Video
USER MANUAL FOR A KENWOOD DPX 5000 DOUBLE DIN CAR STEREO
hi
i want rest code kenwood dpx 5000 car tape plz reply mee with master rest code
thanksssssssssssss
Mar 08, 2009 | Kenwood Car Audio & Video
Kenwood KDC-722
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Dec 25, 2007 | Kenwood Sirius KDC-722 CD Player
Forgot my password on my kvt 715 help me please
Type 1
Type 2
Type 3
Dec 13, 2007 | Kenwood KVT-617DVD Car DVD Player
Kenwood dpx - 5200M cd/cassette player
NEED TO GET THE FLEXIBLE RIBBON CABLE PART NUMBER FOR KENWOOD MODEL # DPX5200M
Nov 11, 2007 | Kenwood DPX-5010 CD / Cassette Player
Car Audio & Video Logo
137 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
