Front screen is cracked, the plastic part? First layer. Is it possible to just get a replacement?
  • 1,238 Answers
Try to see on eBay.com if there's a replacement
Posted on Mar 11, 2011
I have screen protector on my HTC hd7 and I have small crack on the corner (vertical) right lower. Can be repair?
Hello
The screen of the hd7's is made using corning's gorilla glass. Technically but also simply put, it's made of a single sheet of glass, spreading along all the front side of the phone. Glass is being used since it's more resistant to scratches and is a good electrical insulator, a needed property in the making of capacitive type touchscreens.
If you have a crack, most probably the surface area was broken due to some mechanical shock. Like any piece of glass, once broken it can't be fixed, it doesn't work like fixing a scratch on a plastic cover by polishing it. In fact i recommend you to leave it like this and try to cover it with the screen protector. The surface on the glass layer contains a special compound of transparent conductive polymers used to register screen taps. Actually this is what you touch when using the screen. It's not recommended that you try to polish the screen because you can accidentally remove this layer.
So, again simply put and sorry to make it this way, the wisest thing would be to either try to live with it or change the digitizer layer (glass front cover) but the last option can prove to be a bit expensive. Again, sorry for not being able to provide a more nicer solution.
Jul 20, 2011 | HTC HD7 Cell Phone
My room mate spilled his drink and a little went on the bottom left corner. i dried up as much as possible, but now there is a dark shadow spot on the screen in the bottom left. how do i remove the screen...
liquid is never good on those screens-
there are 3 layers to the screen, from inside out, a fresnel screen (etched circle pattern), a lenticular screen (ridge lines top to bottom), and a protective screen ( "Diamond Shield" tinted plexiglass).
the fluid will wick up btween these layers, turn black, then very very slowly recede leaving a waterline mark. It can take months for it to become un-noticeable.
cleaning is possible, but beware, any type of cleaning fluid or spray is going to simulate the exact same problem but to a larger area.
also introducing dust, lint or hair into the layers when separated is almost impossible to avoid.
these pieces, especially the lenticular screen are extremely fragile nylon plastic and is apt to split under its own weight when handling, so beware the project you are about to get involved in...considering the large size.
but it can be done.
Remove all screws around the screen frame from the back of TV and the lower sides. There will be a wiring harness that goes to front buttons- disconnect it. The whole assembly will come off the front of the TV.
Lay it on the floor face down. Remove the screws in around the inside of the screen. The screens are now ready to lift out, one at a time.
IT IS IMPORTANT to not attempt this by yourself. The screen are fragile and large and scratch so easily which appear as a white opaque area when reassembled. Have a helper. Wear cotton gloves while handling as finger prints will be noticeable after you reassemble.
ALSO IMPORTANT- these screen are oriented front and back...in other words they go together in a certain direction...on each screen layer there is a small sticker on its outer edge. Make note of its orientation and reassemble accordingly.
Clean with a cotton cloth and very very little "plastic glass gleaner" (if needed only!).
WIPE EXTREMELY GENTLY in the direction of the grooves on each screen layer- much like cleaning an old vinyl record.
The lenticular screen is the biggest worry as rubbing on the grooved side is so likely to cause damage. Perhaps rubbing should be avoided if possible.
Let them lay out and dry before reassembling. A bottle of compressed air is good to remove debris when layering them back together...a dust free environment is recommended.
Reassembly and installation is just the reverse of dis assembly- remember the wiring harness connector!
Apr 13, 2011 | Mitsubishi WD-73733 73" HDTV
Can the screen be replaced once it is cracked
Yes, and most times the screen is plastic and made of 2 or more layers. You may be able to just remove the cracked piece for now unless all the layers were cracked...
Oct 22, 2010 | RCA P52926 52" Rear Projection Television
The touchscreen of my Z22 is broken
The Z22 is a bullet-proof device for securely saving your personal data, and full marks go to the team at PALM for its solid design. However, the AGE of the Z22, over the last decade, results in 3 problems - the batteries are all dying, and the delicate plastic touchscreen top layer is deteriorating - simply through AGE. When you say the touchscreen is "Broken", I would guess you mean that it does not respond to touch commands from the black plastic stylus that sits in the slot on the back, side, of the unit, when stored. I have never actually seen or heard of a screen that is physically "broken" - like the thousands of iPod, iPhone, Motorola RAZOR, and other touch screen phones that you see today, with cracks running across the broken GLASS. It "Could" happen that the glass screen under the top plastic touch layer is, actually "BROKEN", with the resulting cracks, but this is unlikely, since the trim around the screen is raised a HUGE distance, compared to today's touchscreens.
You can easily replace the screen for $9 if you wait for free shipping from CHINA, or, you can try a few tricks I learned on my Z22 over the years. I have put it in the freezer - which worked temporarily, heated it with a hair dryer - which worked temporarily, and peeled the top plastic layer off the screen- which worked temporarily. I have also replaced the screen with a new one. It is IMPERATIVE to put a hard plastic cover on the Z22 at all times- or you will eventually loose the screen again...
My Z22 page is at:
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
I hope this helps you to get your Z22 back up and running
have fun
good luck
robin dusty graves
Z22 PALM PILOT touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-0.jpg touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-1.jpg touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-3.jpg
Dec 12, 2009 | Palm Z22 Handheld
Cracked screen..do I need to buy an entire new one?
Check with Pioneer and see if it's still under warranty. Otherwise it's not going to be cost effective to fix.
Mar 18, 2009 | Pioneer AVIC-D3 Car DVD Player
Touch screen not working from right side
You have damaged the touch sensitive top layer. Can you see any cracks? It is possible to replace just this top layer as opposed to replacing whole screen which is very expensive of the order of $50.
The touch screen should cost less at $10 plus labour
Jan 08, 2009 | Motorola Mobility MOTOROKR E6
Crack inside of screen
This screen has multiple layers of plastic before you get to the main screen, if the picture isnt affected, you've only cracked oneof the plastic pieces, these are cheap to replace
Dec 31, 2007 | Philips 51PP9100D 51 in. Television
BROKEN SCREEN
I had the same problem I had to get a UX26083 from Ued.net. now i can't install it!
Dec 30, 2007 | Hitachi 65F59 65" HDTV
BROKEN SCREEN
Order one from Vance Baldwin Electronics at www.vancebaldwin.com.
Dec 21, 2007 | Hitachi 51S500 51" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
