Question about Samsung Computers & Internet
Hard drive slowed down after i tried to add another hdd. It takes 2 hours just to get to windows xp splash screen. How do i speed it back up
  • Paul Bade Mar 11, 2011
    What interfaces do the drives use (IDE - ATA-5 or ATA-6, SATA ...)? If the drives are IDE, are you using Master/Slave or Cable Select identification?
    Is this perhaps a newer system with the Intel "Sandy Bridge" chipset, using SATA hard drives? There is a flaw in the first run of this chipset that causes deteriorating performance problems with the SATA interface, particularly with multiple drives connected. If you have this problem, Intel and your motherboard manufacturer will repair or replace it for you.
  • nickkiblue Mar 11, 2011
    Yea i did that no luck! See i had a ide hdd that was faster than the one in there and i had no idea i couldnt do that! Im using a hiren disk to fix all my other issues
  • 917 Answers
I guess you have tried the obvious first step of removing the second drive you added. If not, then that is the first thing to do. You have not provided details on thetype of drive you already had and the type of new drive.
There are two (main) types of drive - PATA or IDE whcih use a 80-way ribbon cable (P=parallel), and SATA which uses a small 7-way flat cable (usually blue, S=serial).
SATA is the easiest to install and will generally always operate at high speed without any setting up.
If you have a PATA already installed and you want to add another PATA, you can either connect the second drive to a separate ribbon and the secondary IDE connector on the PC or more usually you would connect it as a SLAVE on the same ribbon as the first drive (because the secondary IDE is probably being used for a cd/dvd drive).
If you are connecting the second drive as a slave, it is important to make sure that the first drive correctly set as a master via the jumper links on the drive, and the second drive is correctly set as the slave drive. The 80-way ribbon is also labelled with connectors for MASTER and SLAVE.
Another important thing to remember is that a PATA drive MUSTuse the 80-way ribbon in order to work at the higher speed. If you replace this with the older 40-way ribbon then the drive will only work in PIO mode instead of UDMA mode and will become too slow for Windows XP to operate effectively.
If your drive is PATA then when you eventually get into Windows XP, right-click on MY COMPUTER, select MANAGE and then click on DEVICE MANAGER. There will be an entry in the right-hand side for IDE ATA/ATAPI controllers. Click on the (+) next to this and then double-click on PRIMARY IDE CHANNEL. It may take some time for a new window to open. On the PRIMARY IDE CHANNEL PROPERTIES window click on the ADVANCE SETTINGS tab. DEVICE 0 is the first or master drive, DEVICE 1 is the second or slave drive. Both should be set for DMA transfer mode and the current mode will be displayed underneath, which should ideally be UDMA mode 4 or 5. Even DVD drives should have a UDMA of 1 or 2.
If either mode is set to PIO then you have a problem. Check all cables and settings as previously described. click cancel on the properties window. In the IDE ATA/ATAPI controllers list, there should be an entry for the Ultra ATA storage controller. If there isn't then again you have a problem, but in this case it is a driver issue. Try removing all entries in the IDE ATA/ATAPI controllers by right-clicking on the entry and selecting UNINSTALL. Re-boot and hopefully Windows XP will re-install the drivers and set the drive correctly.
Also check in you BIOS for any IDE settings which may be PIO mode (not usually available, but you never know!)
Posted on Mar 11, 2011
  • Samsung Master
  • 27,725 Answers
Try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive)))
then click start all programs accessories system tools defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
hope this helps don
  • 40 Answers
Scandisk (Check Disk) for errors.
Sata hdd very slow
hard drive maybe slow 5400rpm not 7200 rpm check drive speed on them
Nov 08, 2013 | Intel D101GGC Motherboard
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
Hello there: really just looking for some solid advise this hp52w w has the original xp operating system in it with sp2 installed works ok but it gets so slow on the starting windows screen it takes...
Hello Mike, Hi, may I suggest you try first to defrag your hard drive, Im sure when you power on your PC, the hard disk led keeps on blinking, your hard drive may have developed bad tracks and sectors, this slow moving process tends to go forever.
Defragmenting and checkdisk can find faults and bad sectors and tracks that slows down the performance of your PC.
Reformatting should be done if your defragmentation procedure fails to speed up your PC.
Try to run an antivirus program, which may help speed up your PC by detecting viruses, that tends to load forever, or slow down the booting process.
Nov 24, 2009 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
Possible ST380011A hard drive crash
it really looks like your hard drive is giving up on you. happend to me a few times so far (have a shitload of copmputers) and happends only with drives i get sent via UPS. when i order them via FedEx they last so long until i replace them due size limitations. Looks like UPS thoses them around harder. i thnk i read once that they drop the packages pretty much all the time from about 3 feet in general. create an image of your harddrive while you still can and just transfer it onto a new one and you will be all set.
Aug 01, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Dell Vostro 200 desktop with Windows XP is not able to handle two
Vista doesn't generally like to be installed on a hard drive that big. Well, Windows, in general doesn't.
And, from the sounds of it, you didn't install Windows on your new primary 1.5TB drive, you just copied it from the 500GB drive, which won't work.
Here's what you should to, to solve this:
1) Swap out your 1.5TB drive with the 500GB drive again.
2) Swap out your secondard 1.5TB drive, with the new one.
3) Create a partition of 120GB or less on that drive
4) Install Windows on the new partition.
5) Put the other 1.5TB drive back in, as secondary.
Once that's done, you can swap out the new 1.5TB drive with your Windows partition on it, in place of the 500GB drive.
When you boot, Windows may ask you to select which operating system you want, just select Windows Vista, and you should be good to go.
I had a similar issue a few years ago, when I tried to install Windows on a 1TB drive, and couldn't get it to work. Once I partitioned a smaller space, it worked like magic.
Mar 20, 2009 | Dell Vostro 200 Desktop Computer Intel...
Installing XP home edition with SP2: Won't recognize hard drive
Hell, Sorry to hear your having problems your analysis sounds correct but lets make sure it's not something else first. Can you give me more details on the drive Brand, IDE/SCSI, model number. Do you have access to a computer with a CD burner?
Mar 16, 2009 | Microsoft Windows XP Home Edition
The system has slowed down considerably since I loaded XP
chek the hdd driver as well
expensive hdd maybe need extended driver
chek your hdd sectors too
maybe there any bad clusters in your hdd
and check for your windows too
mybe it's need to reinstall it again
please rate
Jan 20, 2009 | Evesham Axis PC Desktop
Dell xps 600 windows booting problem
You would probably do right to reinstall Windows. The bios handed off to Windows long before the splash screen comes up. It is probably a faulty driver or corrupt registry entry. If it was me I would reload Windows
Dec 01, 2008 | Dell XPS™ 600 PC Desktop
Windows xp home does not boot
Replace the HDD.
You don't want your precious data on that drive.
Nov 08, 2008 | Maxtor Hard Drive
Problem with Window XP Home Edition
Freddie, It sounds like a serious Virus infection. If you can start it in safe mode. Do so. and run your virusscanner, and adaware or spybot,if you have them installed
Please let me know how you make out. Thanks.
Feb 22, 2008 | Computers & Internet
Computers & Internet Logo
119 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
