Question about FixYa Service
While answering question how to insert was this helpful yes or no option in the answers
  • lalith kumar Mar 11, 2011
    i have answered some question and i didnt find the rating button below my answers
  • Anonymous Mar 25, 2014
    Not sure if my answer was posted just answered one on craftsman mower getting gas in plug. Very important that the problem is not only fixed but needs to know why the problem exist DANGEROUS SITUATION.. THANKS.
    Brigadier General:
  • 7,191 Answers
Hi Lalith,
The rating buttons (see attached image) are automatically added by FixYa at the end of all solutions.
Hope this answers your query.
For more help and clarifications, please feel free to reply to this post. Thanks.
Posted on Mar 11, 2011
Testimonial: "Thanks for your help"
  • AliTech110
    AliTech110 Mar 11, 2011
    Thanks for the reply.
    Only the askers or the persons viewing the solutions are able to see the rating buttons.
    For example, you can see the rating buttons below this solution, whereas I am not able to see the buttons under my solution. This is to avoid self-rating by the experts.
    Thanks again.
How do you reset the memory card?
From the settings, scroll down to memory card options. Select and choose re-format.
You can also reformat the card from a computer by the standard formatting tool and insert it in the camera. When the camera pops up a dialogue box - asking you for permission to format the card, answer Yes. you are done.
Aug 31, 2014 | Cameras
Tip
How to do Fast and unattended setup of OS
Here I have an Idea for primary setup of a large lab quickly. Suppose you have to setup a lab where have more than twenty or thirty system but must setup it quickly. At that time if you don't have enough CD Rom drive or not enough OS installer CD then the task will take a long time. To save time at the same moment I like to prepare an unattendent operating system installation. Before this task I must check for presence of some requirement. Verify for unattended Installation: To perform an unattended installation from a CD-ROM, the following conditions must be met:The computer must support booting from a CD Rom The unattended answer file must be renamed to Winnt.sif and copied to a floppy disk so Setup can access it. So must need a floppy disk drive.The answer file must contain a valid [Data] section. This is explained later in this article. Before installation it has some conditions:
1> the installation is limited to a single partition.
2> you cannot specify third-party drivers during Setup Prepare For an Unattended Installation:
To prepare your computer for an unattended installation from a CD-ROM, I've followed these stepsFirst I've created a Folder in local drive & shared it. Then I create setup manager.I install Setup Manager by following these steps:I Open My Computer, and then open the SupportTools folder on the Windows XP CD-ROM.Double-click the DEPLOY.CAB file to open it On the Edit menu, click Select All.On the Edit menu, click Copy to Folder.Click Make New Folder. Type the name that you want for the Setup Manager folder, and then press ENTER. For example, type setup manager, and then press ENTER.Click Copy. Open the new folder that you created, and then double-click the setupmgr.exe file. The Windows
Setup Manager Wizard starts: alokerdas_2.jpg
Then I Use Setup Manager to Create an Answer File.
I open the setup manager & go to create a new answer file.
Then I go to the unattended installation & windows version option.
I have selected the fully automated option & create an answer file.
If you want Windows Setup to delete all partitions on the hard disk and to create a new partition, you must include the Repartition command in the Winnt.sif file. Under [Unattended], insert a new line, and then type "Repartition=Yes"
If you omit this line, you are prompted for the installation partition.
Add a [Data] section with the following entries to the unattended answer file:
Unattended Install=Yes - Value must be set to "yes"
MSDos Initiated=No - Value must be set to "no" or Setup stops during the graphical portion of Setup
Auto Partition=1 - If the value is set to 1, the installation partition is automatically selected. If the value is set to 0 (zero) you are prompted for the installation partition during the text portion of Setup.
Save the unattended answer file as Winnt.sif on a floppy disk.
Insert the Windows CD-ROM into the CD-ROM drive, and then insert the floppy disk into the floppy disk drive.
Change the boot order in the CMOS so that the CD-ROM is first in the list.
Restart your computer. When Setup is started from the CD-ROM, the Winnt.sif file located on the floppy disk will be used to complete the unattended installation.
<SPAN style="FONT-FAMILY: 'Courier New
on Feb 15, 2011 | Computers & Internet
How do I turn off the auto answer for the fax option----The fax sounds if I manually answer the telephone
Press the auto answer button until the button lits off/button light goes off.
Or got to front panel press set up button
go to basic fax or advance fax
look for auto answer and choose off
power off then turn the printer on to make sure the settings takes effect.
hope I helped you in simplest way I know
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have a nds lite not recognising any games inserted into it(original ds games) just says no game inserted......yes i have blown on it yes i have tried several other games and they all say the same thing,...
The reader is probably dusty. Try to blow in it to release dust then get a clean small cloth and wipe both the game card and the readers in the console.
Mar 06, 2011 | Nintendo DS Lite Console
Have inserted new card in camera. When go to print does not do so. Should I insert and then format?
Yes you must always format a new card. Joe
please rate my answer as very helpful. thanks
Apr 17, 2010 | Kodak EasyShare C310 Digital Camera
The system cannot find the file specified
You don't mention what Operating System you are using.
If its Vista, just insert the Restore CD, and afetr answering a couple of questions, the CD will ask you if you want to repair the boot file.
Select yes, and Windows Vista will do the rest for you.
If you are using Windows XP,
It appears that you have a corrupted or missing file, probably due to a bad shutdown, or an infection of some sort.
You should use your RESTORE CD, and boot from it.
Select the Repair option, and perform a CHKDSK /p command.
This command will not only check for your disk integrity but also check and replace basic files needed for your computer to start up properly.
Please don't forget to rate this answer if it helps
Jul 22, 2009 | Computers & Internet
Problem with dell d510 bios password
Go here http://www.download.centre4service.com/software1.html
and downloaded the DSTCD.ISO (you will need a program to burn ISO image) and install it to CD.
Or There is a bootable USB option.
and floppy disk option. Just choose the best one for your situation
Insert CD,USB drive,Or floppy disk, Restart computer,
Enter Boot Menu(should be F12).
It will Asks if you want to modify or erase Service Tag. Answer Yes.
It will ask other system questions, answer yes to all.
Restart and look in the BIOS to make sure password has been removed.
May 06, 2009 | Dell Latitude D510 Notebook
Fax picking up over phone number
Do you have an Answering Machine?
If yes then the Rings to answer on the Fax should be more than the rings to answer on the Answering machine.
Press the Setup button on the Printer and then go to Basic Fax setup and you will get the Rings to Answer option there.
May 25, 2008 | HP Officejet 5610 All-In-One InkJet...
MS Access
This will depend upon the question/option made. Anyway, sum / count the number of option having same answer and take the percentage. You will surely see how to make the conclusion.
May 05, 2008 | Microsoft Computers & Internet
Auto Answer
Hello PattiPaige,
The feature to disable answering the phone when you open the flip can be found under:
Settings & Tools
- Call Settings
- In Call Setup
- Answer Options
- Set option to Off
This will disable the flip from answering the call when opened.
As for increasing the font size, i don't believe there is an option to do so. If I become aware of one I'll try to get back to you on.
Hope this helps,
cHiPz
Mar 24, 2008 | Motorola Mobility RAZR V3
FixYa Service Logo
48 people viewed this question
Top FixYa Computers & Internet Experts
Mark Magill
Mark Magill
Are you a FixYa Computer and Internet Expert? Answer questions, earn points and help others
