Question about Brother DCP-330C All-In-One InkJet Printer
What do u need to do scan back to pc - Brother DCP-330C All-In-One InkJet Printer
  • 135 Answers
You have to install the software package that comes with the Printer when you purchase it. Alternatively, if the drivers already installed onto the pc...just go to Control Panel->Printer and Other Hardwares->On the right hand side you will see the Scanners and Cameras->Double click on the icon of the Brother scanner then you can scan now.
Posted on Mar 11, 2011
Can't scan from hp 6500
Hi there
You need a program that you can use on your PC with this program you scan it to your PC and then print it out, ok you need a program like art or photo or paint or some thing like this that have a scan in it.
Read more below.
The best program to put on your Pc is what I use and it is Free you, it is called PagePluse SE, you should try it you can do all sort of things with it but there no scan on it, just scan your photos to the your pc with another program witch has scan on it and put them in the SE program and you can do any size you wont and after adding text to it or backgrounds you can send it to the printer and print, an other program I use for scanning from the printer to the PC is called PainShop Pro 7 witch is a old program there newer ones out now but I am happy just using the old one it does the trick.
The Free version is Called PagePluse SE you not need the version 9.
Ok here the link to download the PagePluse SE program and it not a free trial it a free, there is one you can Buy but this is all you need download the free one it just as good.
Click Link = http://www.freeserifsoftware.com/software/pageplus/index.asp
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 15, 2010 | HP Officejet 6500 Wireless All-in-One...
Can't scan to file on PC
try powercycling the printer ( while it is on pull out the power cable wait 15 seconds and plug back in also check the driver under printer properties that bio directional support is on else you will need to re-install the driver
Dec 15, 2009 | HP Photosmart C5280 Printer
Scan from printer through router to pc?
You will need to use the TWAIN software for the printer. From the computer you will be running the scan options thru the TWAIN software. Then the scan files will be pulled from the printer back to the computer. Running scan options directly from the printer will give you the option to print the scan files or send them to a memory card if your printer has a slot for one. If the scanning software is not installed on your computer then you will need to download it from the manufacturer's website.
Sep 22, 2009 | Dell 1815dn All-In-One Laser Printer
Scanner
to be able to scan to pc you have to have the scan file utility set up on the pc
the scan file utility is on the CD that came with the copier.
you can Google the file if need be
when you have loaded the file you will need to go to
start, all programs,kyocera (scanner file utility and open it
once in configuration you will need to do the following
select setup
on the top you will see a box, type in 001
file destination, you should hit the box next to this and select kyocera/scan file
press ok and you are done
Next
get the ip address of the scanner, you will find this in scanner default when you have pressed thecounter/system menu button
get back into normal copy mode
on your web browser type the scanner ip into the address bar and you will get into the scanner command center
press the start icon bottom left of your desktop, go to run and type in cmd
once in dos mode type in ipconfig, this will give tou the destination address for your scans
now back to the command center, select sender info (left side menu) and type in kyocera after selecting 001 (blue numbers) and submit
then go to destination setup (scan to pc) and under 001 (blue) enter the relavent info, the address will be your pc's ip address.
say no to all password requests
and submit
very important now is to close the browser as you cannot scan when the command center is open
please take the time to rate this fix
Mar 27, 2009 | Kyocera Office Equipment & Supplies
My scanner is not scanning
I would try unplugging the usb when the pc is off then plugg it back in when the pc is on. This may work if the pc is xp or vista but if not you may need to reinstall the drivers.
Jan 11, 2009 | HP LaserJet 4 plus Printer
C5200
Do you have HP solution center installed on the computer? You need this software on you PC to scan correctly. You can download it from HP here:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=c5200&submit=Go+%BB
Just pick the exact model you have and correct operating system (Windows XP, Windows 98, Mac OS 10.5) then pick the bundle/full feature driver and install that and your scanner should allow you to scan to you PC. You may find it less of a hassle to scan from the PC by using HP software and selecting scan.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Can not get scanning to work over a wireless/network
The ip address for you scanner is already set. If you are able to print to it over the network than you will be able to scan from it over the network. The trick is that you will need to initiate the scan from your pc and not from the scanner. Look in your program files and find epson scan. there you will find epson scan setings. open this up and select a scanner, the cx11nf. Tell it that it is a network scanner and allow the program to find the scanner. Once found, you will need to test it. If you get full communication back from the scanner than you are connected and can then use epson scan to scan your documents and pictures to file.
If you cant find epson scan than you have not loaded the program and will need to reload the program.
Gremlin11
Nov 13, 2008 | Epson ACULASER CX11NF All-In-One Printer
Scan to pc
On my version of the hp software I can quite easily do this.
You will need working email software on your pc, so to scan the image, ensure that the pc is connected to the scanner and the pc is switched on - with all the HP scanning software installed.
Press the scan button on top of the scanner, with the document inside the scanner faced down.
When the HP Software pops up on the PC - the scanned image should appear. You can then click the email as attachment button in the HP software.
There are many ways to do this operation. So if you get stuck then let me know I we can go into more detail.
Please don't forget to rate.
Jul 04, 2008 | HP PhotoSmart C4180 All-in-One Color...
Brother DCP-330C All-In-One InkJet Printer Logo
70 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
