Question about Roper RS25AEXLQ Side by Side Refrigerator
My roper rs25aexlq00 top freezer refrigerator is leaking at the water dispenser. When you press the lever water runs along the side and almost everywhere but in the cup. I can see that the water line is cracked, but how do i open dispenser face in order to pull new water line through?
2 Suggested Answers
SOURCE: Roper refrigerator leaking from pipe
Thanks for your help! I have a tech coming tomorrow so I'll let you know what the problem was.
Posted on Sep 25, 2007
Constant, slow leak from water dispenser on whirlpool refrigerator
you might need to replace the bottom section and spare parts should be available readily online. I had a slow leak on my samsung side by side and it was resolved once i bought a new part...Hope this is of some use but not an expert.....
Jan 02, 2013 | Whirlpool Refrigerators
How do I remove the door with water dispenser from my Roper Side by Side Refrigerator
Turn water supply to refrigerator off and get a pan or towels to collect what water that will spill when disconnected. On each end of the quick connect coupling is a ring hold the coupling tight with one hand while pressing the ring towards the center of the coupling and then pull the water line out. When replacing the water line trim the part of the water line off where the ring was before or the line may leak once you reattach the water line. Press ring towards the coupling to remove and simply push the existing line after trimming into coupling and pull tight. The grip inside the coupling will lock the line in place. If you have questions please let me know, Thank You Sea Breeze
Nov 17, 2012 | Roper RS22AQXKQ Side by Side Refrigerator
No water from the water dispenser.
a new refrigerator has a water resevoir that has to fill up. you have to hold the water dispenser down for a minute or so to allow this resevoir to fill.
if you have done this already, then you probably have a bad water valve.
Jun 12, 2010 | Whirlpool GS6NBEXR Side by Side...
I have a Hotpoint HSS25GFTA BB. The water is not dispensing. I know the microswitch is making and water is pumping because I disconnected the tube on the bottom of the frezzer door and it squirts water...
Water is frozen inside the water tube that runs inside your freezer door. If you empty out the food in the door, you can use a hair dryer on medium heat to warm the frozen piece so it loosens enough the dispense out. Every 5 minutes, close the door and check if water dispenses. It takes between 15-30 minutes.
GE makes a dispenser water tube heater that attaches to the top of the dispenser tube to prevent frozen tubes. The part is WR49X10173. Check to make sure it is compatible with your refrigerator. Amazon and Walmart.com sells the part. Good luck!
Mar 16, 2017 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Refrigerator leaking water from freezer compartment, freezing along walls of freezer, but running water out under door
Sounds like the defrost water drain is plugged up. It could be a piece of food wrapper fell into it, or something. What make and model is it? Top freezer? Side by Side?
Dec 30, 2009 | Refrigerators
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
WATER QUIT RUNNING IN DOOR
Okay. My appliance is around four years old. The first time the water quit working was about a year ago (ice cubes / dispenser was fine). I just let it go and didn't worry about it. One day months later, I found it functional again. That lasted about a month or two, then it recently quit again. Tonight, I located the water supply line coupling under the unit on the left side under the freezer door, about five inches from the hinge. I separated the coupling (push lock type) and pressed the water dispenser lever. After a few seconds, the water flowed out just fine. I re-attached the coupling, turned the freezer coldness selector to 0 (off) opened the freezer door and fetched my wife's blow dryer. I ran the dryer along the inside of the freezer door near the black door seal frrom the hinge up to the water/ice dispencer compartment. I also ran it all along the back of the dispenseer compartment to the handle side of the door as I am unsure of where the water line runs. After about ten minutes of this, I attempted to dispense water with no luck. I continued with the blow dryer until the plastic and even the door seal were very warm to the touch. I closed the door and attempted to dispense water once again, and this time it worked. I turned the coldness selector back on. This time I set the freezer to 3 and the fridge to 7. I ran several cups of water through the dispenser since it's been sitting in the line for a while before drinking any. As for the "reservoir," I don't where or if one exists, but heating up the inside of the door from hinge to dispenser worked perfectly. Hope this helps someone!
Cheers!
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice/Water Dispenser in Freezer door not working when you press the lever. Also the light dims when lever is pressed. Icemaker working fine.
Sounds like a frozen waterline. I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Nov 28, 2007 | GE GSS20IEP Side by Side Refrigerator
Water is not dispensing but icemaker is working...
damaged water feed pipe at the bottom of the freezer door
Oct 22, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Roper RS25AEXLQ Side by Side Refrigerator Logo
26 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
