Question about Microwave Ovens
Oven does not reach the set temperature in bake. It shutts off prematurely.
  • 32 Answers
More than likely you have a bad Oven Temperature Sensor (probe). Depending on your model it is probably around $20 -$40 for the part and about 30 minutes to an hour to replace. Usually a pretty simple fix!
Posted on Mar 11, 2011
My kenmore wall ovens will not heat past 160%,
Check to make sure you haven't inadvertently set the oven to expect temperatures in centigrade (celsius). Otherwise you probably have a bad bake heating element, or else a bad controller.
Jun 29, 2014 | Kenmore Microwave Ovens
Please guys help me, every time i baked the cookies , its always burned :(
The oven temperature may be too high. Get an oven thermometer and set it in the center of your oven and check to see if the temperature on your oven matches it. Many ovens run 25 degrees or more off of the set temperature. My mother's oven used to need to be set at 325 if she wanted it to bake at 350.
If the cookies are black on the bottom, but doughy in the centers, this may also be a case where the oven temperature is too high.
Another problem may be that you are baking them too long. Cookie baking is a precise thing. It may seem duh-obvious, but be sure you use a timer, lol. If the recipe calls for 10 minutes, and they are always burned, start checking them at 8 minutes.
If you are substituting honey for the sugar in the recipe, remember to lower the oven temperature by 25 degrees and decrease the liquids by a small amount to compensate. Honey browns/burns much faster than sugar.
Hope these suggestions help. =)
Aug 25, 2013 | Amana Microwave Ovens
GE JVM1790WK convection microwave
I assume you've referred to your owner's manual to be sure you are operating the convection properly?
If for some reason you don't still have your owner's manual, you can get it here. See the tips on page page 30.
You can also do a hard reset by unplugging the oven for a couple of minutes, plugging it back in, then setting the clock and trying again.
If it's still not working, you may have a bad sensor or other problem.
Sep 04, 2012 | GE JE1590 Convection / Microwave Oven
GE Profile jvm1090ww 01 SN ZR958136 s Convection temperature does not get above 360F when set at 450F. Could never brown meat or bake.
The convection heater is control according to the temperature of the part n 3014 Thermister
Part Number: AP2025611 made by GE
So this is acting like a temperature sensor and it seem that is giving wrong indication to the control panel and switch off the heater at wrong temperature.
So you should replace the thermister.
You can find this and all a other parts of your oven in this link.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=216738&diagram_id=20027025#d20027025
Nov 04, 2010 | GE JVM1090WW Microwave Oven
I have samsung CE103VD microwave.could you plz tell me what temperature n what time should i set to bake a cake on convection mode?
I too have the same problem i try to bake cake and it turns to become biscuit or it dosnt cook in the centre
Sep 17, 2010 | Samsung MT1066SS Convection/Microwave Oven
My old GE oven (JSP38G052BG) won't bake or broil. It start then stop after 1 or 2 minutes. The heating elements get worm. Can you help me please
Hello ediben11.
If your oven's bake or the broiler heating elements won't heat but the range burners still work;the clock may be set for a timed or self-cleaning cycle. So,make sure to check the clock buttons and the knobs are set properly.
*If your clock has a knob that says "push for manual" then push the knob in after that, try the baking and broiling elements again.
*If it still does not work properly, you may have a defect in the thermostat/selector switch/common wiring.
*If the oven does not have a separate bake or broil selector switch; then the thermostat is probably the problem. It is not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Hope this helps.
Mar 23, 2010 | LG LMVM1945 Microwave Oven
Set covection baking temp / Thermador MCES
We have the owner's manual and have uploaded it to our site for you here.
Dec 24, 2009 | Thermador MCES MCEB Convection Microwave...
Wont heat
Hi!
Here are two instances when this happens---
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Feb 05, 2009 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Admiral oven E3V-81yr
I would contact Sears parts and give them the entire model # from the sticker inside the unit and they can get a manual sent to you.
Sep 30, 2007 | Kenmore 63672 Convection/Microwave Oven
Microwave Ovens Logo
26 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
