Question about Zanussi Washing Machines
WJD 1257 works fine but After 1&1/2hrs knocks of the main power fuse even if only on standby. I remove plug, put fuse switch back and all is well until the next time. Have tried the other socket but no difference. Any ideas? The main plug has been replaced to see if any difference. This has been going on fo nearly 2 years now but the occurences are increasingin frequency.
Try to see the capacitor of your the machine. The capacitor looks like a circle tube of plastic ware where the 4 wires are connected to it. it is only for the washing machine with the dryer. If it's only a washing machine the, the capacitor is only a single or only two wires are only connected. To test if that is the common problem, try to connect another functioning capacitor.
Posted on Mar 11, 2011
My sanyon dp47460 made strange noises then powered off and will not turn back on remote doesn't work either
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened look for puffed up caps like these on the power supply board.
Apr 19, 2012 | Sanyo DP47460 Diagonal HDTV
Logik LCX27WN2 switches to standby every time
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.4_12_2012_9_54_20_pm.jpg
caps in power supply puffed up on top like these
Apr 12, 2012 | Televison & Video
LCD tv switching itself off
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.4_10_2012_2_12_56_am.jpg
Look for puffed up caps like these in the power supply board.
All this info is just someplace to start and may or may not resolve the problem--it is where to begin.
Apr 09, 2012 | Televison & Video
My toshiba tv 32kc500b is not starting at all with remote or without remote
KV suggests it is a Sony and not a Toshiba?
general answer:
ISSUES:
Answers to issues:
Apr 01, 2012 | Televison & Video
KONKA KDL32AT23U 32 in LCD Television No back light, sound OK
Not likely it is the back light if you can eventually get it to come up.
Some general information (cap?):
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.3_29_2012_1_25_02_pm.jpg
Mar 29, 2012 | Televison & Video
Unit works fine. However when it is switched to standby for a few minutes or longer then powered up. Nothing happens. Cannot hear the click of something, i assume a relay inside the unit. If the unit is...
I got same issue. Solution is to buy a efergy standby eliminator plug so it can respond to the On/Off signal by cutting off and restoring mains power
Dec 20, 2009 | Yamaha YSP-800 System
TV works fine on analogue however won't work on digital even when re scanning. When it happened the television froze and then wouldn't work. Now all is has is "no channel available. Please scan" do you...
Power the TV off and uplug from the mains, now remove the aerial, now press the standby button the TV, now plug the mains back in and switch to a DTV channel, wait 5 secs and then put the aerial back in whilst still on that channel, now rescan.
If that didn't work, reset the TV to factory defaults and rescan again.
Thanks
Oct 08, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Stopped working
I had a similar problem with a jvc 8040. when I replaced the fuse it became very obvious that the b1560 output on the center channel was blown (smoke and sparks, always a dead giveaway). I haven't fixed the center channel yet but simply unplugged the center channel board and removed it from the unit. Now everything works fine except of course the center channel. Pre outs still operate just fine so a slave amp could be used for center channel power, or you could just go and buy a marantz amp; I did and then I realized that I was lucky that the old jvc quit.
Jan 27, 2008 | JVC RX-1028V Receiver
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Maxent MX-42vm10 42" Plasma
Generally, if a Plasma Tv is not coming out of standby, it means either the main board is faulty (most likely case) or Power Supply Board is not giving enough power to Main board to switch on the TV. In your case, I think it's the main board (aka Motherboard). Sometimes it's hard to tell to whether ceremic fuses are blown off by looking at them, so it's best to check with a multimeter. Check the fuses in the PSU and also whether it's outputing correct voltages. Also, can you hear a clicking noise right after you've switched on the TV or pressed the power button in the remote to make the Tv go from standby to ON. A clicking noise means one of the boards is shorting out. In your case, I don't think you'd hear a shorting out clicking noise, and I think replacing the Main board will get you out of standby.
Jul 27, 2007 | Maxent MX-42VM 42 in. Plasma HDTV
Washing Machines Logo
114 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
