Question about LG Wireless Media Transmitter Box Anwl100w
While watching a DVD on my new LG 60" PK750 TV through my new LG AN-WL100W in the HDMI 1 mode the AN-WL100W keeps going into the AV2 mode which stops me from watching the DVD. If I shut the TV and Media player off. I can then get back into the HDMI 1 mode for a while before it will again go back to the AV2 mode. Please help. Thank you
  • LG Master
  • 11,800 Answers
A wireless device never works continuously, it sends and receives the data in bursts / packets , and the HDMI will follow this pattern. In between them the system sits practically idle. If the time between the bursts is too long the device might think that the HDMI cable has been disconnected and switch to the next available connector - AV2.
Since this happens while you are using it correctly (the cables are firmly inserted) with a bandwidth demanding signal like DVD then your unit is defective and it should be replaced.
But, unless your tv is in a place where it's absolutely impossible to get a HDMI cable directly to the tv, you should just get rid of it and get your money back - a direct HDMI link will provide you with a better image and an easier setup: with this device you will not be able to add a home theater to your tv. In my opinion this is a $300 device that nobody really needs, it's just an unnecessary gimmick.
Posted on Mar 11, 2011
What channel do I put my LG TV on to connect my Sony blueray player to watch netflix
channel is not the correct path
you need to be thinking What input source do I need on the tv
atv dtv - THIS IS FOR AN ANTENNA CABLE
hdmi1 hdmi2 hdmi3 av1 av2 these are input sources
look on remote for input or source button .
HDMI 1
Apr 18, 2016 | LG 42LC2D 42 in. LCD HDTV
What channel or setting is used on the TV to play a DVD?
Hi, Channel 3 or 4 might work for older TVs. Most new HDTV's have a mode setting in the menu. (Video 1 or 2 or 3) or (Component 1 or 2). On your remote you may have DVD button. Try all these suggestions, 1 of these will work. You can play with the remote too. Good luck.
Jun 13, 2011 | LG 42LB2R 42 in. LCD HDTV
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
We have a lg, lcd tv.model#37-LD450, we cannot get our DVD player connected so that it plays, any help would be appreciated, owners manual on a dvd and no use
Your dvd will have a scart socket or a hdmi or other socket, ( check manual), connect lead from dvd to tv, output from dvd to input on tv, from one of these ,on your tv remote select the button that changes the av select , that means the button that tells tv that you want to watch signal from dvd ,( or other input devices) ie sky video camera etc it may be av1 av2 av3, you should get a picture on one of these,
hope this helps
pete
Nov 15, 2010 | Televison & Video
How do you access the video mode in order to watch a movie on a dvd play or play a video game?
Hi, usually the function button on the remote control to select the input mode / source is a circle or a square with an arrow pointing into it (see below).
b74fea7.jpg Each time you press this, the next available source is selected in a set order, e.g. TV / AV1 / AV2 / HDMI / PC
If using a SCART interface for your DVD player, the TV should automatically switch to the DVD source when you activate the DVD player (take it out of standby).
Nov 26, 2009 | Sylvania Televison & Video
Lh300 sky box works with scart but wont work with hdmi cable just keeps saying no signal. new tv just received today
on your tv, have you selected the correct mode on your source button? eg, AV1, AV2 , PC, and HDMI
Oct 04, 2009 | LG 42LH30 42 in. LCD TV
I have an LG LCD TV (42LC2D) & a LG HDD/DVD Recorder (DBRH197). The HDD/DVD is connected to the TV via a HDMI cable. Generally, when I watch DVDs, I change the Input on the TV to HDMI, however since...
First thing to do here is to check the connection adn if possible try a different cable , because sometimes this can only be a connection or a cable problem,, as for making it unlock so you can watch any DVD on it, there's a lot of site there that is offering that service to unlock the regional code of this unit...
Hope that helps.........
Sep 15, 2008 | LG Televison & Video
Playback of any dvd you get white lines across the screen.that is on av2.if you swap leads over so dvd is on av1 it is spot on but then the tv is **** on av2.new scart leads have been fited to...
the solution is very simple you have to go out and spend more money on hdmi leads problem sorted.COST ME ANOTHER £44 POUNDS ON TOP OF THE TV AND DVD PRICE BUT NEVER MIND!!!!!!!!!!!!!
Jul 09, 2008 | Philips Televison & Video
LG Wireless Media Transmitter Box Anwl100w Logo
113 people viewed this question
Top LG Home Security Experts
Lawrence Oravetz
Are you a LG Home Security Expert? Answer questions, earn points and help others
