Question about Acer Aspire 4520-5582 Notebook
The screen is becoming white as i open it. and sometimes , i hear something ticking inside it,., and in that case, i cannot open my laptop,.
  • 111 Answers
The thin wire ribbon (lcd video cable) connecting your screen to your actual computer is either breaking or loose at the connection. I had the same thing happen to my aspire. http://www.laptopparts101.com/lcd-screen-video-cable/
Posted on Mar 11, 2011
    Problem Solver:
  • 11 Answers
Ur windows have been deactivated,,..activate dis or formate dis
  • 104 Answers
These are minor defects can be solved by formating
My lg studiowork 700s has stopped working
look listen and dance not matter how you performance keep it calp and trust it
Feb 20, 2014 | LG Studioworks 700S 17" CRT Monitor
Toshiba laptop pas409e-d screen is black
Step 1:
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Causes a Computer Monitor to Go Blank b> While a blank screen may be caused by a general power outage, more often it's a problem with the screen itself. It could be a loose video or power cable going to the monitor. If that's the case, you can get the screen working again and be back in business in a few minutes. b> Power Problems All the power might be off due to a bad outlet, switch, fuse, or circuit breaker. If you hear no sound coming from the computer and its power light is off, check the power connection and breaker or fuse. Video Cable Many times the cause of monitor blackouts is a loose video cable connection. This might happen if you move the monitor or the cable. The video cable runs from the back of the computer to the monitor. It has a multi-pin connector on each end and both of them screw down securely. If the screws aren't tight, either connector could become loose. If that happens, the video signal could stop suddenly and make the picture go blank. Check both ends of the connector to make sure they're firmly seated and the screws are tight. The cable itself might be bad.This is unlikely, but possible. b> Display Power The monitor must have power. If the power light isn't lit on the monitor, it may have been turned off or become unplugged. Press the power button to make sure it wasn't accidentally turned off. Make sure the monitor is plugged in. If it's connected to a power strip, check that the power strip is on. If that checks out, unplug the monitor and try a different outlet. Power strip sockets can sometimes fail. Flat-screen monitors may have a power-brick-style adapter. It, too, has connectors. Follow the power cable from the monitor's power plug back to the monitor. About halfway up you'll find a thick rectangular plastic brick. The power goes into a modular-style equipment socket. This can become loose. Follow the wire the rest of the way to the monitor. It connects to the back of the screen with a small round plug. Check that it's firmly plugged in. If everything's plugged in right and the power light on the monitor's still off, the power brick might be bad. b> Video Card Some computers have a separate video card inside. It may come loose and cause a blank screen. If this is the case, open the computer and inspect the video card. Sometimes removing and reseating the card will fix the problem. If it has to be replaced, most video cards are not expensive.
b>
Feb 15, 2013 | Computers & Internet
My microphone records the sounds on my computer and plays them directly back through the speakers. How can I eliminate the microphone playback and have someone else hear me on something such as skype?
double click on the volume on the taskbar (System Tray - Next to clock) and Controls for Playback will open. If you can't see Microphone Volume here, click Options- Properties - and in Playback Volume list - Select Microphone by ticking against it and press OK. You will see the Microphone Volume on screen. Just tick inside the mute box of Microphone. Now the audio from Microphone will not play but you can still record it.
Nov 16, 2010 | Sony VAIO VGN-AR630E Notebook
The display color is off
Check your display drivers. Update them if needed. If the problem persist check the connections inside the laptop (sometimes they can become loose especially if the netbook has been dropped) Worst case scenario you may have to replace the screen.
Jul 27, 2010 | HP Mini 1000 Netbook
My acer laptop screen turns white while working
Try reinstall the video drivers as it looks like an issue with the video adpater. To do so:
Start Menu> All Programs> Acer erecovery management> Restore> install Application & Drivers> Select the appropriate Video driver (Intel, NTI etc as per your computer spec) and install it. Restart the computer and check, the issue should be resolved. If not, then I am sorry I bet the computer needs repair.
Jul 01, 2010 | Acer TravelMate 2300 Notebook
White color in LCD monitor appears as pink anywhere ! but sometimes it back to white color truely.
This can be a common problem with laptop screen when white goes pink. This is caused by a faulty cable that runs from the laptop motherboard to the inverter just under the screen.
The cable becomes stretched after a while by movement of the laptop lid which pulls a pin from the cable.
What i suggest you do is take the laptop to PC repair store and have them fit a new video cable or order a replacement video cable from eBay and replace the cable yourself.
Don't be fooled by the preconception that its a bad CCFL bulb (backlight) as this is not the case.
Regards
Jun 25, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
Sony ericsson w850i problem white screen not open
Hi if your phones screen is white then this is a sign that the ribbon that takes data from the circuit board has become damaged. what happens is that when the phone has been opened and closed load of times the little copper wires that run inside the ribbon become brittle and break, the only option you have of solving this problem is to get the ribbon replaced.
its not expensive to buy and wont cost much to fit.
their is no easy fix as it is a case of getting new parts fitted to your phone.
let me know how you get on or if you need further assistance ok
Jun 13, 2010 | Sony Ericsson W850i Cellular Phone
Loud ticking on passenger side underneath aftermarkert air cleane
It sounds as though your timing has advanced and it's time for a new belt/chain, whatever the case may be.Best of luck, Dana
Aug 27, 2009 | 2004 Dodge Ram 1500
Screen becomes dark
is it a laptop? because if it is, when you open it you should hear a click, if you dont hear a click he screen will be black, so you keep opening and closing it till it clicks, if not a laptop, please explain more.
Jul 10, 2009 | Office Equipment & Supplies
Sony Vaio Desktop VGC-LS1 Clicking sound, Screen doesnt illuminat
what happen to my PC when i turn on " VGC LS1" got white screen but i still can hear the Windows run normal?? Help Please!! thanks
Mar 10, 2009 | Sony VAIO FX150K Notebook
Acer Aspire 4520-5582 Notebook Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
