Question about Saws
I have draper 600w orbital-jigsaw .stock No64430,part No pt680v voltage230/240-50hz. wood--80mm ,mild steel--8m speed load 500-2900spm serial/ No 01070196. the motor is running but blade will not move. it does not need oil or greesed.
3 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: lost instruction sheet
Try this link: http://www.accesstoretail.com/uploads/partinfo/686870.pdf
It should have exactly the information you're looking for.
If I've managed to answer your question or solve your problem, please take just a moment to rate this posting...thanks!
Posted on Mar 28, 2009
r_b03
  • 102 Answers
SOURCE: I purchased a new B&D variaable Speed Orbital
you can order that in any B&D service center..try it..
Posted on Jun 09, 2011
Owners manuals
I would like to get the instruction manual for a black & decker orbital jigsaw model JS400. I the hose fiiting for the shop vac, also the guide for the wood. thank you skip
Aug 30, 2014 | Black & Decker Saws
Oil leak from my Skil Jigsaw and it keeps Jamming when I cut wood
get a nail file and sharpen the blade till you can see your face in it
May 07, 2013 | Skil Top Handle Jig Saws Variable Speed...
No power on the jigsaw
could be several problems. If you are mechanically inclined and have a volt/ohms meter I would unplug the tool and remove the handle half and start the process of troubleshooting with the cord,,,, switch,,,, and go on from there till you find the problem. Usually it is a cord or switch that would be the problem.
Feb 07, 2012 | Makita 4304 Factory-Reconditioned Variable...
How does the Draper stud detector work
It produces a tuned magnetic field of it's own, and when a live wire or a nail enter that field it changes the loading in the detector's circuitry throwing it off tune, and depending how it is thrown off determines ifit is a nail, a wire or a live wire.
It is the same basic principle of a metal detector you would use onthe beach to find metal things.
Feb 03, 2012 | Draper Measuring Tools & Sensors
Jun 09, 2011 | Black & Decker Saws
My Makita BJV180 jigsaw will not do elliptical cutting even though I turn the lever to the elliptical cut position.
this saw has 3 orbital settings and one straight line setting .. in orbital mode the blade moves forward slightly on the up stroke and back on the down stroke .. it may be difficult to see and may not be pronounced without a load ...
Nov 12, 2009 | Makita BJV180 18V Lxt Lithium Ion Cordless...
Lost instruction sheet
Jan 25, 2009 | Saws
Both leaf springs have come off the roller wheel guide
You will have to take the case apart and push them into place. If you have access to a hemostat or a nice long, this pair of needle nose pliers, it will be helpful. There is possibly a screw inside that holds them in place. If so, get the smallest bottle of blue threadlocker that you can find. It's quite expensive and you only want enough to wet the screw threads. Only use blue, it's removeable. If you use red or black, you will not be able to turn the screws if the problem ever happens again.
Jan 03, 2009 | Skil 5.0 Amp Variable Speed...
Jig Saws Blades Types
High Speed Steel - Used for wood and light metal cutting Bi-Metal - Also used for wood and light metal cutting. Cobalt Steel - Tougher and lasts longer than Speed steel and Bi-Metal. Used for wood and metal. Carbide Grit - Strictly used to cut masonry board. Scrolling - Thinner than the regular jig saw blades and are used for tight turning cuts.
Aug 27, 2008 | Milwaukee Tool Milwaukee Orbital Jig Saw...
Blade Types
remember to match the blade width to the type of cutting you are doing. Also keep in mind: * Narrow Blades can make much tighter radius cuts, but tend to twist and wander when making long straight cuts. * Wide Blades can't make the tight turns that narrow ones can, but they hold a straighter line than their narrow counterparts. * The tpi determines the speed with which the blade cuts through stock. Blades with high tpi cut slower but leave a very smooth edge. They are best for detail work on thin stock. Blades with low tpi cut quickly and leave a slightly rough edge. They are great for resawing or long rip cuts. * Steel Blades are inexpensive and work well for cutting softwood. Steel blades, however, dull quickly in hardwood. * Bimetal Blades are made of high-speed steel and can cut thin metal or wood. * Carbide Blades are for wood cutting only. They are more expensive than other blades but stay sharper longer than steel or high-speed steel.
Aug 27, 2008 | Dewalt Variable Speed Deep Cut Band Saw...
Saws Logo
66 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
