Question about Health & Beauty
How disable blue tooth - Health & Beauty
How to disable blue tooth of samsung C3222
Posted on Apr 08, 2011
My wifi will not work unless my blue tooth is enabled, every time i turn bluetooth off my wifi goes off
it may be a faulty radio connection. Wires may be crossed where disabling the power to 1 affects to other. will need phone replaced. Make sure to mention blue tooth malfunction otherwise you'll have to pay for it.
Jan 04, 2014 | HTC Inspire 4G Smartphone
Bluetooth video is blocking my webcam on my labtop. i can not get access to my webcam it says that the bluetooth is blocking it.
If your not using blue tooth try turning it off. You didn't say what operating system your using. On windows 7 you can just click the window icon and type blue tooth in the search window. It should find your default program and get you to where you need to be to turn it off. :You may have some thing on your task bar that allows you to turn off blue tooth. Also try opening control panel and selecting device manager, Look for anything that list blue tooth and disable it. You might have a program on the the program bar under accessories that is listed as blue tooth. Somewhere you should have a way to turn it off.
Feb 17, 2011 | Computers & Internet
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Unable to connect bluetooth to another cell
Some of the carriers actually have a lockout on Blue tooth transfers. So depending upon your carrier even tough the phone itself is capable it may not be allowed. I work at US Cellular and all the B tooth options on these phone are unlocked, however they are unable to link to a verizon or sprint phone for example without having their associated data plan.
The process for doing the pairing is rather simple and if you followed the steps and they still wont its a lockout.
Go to your blue tooth setting on one of the phones, turn the find me mode on or make visable to others.
take the second phone and go to blue tooth check registered devices and click new search. once you find the other phone click pair and eenter in 0000, the other phone will ask if you want to pair in which case enter the 0000 pass code again.
Once paired if you are transfering pics or music go to your media library or pic gallary and find the fill. Select options and send via blue tooth, it will bring up the registered list and select the phone you are transfering to. that should be all you need to do, if it says not supported or unable to connect the BT is disabled and you need to speak with your wireless carier for assistance.
Nov 20, 2010 | Cell Phones
How to connect sony ericsion w395 via blue tooth
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Have new lap top [toshiba satellite] have connected tomtomgo 520 twice and on both occasions my wi fi connection has been disabled
Built-in FM Transmitter to transmit sound over own car stereo and lets not forget Best hands-free calling> Best guess is that your computer is finding and trying to connect to the blue tooth connection since Toshiba has blue tooth capabilities, also you could be losing the wifi signal just because the FM transmitter is overpowering the the wifi signal. If i had to guess though i would go for the blue tooth connection as being the problem. Hope this helps
Apr 26, 2010 | Tomtom GO 520 GPS Receiver
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Blue tooth activetes it self and control the keyboard
if your operating system is windows xp
do this:
restart your laptop then b4 it loads the windows xp logo
press F7 this will bring you to loading/booting option then select safe mode then do not go to restoration option...
after you log in disable the blue tooth services
to do this there is a small icon located at the lower left of then taskbar get your mouse pointer next to it and right click on to it to see on the options to disable it and stop its start up option..
Jul 08, 2009 | Acer Aspire 2930-4661 Notebook
My internal bluetooth is not working
try updating the drivers and go into the settings on system ,device drivers , also look under control panel and see if the bluetooth has been disabled u can also see this under device drivers section.
actionman
Feb 27, 2009 | Acer Aspire 4720 Notebook
Bluetooth installation
you need to disable your laptop.
The blue tooth connection is close to headphone jack, but you need to open the uppercase to connect your blue tooth.
Basicly you need the bluetooth and bluetooth cable.
Once you open the uppercase, you can see the internal microphone connection. the bluetooth connection is on the other side (motherboard).
Apr 22, 2008 | Acer Aspire 5610 Notebook
Health & Beauty Logo
26 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
